hole on cap
  • spiros.p
    • Dec 2020
    • 89
    • Greece
    hole on cap
    only few months new caps on my amp and today i want to set the bias and amp going in protect mode and start smoke.imediatly shout down open it and found this!!!!!! leak from one capacitor desolder and see two holes on the can.i suspect was there from beginning from transport maybe?the holes is from out to in is like a nail pin not like from screwdriver.realy angry about that.
  • spiros.p
    • Dec 2020
    • 89
    • Greece
    Re: hole on cap
    i have found what causes the holes is excactly the distance from other capacitor legs.during transport from supplier not right packet
      • 22168
      Re: hole on cap
      holey smoke
      • spiros.p
        • Dec 2020
        • 89
        • Greece
        Re: hole on cap
        i hope don't get any more damage the amp i clean the electrolyte and measure the afected components looks all ok.wait for new creplacement
        • ChaosLegionnaire
          HC Overclocker
          • Jul 2012
          • 3266
          • Singapore
          Re: hole on cap
          thanks. this is a cautionary tale for me not to use dented, holey or pierced caps. i've always wondered if it was okay to continue using them or to recap them at once. this answers my question. i shall stop using those stuff with dented, holey and pierced caps and recap them whenever i get the chance or spare time.
          • eccerr0r
            Solder Sloth
            • Nov 2012
            • 8711
            Re: hole on cap
            possible that the manufacturer put dents in the can so they can fit smaller windings of foil/separator in a bigger can so it won't rattle inside, at least I thought I've seen this in the past before?
            • CapLeaker
              Leaking Member
              • 8352
              Re: hole on cap
              Weird. I’ve seen all kinds of dented caps, but not something like this. Almost looks like someone put a drill punch on the cap and drilled a perfect hole in there.
                • 31289
                Re: hole on cap
                crushed against another 10mm cap - someone probably stepped on the package!
                • spiros.p
                  • Dec 2020
                  • 89
                  • Greece
                  Re: hole on cap
                  yes i measure the legs from the cap and fits excactly on the two holes.wrong package and during transport hit each other. if i remember correctly the packet was to big and include some other smal components i have ordered semicontuctors and so on.is a wonder hold so long the cap.don't use a lot the amp since last winter maybe 50-60 hours til now.
                  • eccerr0r
                    Solder Sloth
                    • Nov 2012
                    • 8711
                    Re: hole on cap
                    Oh now I see the hole on the side in the dent... that's abnormal.
                    it wasn't underneath the heatshrink?
                    This looks too suspicious to be something other than foul play...
                    • spiros.p
                      • Dec 2020
                      • 89
                      • Greece
                      Re: hole on cap
                      nippon SMH 6800mf 100v.to heavy and quality cap.let 4 of them free in a plastik bag and close in big paper box to travel 400km road and line ferry boat.accident warranty.
                      • spiros.p
                        • Dec 2020
                        • 89
                        • Greece
                        Re: hole on cap
                        today replaced the capacitor the amp works again ��
                        • silberdrache
                          Burnt Hole under IC on MacBook Pro M1 Pro 14"
                          by silberdrache
                          I'm new to this Forum, so I hope it's the right place for this topic.
                          Im a student from germany, and as a hobby I repair electronics. I started microsoldering maybe 1-2 years ago.
                          I have a MacBook Pro 14" m1 Pro with 10 Cores and 16/1tb storage. The board Number is 820-02098-A.
                          The MacBook has a light water damage. Coffee got spilled over it, but the Mac continued working only the battery didn't charge anymore and when the battery was empty the Mac turned off and doesn't show any sign of life now.
                          I opened it up and there were only three drops of coffee...
                          11-10-2025, 11:19 AM
                        • howardc64
                          by howardc64
                          Problem
                          08-04-2024, 10:36 PM
                        • 13mh13
                          Aluminum SMD caps vs thru hole caps (reliability)
                          by 13mh13
                          The PCB motor for 1987 Technics SLP-120 CD player has slow spin-up issues. Similar to what another tech in the below video reported.
                          https://i.postimg.cc/kGrR6BpZ/image.jpg
                          I replaced the three bi-polar 47uF electros but that made no difference. The orig three bi-polar 47uF electros tested okay on my ESR M-tester.
                          I have not tested/replaced those alum. SMD electro PCB caps.
                          Are Al smd caps are more prone to failure (or degradation) than regular thru-hole electros?
                          All the thru hole electros I removed / replaced on this CDP (and most...
                          04-05-2024, 07:41 PM
                        • SluggerB
                          Would this be safe?
                          by SluggerB
                          I am trying to fix a broken plasma TV by replacing a large cap on the power board. It is a 1900uf 220v cap and I could only find one place that sells them. It was listed as through hole, so I bought it. It showed up today, but instead of through hole, it has spade connectors.
                          Would it be safe to get some heavy duty wire (like lamp cord wire), connect that to spade connectors, connect them to the spades on the cap, and run the other ends of the wire 2-3 inches to the holes and then through the holes and solder them in place? I actually did it already and put it together but...
                          06-04-2025, 04:22 PM
                          by momaka
                          03-15-2023, 10:17 PM
