Supercapacitors/EDLCs...why are they failing?
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8716
    After reading https://www.badcaps.net/forum/showthread.php?t=72162 it seems that supercapacitors simply do not last that long...
    ... or is it that it's being design-abused? Did Fluke mess up on this design?
    Supercapacitors/EDLCs used as memory storage maintainers are presumptively used so that the cost/annoyance of swapping batteries are done away with. As a capacitor it should have long charge/discharge endurance, though supercapacitors not as much as a regular capacitor, but does it have significantly larger cycle counts compared to a, say, LiFePO4 battery?
    Compare it to those tiny leakbomb Varta or other brand 3.6V NiCd/NiMH batteries used frequently on old motherboards versus an EDLC, which lasts longer before they become unusable?
    Are there other devices that frequently have their EDLCs fail? I don't have a Fluke DMM and don't know if I have devices with EDLCs... I did extract a small EDLC (0.047F) from some device and it still seems to work, so they're not extremely fragile AFAIK...
    • 31301
    Re: Supercapacitors/EDLCs...why are they failing?
    they failed on VCR's a lot
    • Per Hansson
      • Jul 2005
      • 5895
      • Sweden
      It must be something wrong with the implementation:
      Siemens uses them in their 840D PLC units as a backup for the 3v lithium battery (so you have like 20 mins to replace it with the power off)
      I've never seen one fail: and some are 20+ years old...
      But I agree with STJ: seen them failed in home entertainment receivers myself.
      And the many examples of Xbox and Fluke's on this site...
      • Dan81
        SNES-powered
        • Oct 2013
        • 1866
        OG Xbox is probably the most well known example of supercaps failing.
        Apparently Aerogel technology didn't age well, at all.
        Main rig:
        Gigabyte B75M-D3H
        Core i5-3470 3.60GHz
        16GB DDR3-1600
        Samsung SH-224AB DVD-RW
        Delux MG760 case
        • Heihachi_73
          • Jun 2012
          • 713
          To be fair, regular 2001-era capacitor technology didn't age well either. If you had an MSI board back then you were lucky it lasted two years as they were full of Chhsi junk. Even uber-expensive servers didn't get away from it when their Nichicon HMs started taking a dump. Need I mention KZGs?
          • eccerr0r
            Solder Sloth
            • Nov 2012
            • 8716
            I would imagine that EDLCs would be formulated differently than regular capacitors... and were there any off brand EDLCs that weren't mostly Panasonic out there?
              • 31301
              lots of companies made them at one time or another,
              the oldest i'v seen are from 1987 on sega arcade boards - those ones never leaked.
              but those ones had thick steel cases - whoever made them obviously knew something!
              • lti
                • May 2011
                • 2558
                I remember those being NEC/Tokin caps (the same company that made those horribly unreliable caps in PS3s and some laptops). They were also larger than modern style caps of the same value.
                It looks like Kemet is selling them now.
                https://www.digikey.com/en/products/...H105ZF/4290877
                  • 31301
                  NEC, Elna, Tokin, Samsung - like i said, everybody made them for a while but most stopped because they didnt get huge use
                  • eccerr0r
                    Solder Sloth
                    • Nov 2012
                    • 8716
                    CapXon?
                      • 31301
                      Originally posted by eccerr0r
                      CapXon?
                      maybe now, but not back when i first started seeing them.
                      • eccerr0r
                        failing hard drives after sitting for years...
                        by eccerr0r
                        With the discussion about water pumps failing when cars sit for a while, I wonder what people have seen with hard drives. Do people see hard drives failing after being sat on the shelf for a long time unpowered versus a hard drive that's at least powered up at least once in a while, say, weekly?
                        Wonder if it's worth spinning up the spare spinners once in a while to keep the bearings lubricated?
                        Wonder how I should best keep my cold spares for my RAID "fresh" for eventual failures of the working drives. Was thinking about keeping a hot spare but that's another...
                        03-02-2023, 10:33 AM
                      • TimScrawn
                        A2337 820-02016-A Failing DFU mode
                        by TimScrawn
                        I have a very strange issue here. Customer was using Mac one day and stopped working when they went to use it the next day. I plugged it into my amp meter and I got 5v at 0.10amp.
                        Checked all rails:
                        PPBUS_AON: 12,3 V
                        PP3V8: 3.79v
                        PP3v3_AON: 3.29v
                        PPDCIN_AON_CHGR_R: 5 V
                        The very strange part of the issue is that I left the Mac on one side for a day, came back to it and reconnected everything. Connected the DFU cable to a WS machine and connected the charger. The Mac then booted to the login screen? I then logged in and because I was after...
                        06-29-2025, 10:27 AM
                      • Andri15
                        ASUS ROG G513R-MP-VGT 6050A3348202-MB-A02 frequently restarts
                        by Andri15
                        can someone help me,i have a case for this series often restart.
                        After entering Windows for 5 minutes, the laptop immediately restarts.
                        is this related to cpu/gpu​?
                        04-23-2025, 11:28 PM
                      • ja1870
                        Intermittent Samsung H4000 TV A/V problem. Failing component, or "reset" fixable?
                        by ja1870
                        As probably no symptom is unknown to those around here, would appreciate any comments.
                        Trying to troubleshoot an intermittent condition for a non-technical senior - remotely.
                        When I can get over there, will try a factory reset, but suppose it could be a symptom of a failing cap or other component - and prefer to be forewarned either way, if possible.
                        Detail:
                        Older 28" (non-Smart) flat screen Samsung UN28H4000AFXZA works perfectly, except when occasionally displays one of two - probably related - symptoms.
                        1) Channel displays...
                        03-15-2023, 05:17 PM
                        1970 Metal Lathe Control Circuit blowing fuses on the 120 volt section failing meager test below 60 mega ohms
                        I was working on this machine yesterday and I now going to use an incandescent lights instead of a fuses to figure out what the issue is with it blowing control voltage rail but this not the only issue the coolant pump failed the meager test as well as the main motor as well this motor has 12 motor wire leads instead of the normal 9 wires
                        This metal lathe has a weird motor setup it has a soft start motor with a “Y” and a delta type of motor winding setup and it is not done in the motor pucker head enclosure it is with four different contactors wired in a configuration I have not...
                        12-29-2024, 07:18 AM
