Intermittent Samsung H4000 TV A/V problem. Failing component, or "reset" fixable?
  • ja1870
    • Jul 2014
    • 16
    As probably no symptom is unknown to those around here, would appreciate any comments.
    Trying to troubleshoot an intermittent condition for a non-technical senior - remotely.
    When I can get over there, will try a factory reset, but suppose it could be a symptom of a failing cap or other component - and prefer to be forewarned either way, if possible.
    Detail:
    Older 28" (non-Smart) flat screen Samsung UN28H4000AFXZA works perfectly, except when occasionally displays one of two - probably related - symptoms.
    1) Channel displays picture, but no built-in sound output. Changing volume setting, or toggling mute button does nothing. Audio-out ports status is unknown.
    2) Channel "blank" and displays "no signal" message. But signal quality/strength display is fine.
    Taught user to power off and back on - after which all is well.
    Presume the OTA roof antenna is still up with strong signal, and coax tightly connected, and that household power is stable.
    Can't get a definitive answer from the user, but think it usually happens after TV has been on - rather than showing up immediately after power-up.
    Thanks.
  • R_J
    • Jun 2012
    • 9628
    Re: Intermittent Samsung H4000 TV A/V problem. Failing component, or "reset" fixable?
    There does seem to be a firmware update ( ver 1042.0 ) for that model from Samsung, give that a try first https://www.samsung.com/ie/support/m...E32H4000AWXXU/
    • Rajnhl
      • Oct 2018
      • 94
      • India
      some samsung led models auto detect input signal as normal composite video signal and component signal. there is switch in socket which loosens after some time due to dust , try to clean it by spraying wd40 in AV input sockets.
      • ja1870
        • Jul 2014
        • 16
        Thanks for the hints. Found the update to firmware for the exact model and will try that when I can get there. Will be sure to bring a spray to clean as well.
          09-07-2024, 05:50 AM
        • C152Heavy
          Samsung LN46C630K1F – Intermittent Backlight, BN44-00341B Power Board
          by C152Heavy
          Summary for TL-DR readers:
          • Backlight is intermittent, may come on with TV boot or not. No flickering, never fails during TV on.
          • Have obtained Samsung schematic & service documents - Can upload if helpful.
          • Have read ALL applicable threads
          • C1818 and CP820 replaced as low hanging fruit
          • CN802 data taken for normal and failed BL operation. SUMMARY: Pin 2 - 5vDet = 3.52 @normal, 0.0 @BL fail. Pin 6 - EPWM = 1.631 @normal, 1.058 @BL fail.
          • VCC pin (18) of PFC...
          01-11-2023, 02:53 PM
          09-06-2024, 11:40 PM
          09-06-2024, 08:40 PM
