Re: capacitor ripple vs endurance & other questions
Well, somebody angered one of the caps gods, and he visited a bad electrolyte plague upon us all.
Of course, at the lower price you can always buy the caps and still be less than SJ.
Two on ebay for $54.Leave a comment:
"It's not 'my' equation."
Not unless your real name is Pythagoras and you're really, really old.
But then I never called it your equation, I called it the equation which you used, meaning the equation which you used in your explanation of the circumstance under which ESR is effectively equal to impedence.
.Leave a comment:
But then I never called it your equation, I called it the equation which you used, meaning the equation which you used in your explanation of the circumstance under which ESR is effectively equal to impedence.Leave a comment:
Oh, this is tooo funny -
>>(who's currently screwing around with a DAC-19M015 out of a Westinghouse SK-19H210S)<<
Look up "DAC-19M015" in Google and go to the ShopJimmy.com result.
If you don't see it in the small pic, use the enlarge function...
Well??
Come on.....
Comes with pre-blown cap!!
Send me a dozen, will ya?!?
.Leave a comment:
It's been enough years since electronics classes that I don't recall the others that involve both inductive *and* capacitive reactance, and the books aren't ready to hand, but I was only talking about the equation you actually used, which is basically the one for impedence--resistance along the X axis, starting at 0 and moving to the right, XL - XC along the Y Axis, and impedence is the hypotenuse of the resulting triangle, in other words, the Pythagorean Theorem--called for the squaring of XL-XC.
Now that I think about it, staring points and directions don't really matter. You take resistance, put it at a right angle to the difference between inductive reactance and capacitive reactance, and measure the length between the two unconnected line ends, and that's your impedence. Polarity/sign doesn't matter because what you're dealing with are lengths, and there isn't really any such thing as a negative length. Either something has length or it's a one-dimensional point.
You can grab a copy at most any cap manufacturer's site.
They don't [or didn't used to] teach ESR in school.
The 3 foot tall stack of Navy NEETS training manuals as 2 or 3 sentences about ESR and that's it.
Civilian programs covered it about as well.
It got a casual mention saying it wasn't significant and it wouldn't be included in the equations.
It wasn't significant because they teach DC and jump into RF without covering anything in between.
At DC ESR is zero and at RF it isn't significant compared to Xc.
It's in between DC and RF were ESR matters.
The reason I explained it that way is so people that aren't math gurus would understand ESR and not trip over the math.
That variable is the difference between XC and XL and which one is greater changes which means negative numbers are possible.
Either [XC-XL] or [XL-XC] work as long as it's + or zero.
The way I deliberately worded it is JUST FINE and deliberately avoided a more complicated discussion that could confuse people.
.Leave a comment:
Well??
Come on.....
Discount-Merchant has a picture of one where the caps are actually going to wait until you've gone to the trouble of installing the board and applying power before going bad, but they're currently out of stock.Leave a comment:
Now that I think about it, staring points and directions don't really matter. You take resistance, put it at a right angle to the difference between inductive reactance and capacitive reactance, and measure the length between the two unconnected line ends, and that's your impedence. Polarity/sign doesn't matter because what you're dealing with are lengths, and there isn't really any such thing as a negative length. Either something has length or it's a one-dimensional point.Leave a comment:
Hahahaha, that was the best one today by farLeave a comment:
Well??
Come on.....
Send me a dozen, will ya?!?Leave a comment:
XL-XC aren't squared in all equations and the value must not be <0.Leave a comment:
The ratings to look at beyond uF and volts are ESR and Ripple.
[Remember going up in volts isn't a problem.]
ESR is isn't really Impedance (Z) - but:
At the 100kHz they use for data sheets Xc and ESL are at values such that *effectively* ESR = Impedance.
The actual equation is:
Z² = ESR² + (XL - XC)²
[Note: (XL - XC) must be corrected to a positive value if it isn't.]
------SNIP-------
If XL-XC <0, then squaring that value will automatically result in a postive number, 'cause a negative number times a negative number is a negative negative (i.e., positive) number.
Now if the formula/equation called for raising it to an odd numbered power, then you would need to be sure to take the absolute value.
regards,
unitron
(who's currently screwing around with a DAC-19M015 out of a Westinghouse SK-19H210S)Leave a comment:
just get them from badcaps.net.problem solved!Leave a comment:
United Chemicon KZE (ammo pack - cheaper):
661-EKZE250ETD471MJ1
United Chemicon KY:
661-EKY250ELL471MJ1
Nichicon HE:
647-UHE1E471MPD6
These are Mouser part numbers.Last edited by momaka; 08-21-2010, 01:08 PM.Leave a comment:
Where are you located?
Use DigiKey, Mouser, Newark, badcaps.net.Leave a comment:
Where are you located? Profile location is blank...?
In USA, you ~generally~ won't find them. You may find 1 out of the whole group from a distributor who will only sell them in qty of 1,000 or more.
Stick with Nichicon, Panasonic, Nippon Chemi-con, Rubycon, Samxon
Great overall selection and you won't pull all your hair out trying to find them...Leave a comment:
I managed to find capacitors for all the other values except for the 470uf @ 25V (10x16mm).
I want to use either Nic Components NRSJ, NRSK, sanyo WG, or Rubycon ZLG, but I'm having a hard time finding someone who sells these capacitors. Does anyone know of any good suppliers that carry one of these brands in the specified size above?Leave a comment:
BWAHAHAHAHAHAHAAAA!!!Leave a comment:
by MORETTIGIANTitle:
Capacitor detached from PCB – RTX 2070 Super Founders Edition
Description:
During maintenance on an RTX 2070 SUPER Founders Edition, I found a capacitor lying on my desk after reassembly.
I did not notice it detaching, so I am unsure of its original location on the PCB.
Procedure performed:
- Removed backplate
- Cleaned heatsink and PCB with isopropyl alcohol + soft ESD brush
- Reapplied thermal compound
- Reassembled card
Observed behavior after reassembly:
- GPU powers on and operates normally under...11 Photos -
by chth96When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
Rubycon YK DataSheet (b...-
Channel: General Capacitor Questions & Issues
by DrewPhillipsHello All, I have on the bench a couple of PSU's which have some failed Nichicon PL series caps. They didn't "puke" their guts through the top, but instead "diarrhea'ed" corrosive brown electrolyte through the bottom, down the legs and onto the board. On one cap, the electrolyte rotted the cap right off the board leaving 2 little stubs, and also corroded a trace on the foil side.
The PSU's are Power-One MAP series and are ringing-choke topology. The semiconductors have date codes in 1993. The PSU's were used in a commercial application, fan-cooled. They had failed...-
by Per HanssonI have repaired a Sign WiFi Smart Plug with model number: SNSM-WASINGLE sold by Spares Nordic AB in Sweden.
The fault condition was that the device gave no signs of life: pressing the push button did not cycle the internal relay and the blue LED did not come on and it was not seen on the WiFi network.
The fault was very simple, capacitor C3 on the PCB with writing "KSJ" and "LOWESR" had literally blown its top off, after replacing it the device works fine again!
As I find linear high voltage regulator designs interesting I drew up the attached schematic... -
by PrologHi people, I hope this is the correct spot to post this, I'm new to the forum.
I have an RTX 3080 Founders Edition which has a burnt up capacitor (it was in parallel with another capacitor which appears damaged too), so I am hoping to be able to identify the capacitor values and order replacements.
I hope these photos make it clear which component I am referring to:
(yes, the soldering is a bit botched from removing the blown one, I know)
I have found the board schematic (attached), but there does not seem to be a boardview available. I have never... - Loading...
