Re: Post help identifying capacitors here
I have an Alienware Area 51m laptop that blew a surface mount aluminum cap.
I've attached an image showing the following lettering:
8 N
100
EZY
I know it's 100uF 25V series ZY but I'm coming up dry on locating the manufacturer.
Any ideas?
Thanks,
-vencain
This is a sticky topic.
That looks more like a MOSFET or DC-DC converter IC to me, from the little I can see.Leave a comment:
Can anyone identify this component for me please? It's from an Asus US425IA motherboard. The writing on the component reads "ML KABK EKBD"
https://ibb.co/Smgr01T
https://ibb.co/8n3CV3XLeave a comment:
The basic values are there, but no (known to me) manufacturer, no series name, no date code.
Thanks for commenting.Leave a comment:
Other than being from china, I can find no original company manufacturer. Like, noneLeave a comment:
look for more writing like uf and voltageLeave a comment:
I already answered in your other thread
It is a Panasonic FK series 47µf 63vLeave a comment:
Please could someone help me identify what the capacitance, voltage, tolerance and package of this cap is please?
Written on the cap's head:
470
jFK
6K3
Many thanks in advanceLeave a comment:
ok let me start by contributing to this thread, the famous japanese website link that is used to identify many brands of polymer/solid capacitors: http://capacitor.web.fc2.com/solidcapacitor.html
and to the newbies reading this, just use google translate by copy-pasting to translate the japanese text on the webpage to understand what they are saying in japanese.Leave a comment:
Or just a link that does a search on this forum for the word "identify"Leave a comment:
It's stickied. Perhaps just link some of the many in here, so there's some reference material.Leave a comment:
I think just starting fresh would help and we can do the rest later. Actually I think there is so many it might be pointless to combine all those thousandsLeave a comment:
Probably need to combine a lot of these others into one and FAQ it.Leave a comment:
There are so many 'Help me identify this' threads we need a single stickeyed thread and TC has agreedTags: None- Stuck
by varkatopeHey there, retro fans.
I have an MS6163 version 1 board I'm trying to repair which was obviously used as a donor because it's missing a few parts, mostly capacitors. There are few high quality images online that would allow me to read the capacitor values (bad angle, blurry photos). I thiiiink I've figured out most of the values for the missing ones except for one in particular, number C210, which is in the bottom-left of the attached photo. Could someone with this board be so kind as to take a look at theirs and tell me the capacitance and voltage values of all the highlighted missing...1 Photo -
by dragon3xHi, I have some 32 bits computer motherboards that need repair, as they fail to
power on.
Here are some examples :
(N.B. "capacitors" indicated here are electrolytic capacitors located in the onboard
switching supply area).
(N.B. #2 : I could not find a 3300 microF aluminum-polymer with a higher voltage
than 6.3 V.)
1 - Motherboard #1 : this is an Asrock K7VT2 (socket A) that still works well. To put it on test
I replaced capacitors with aluminum-polymer.
3300 microF/6.3 V. x 4 replaced by 3300 microF/6.3 V. (KYOCERA... -
by slybundahey all, iv got my favourite battery charger here which iv had for many years probably 15 years now or maybe even more. it still works good but thought id open it up to clean the dust out of it, lots of dust inside but now its clean and noticed 4 capacitors inside it and wondered if i should replace them.
it has inside:
2 x 47uf 16v caps 105c branded as Su'scon (lol sounds sus to me)
2 x 470uf 16v LZ105c branded as G.Luxon
not heard of these brands are they any good?
iv attached photos of the charger and the board inside for an idea on the type of...-
Channel: General Capacitor Questions & Issues
by sam_sam_samI did not have any 27uf @ 50 volt capacitors but one nice thing is that it has enough room for two capacitors in parallel a 22uf and a 4.7uf @ 50 volts 22 plus 4.7 equals 26.7uf which so very close to 27uf I will show some pictures of it sometime tomorrow
After all of... -
by Ady2017I have a 2007-era Panasonic VHS combo that is full of of Elna RJG capacitors. I am trying to test the capacitors to diagnose the machine and then select replacement capacitors but I can not find any datasheets for them. I did find a Elna catalogue from 2007-2008 but there is no mention of this capacitor series. Where these specially made for Panasonic and so not made available to the public? Any ideas what to find out what the ESR values should be without the datasheets? They are all between 10V and 50V and 47uF and 1800uF. None are leaking or bulged but I know that they need to be tested to be...
- Loading...
