Blown cap on old dwell gauge - kal equip 2851
  • snakeintheeaglesshadow
    • Dec 2021
    • 10
    Re: Blown cap on old dwell gauge - kal equip 2851
    Originally posted by desert-rat
    Did you try to see if it would work? Volts and ohms are easy to check. For tack and dwell you would need an old car with points.
    I did try to use the tach function. My car doesn't have points ignition, but is old enough to use the tach. If I recall correctly, it worked for a split second then died, and now won't turn on at all. I'm pretty sure I attached the leads incorrectly. Probably attaching one to 12v that shouldn't have been.
    I will test the resistor in the next couple of days and report back.
      • Dec 2021
      • 10
      I finally found my multi meter and was able to test the resistance. The meter reads 05.0. However, the resistor practically crumbled while removing so I'm not sure how accurate that can be.
      Does that narrow-down the correct resistor at all?
      • redwire
        • 3912
        The old burnt resistor was GREY-RED for the first two stripes, so it's 82 something something, either 8.2Ω or 82Ω yet you measure 5.0Ω on the burnt part. Hmmm.
        I would put in 82Ω and see how it works. If the new part is the wrong value, both Ohms ranges (Rx1, Rx1,000) will read way wrong.
        You would put a potentiometer for the test resistance and see What it the meter reads.
        Or, connect a known resistor to the test leads and put a 1k potentiometer in place of the mystery burnt resistor and dial in the right reading, then measure the pot to get the value.
        I would say the meter was in Ohms function and saw power which overloaded it. It's too easy to be measuring Volts and hit the slide switch. Oops. Smoke. Why does the middle slide switch say "Volts" yet the line goes down to Ohmsx1? So confusing. Do not drink and dwell lol.
          • 31213
          if the meter wasnt zero'd then it probably had 0.4 to 4ohms in the leads, sockets, switch etc.
            • Dec 2021
            • 10
            Ha! Or don't dwell at all and upgrade to HEI.
            You mean touching the volt meter probes together and subtract the number from the resistor's value? I did that now and the 'empty' value is indeed 01.0. Meaning the final value of the burnt resistor is 4 ohms?
              • 31213
              maybe,
              if you turn the meter off and on, is the lead value always the same?
              • eccerr0r
                Solder Sloth
                • Nov 2012
                • 8701
                cars don't use tachometers anymore?
                hmm... electric cars wouldn't have tachometers I suppose but any gasoline ones it's still somewhat interesting information. Might not be useful information for automatic transmissions however...
                  • Dec 2021
                  • 10
                  maybe,
                  Yes it seems to be the same 'empty' 01.0 value after a few power cycles. Does that change the values of the resisters I should try?
                  It's actually designed for tuning a carburetor. The RPM is a useful data point to do so.
                    • 31213
                    no, the dwell meter is for ajusting the distributer advance or spotting a vac leak on the line
                    they are still used on some raced up cars like the B series honda engines with variable cam gears.
                    • redwire
                      • 3912
                      Dwell was used for setting point gap, this box can run off a 9V battery so it can do old small engines- moped, lawn mowers etc.
                      OP see if your multimeter is pooched. Measure ohms on some resistors, compare to another multimeter etc.
                      My estimate - the burnt resistor was 82Ω.
                      • cmlewis89
                        LG 47LB5DF blown power supply board
                        by cmlewis89
                        Hi folks,
                        I'm new to this forum. So my trusty 17-year-old LG 47" LCD recently died. As I was booting it up, I heard a hum followed by a loud bang, sounds of pieces flying around, and loss of power to the unit. Inspecting the PSU, I saw two obvious problems: a blown thermistor (bang + flung pieces) and a visibly bulging main cap. Inspecting as many components as I could with my Fluke MM, I diagnosed that the following components on the "hot side" of the board were also bad: one of the 2 main MOSFETs, main 8A fuse, small cap (25V 47uF) connected to main caps, and a blown...
                        09-03-2024, 07:50 PM
                      • drscoot
                        HP X360 convertible battery blown fuse error, not charging
                        by drscoot
                        HP Modelnumber: 14-dh0061nb​
                        This laptop had a shorted cap on a Vcore section. After replacement is works again. But there is still a battery issue.
                        The battery is HT03XL and with the built-in component test from HP, in the Power section, I get an error: Logic State: Calibration required (20), Charge state: Blown Fuse (42)
                        I have another same battery, also with error: Logic State: Very Weak (70), Charge state: Blown Fuse (42)
                        And a third battery TF03XL (looks identical) with error: Logic State: OK (0), Charge state: Blown Fuse (42)
                        All these 3 batteries are charging...
                        12-15-2023, 05:54 AM
                      • swerg
                        Part selection for possible blown inductor on ASUS GX531-GW-AB76 laptop mobo
                        by swerg
                        Hey everyone,
                        I'm a novice trying to repair my laptop. The LCD screen has an image, but no LED backlight for the image. It also produces an image when connected to an external monitor.
                        I have found what I believe to be a blown inductor labeled "L4502" and "120 Ohm" in the schematics (zoomed in image, blue arrow to blown component). I have included an image of the general area of the mobo and an excerpt from the schematics as well.
                        I am having trouble selecting a replacement component, which I believe to be a 120 Ohm ferrite bead, from the components...
                        06-06-2024, 03:39 PM
                      • MrzPdlch
                        Blown fuses on Gigabyte GTX 980TI 6GB
                        by MrzPdlch
                        Hey everyone,
                        I just went ahead and unscrewed a faulty GTX 980 TI from Gigabyte. What I found beneath the cooler was, as it seems, a common issue of that card. Two blown fuses on the bottom right corner of the card next to a MOSFET.
                        Now my question would be if there is any schematics of that card available to figure out which are the blown components so I can try and replace them together with the mosfet if needed.
                        Find some pictures of the actual GPU together with a picture of how it should look like.
                        I also wonder whther it might be a problem that there...
                        03-10-2024, 04:14 PM
                      • cheeky2
                        Samsung BN44-00262A H37F1-9SS power supply help finding blown value components!
                        by cheeky2
                        This Samsung combined power supply and inverter was replaced a while ago from a Samsung 37inch LE37B530P7W TV. However I would like to repair this one.
                        I have replaced the Mosfets Q1820 and Q1821 ( FDPF7N50U) which were both blown and the fuse FM802S. The schematic for this power supply that is attached doesn't relate to this power supply as the driving transistors and diodes are D1830, D1831, D1832, D1833, Q1811 & Q1810 are nowhere on the schematic!
                        Does anyone know what the components for D1830, D1831, D1832, D1833, Q1811 & Q1810 should be? I ask as I did change the Mosfets...
                        06-15-2025, 05:12 AM
