Help identifying capacitor
  • kalemaroni
    • Jun 2016
    • 189
    Please could someone help me identify what the capacitance, voltage, tolerance and package of this cap is please?
    Written on the cap's head:
    470
    jFK
    6K3
    Many thanks in advance
  • Lisa Su
    Badcaps
    • Apr 2021
    • 216
    • Taiwan
    Re: Help identifying capacitor
    Post here
    https://www.badcaps.net/forum/showthread.php?t=111326
    • R_J
      • Jun 2012
      • 9624
      It is likely a Panasonic FK series 47µf 63v
      • kalemaroni
        • Jun 2016
        • 189
        Originally posted by Lisa Su
        Thanks. Am I being blind or is there no way for me to delete this post after copying to the thread you linked?
        • R_J
          • Jun 2012
          • 9624
          Don't worry about it, you can't delete threads, maybe the mod will if he wants to.
          • Prolog
            by Prolog
            12-01-2024, 08:27 PM
          • MORETTIGIAN
            by MORETTIGIAN
            Title:
            Description:
            Procedure performed:
            - Removed backplate
            - Reapplied thermal compound
            - Reassembled card
            09-18-2025, 12:14 PM
          • Sparklingx
            SMD ceramic capacitor capacitance & voltage
            by Sparklingx
            what is the easiest way to measure the capacitance of SMD ceramic capacitors and its rated voltage?...
            09-12-2024, 01:04 AM
          • Ambro
            Help identifying missing smd capacitor for HP elitebook 840 g3
            by Ambro
            In an unfortunate mishap while attempting to read from the bios chip, one of the smd capacitors took flight and disappeared.
            I'm not sure how crucial this smd capacitor is, but it was a brown possibly ceramic one with no notable markings on it anywhere.
            I've attached a picture of where it's located on the board.
            Does anyone have an HP elitebook 840 g3 who might be able to aid me identifying this component. I'm not sure how crucial it is, but didn't want to risk it.
            Thank you for any help you can provide....
            09-09-2023, 06:21 PM
          • grimacelord
            Need Help Identifying Capacitor On Kar-Tech Versa Remote
            by grimacelord
            I have sort of a weird one here. This is the circuit board for a Kar-Tech VERSA remote. It's a wireless transmitter for crane and other heavy equipment.
            One of the capacitors have blown and I need help finding a replacement. The capacitors are 11.4mm x 6.6mm in size and the only imprint on them is "200mΩF", which I am assuming means 200 microfarads. There is no other markings on them. I have tried doing some searching on digikey and mouser, but I can't seem to find anything like this on there or I am inputting the wrong search parameters....
            09-08-2023, 09:28 AM
