solid polymer electrolytic capacitor go boom?
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8701
    Anyone had a solid polymer capacitor fail for whatever reason?
    How do they fail? Do they explode, go open, short out, ?
    How about for different reasons: forcing excessive ripple current, overheating, voltage too high, reverse voltage?
    Just wondering about the causes for a potential shorted solid polymer capacitor... trying to debug a board that has a ~4Ω "short" on a track... it may or may not be a capacitor but was wondering what if it were...
    • 31015
    Re: solid polymer electrolytic capacitor go boom?
    i watched a video of trying to fuck a bunch of them,
    guy ran them at rated voltage in reverse polarity, they went dead short and just cooked till the leads melted
    that said, there was a guy on another forum a few years ago, re-capped a mobo and put one in backwards, it exploded and put black tar-like goo all over the place.
    so it may depend on the internal design/manufacturer.
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8701
      hmm...also curious what happens if they get overheated or overvoltaged. Unlike a "wet" capacitor, they don't have a liquid to boil off so I can't extrapolate a regular aluminum wet capacitor over. Reverse polarity it seems very similar to an aluminum wet, except that one case where the internal resistance got so low the leads were more resistive
        • 31015
        well given my previous post, i suspect they get very hot and then it's down to the specific design whether it stays in one piece or expands and blows the can off
        • AleXis6
          • Feb 2021
          • 69
          • Belarus
          I have several unbranded without any prints can do some experiments.
          what the design do you suggest?
          can try overvoltage or reverse polarity
            • 31015
            put a bowl over it or do it outside.
            you can thank me later!
            • PeteS in CA
              • Aug 2005
              • 3581
              • USA, Unsure of Planet
              I recently saw a polymer cap that had been installed reverse polarity. But for being inside the P/S case it would have launched. The case limited the height the cap attained.
              About 15 years ago (time's fun when you're having flies!) when I was torture testing lytics, I tortured a couple of polymers - probably ran them at ~8X rated ripple current - and the things just kept running. I don't remember whether, after several thousand hours, the things even reached double their initial impedance.
              PeteS in CA
              • eccerr0r
                Solder Sloth
                • Nov 2012
                • 8701
                looks like reverse polarity has been well tested, and looks like high ripple current are even tolerated...
                wonder about overvoltage and high ambient heat now?
                • PeteS in CA
                  • Aug 2005
                  • 3581
                  Polymers don't have a liquid electrolyte that could cause venting or evaporate.
                  PeteS in CA
                    • 31015
                    you say that, but if the chemical outgasses or there is an air-pocket in the end of the can then expansion can still blow the can off the contents
                    • PeteS in CA
                      • Aug 2005
                      • 3581
                      Since in both polymer and liquid electrolyte capacitors the dielectric is aluminum oxide, not the polymer or liquid electrolyte, are the frequency characteristics for the two types substantially different? I couldn't find charts.
                      PeteS in CA
                      • cloudff7
                        Electrolytic capacitor leak in storage?
                        by cloudff7
                        there a risk of this aluminum electrolytic capacitor of electronic device long term storage opening and leaking acid and corroding the PCB board?
                        07-22-2024, 06:27 AM
                      • chth96
                        Should I replace polymer capacitor?
                        by chth96
                        a few days ago I finally purchased mser-100 v2 and I tested its abillity of measuring ESR value.
                        I found that It shows pretty accurate ESR value for electrolytic capacitor,But When I measure polymer capacitor of dreamcast game console,I found that one third of polymer capacitor's ESR value is more than twice the value of ESR meter table.(for example, I measured one polymer capacitor of 6.3v 100uf, It showed ESR value of 7.68)
                        Although my dreamcast now turns 20 years old but it still works. I occasionally have played game with it.
                        Is this ESR value of polymer capacitor correct?...
                        11-18-2022, 04:22 AM
                      • AleXis6
                        Manufacturing Date of Electrolytic capacitor
                        by AleXis6
                        Guys. could you help me please to decode some codes of main capacitor's producers.
                        I would like to know the manufacturing date.
                        Based on the information from capacitors I have - it seems easy to decode manufacturing date for Rubycon, Nichicon.
                        If I understood correctly:
                        1. Nichicons marks date of production as (see the attached pictures) H2116
                        I don't understand the meaning of first letter - may be it is code of factory.
                        21 -year
                        16 week
                        I bought this capacitor recently.
                        another one-
                        2....
                        10-11-2021, 02:20 PM
                      • Prolog
                        RTX 3080 FE Identifying capacitor
                        by Prolog
                        Hi people, I hope this is the correct spot to post this, I'm new to the forum.
                        I have an RTX 3080 Founders Edition which has a burnt up capacitor (it was in parallel with another capacitor which appears damaged too), so I am hoping to be able to identify the capacitor values and order replacements.
                        I hope these photos make it clear which component I am referring to:
                        (yes, the soldering is a bit botched from removing the blown one, I know)
                        I have found the board schematic (attached), but there does not seem to be a boardview available. I have never...
                        12-01-2024, 08:27 PM
                      • beogeek
                        Need replacement advice for surface mount electrolytic capacitor
                        by beogeek
                        I have a faulty monitor, the surface mount electrolytic capacitor 33uF 100V needs to be replaced, now I can't seem to source them locally, so my question is can I replace it with a through-hole electrolytic capacitor of the same value? Or has someone got a better suggestion?
                        Cheerio...
                        03-17-2022, 01:43 PM
