Post help identifying capacitors here
This is a sticky topic.
The cap that scottl31 posted above is Nichicon HC series, as lti correctly identified.
EB series from Panasonic is not quite adequate in that case, if ESR and ripple current capability are to be observed.
Relatively close replacements would be United Chemicon KZE and KZH or Rubycon ZLH or ZLQ. All of these are readily available on both Mouser and Dikigey ATM. Just match the capacitance and the voltage (10V, 470 uF), along with the diameter. Height-wise, UCC KZH and Rubycon ZLH and ZLQ will likely both be shorter, since they are newer miniaturized series.
*edit*
Forgot to add... Nichicon HW and HV series would also be close enough (if not better), along with Panasonic FR and FS. These are also readily available on Digikey and Mouser.
Happy hunting!
.Last edited by momaka; Yesterday, 06:37 AM.Comment
by varkatopeHey there, retro fans.
I have an MS6163 version 1 board I'm trying to repair which was obviously used as a donor because it's missing a few parts, mostly capacitors. There are few high quality images online that would allow me to read the capacitor values (bad angle, blurry photos). I thiiiink I've figured out most of the values for the missing ones except for one in particular, number C210, which is in the bottom-left of the attached photo. Could someone with this board be so kind as to take a look at theirs and tell me the capacitance and voltage values of all the highlighted missing...1 Photo -
by dragon3xHi, I have some 32 bits computer motherboards that need repair, as they fail to
power on.
Here are some examples :
(N.B. "capacitors" indicated here are electrolytic capacitors located in the onboard
switching supply area).
(N.B. #2 : I could not find a 3300 microF aluminum-polymer with a higher voltage
than 6.3 V.)
1 - Motherboard #1 : this is an Asrock K7VT2 (socket A) that still works well. To put it on test
I replaced capacitors with aluminum-polymer.
3300 microF/6.3 V. x 4 replaced by 3300 microF/6.3 V. (KYOCERA... -
by slybundahey all, iv got my favourite battery charger here which iv had for many years probably 15 years now or maybe even more. it still works good but thought id open it up to clean the dust out of it, lots of dust inside but now its clean and noticed 4 capacitors inside it and wondered if i should replace them.
it has inside:
2 x 47uf 16v caps 105c branded as Su'scon (lol sounds sus to me)
2 x 470uf 16v LZ105c branded as G.Luxon
not heard of these brands are they any good?
iv attached photos of the charger and the board inside for an idea on the type of...-
Channel: General Capacitor Questions & Issues
by sam_sam_samI did not have any 27uf @ 50 volt capacitors but one nice thing is that it has enough room for two capacitors in parallel a 22uf and a 4.7uf @ 50 volts 22 plus 4.7 equals 26.7uf which so very close to 27uf I will show some pictures of it sometime tomorrow
After all of... -
by Ady2017I have a 2007-era Panasonic VHS combo that is full of of Elna RJG capacitors. I am trying to test the capacitors to diagnose the machine and then select replacement capacitors but I can not find any datasheets for them. I did find a Elna catalogue from 2007-2008 but there is no mention of this capacitor series. Where these specially made for Panasonic and so not made available to the public? Any ideas what to find out what the ESR values should be without the datasheets? They are all between 10V and 50V and 47uF and 1800uF. None are leaking or bulged but I know that they need to be tested to be...
- Loading...
