Can I Know Capacitors suitable Capacitys Listwise?
  • imcyberking
    • Jun 2010
    Hi Friends,
    I'm Asif Here M biggner in this Subject..
    I Don't know the capacitors compatibility,
    I mean, I want to know the list of capacitors which can
    suitable with another capicity..
    Ex: I have 1800uf, 6.3v cap, but it is not available
    in market so i learn here in this forum that 2200uf cap is suitable
    for it, in case i face the same problem with another capasity of cap,
    then how can we find out which can compat the same ..
    Thanking u sir...
    Mr.Asif
    Hi Friends
    This Is Asif Here From India
  • kaniki
    • 514
    Re: Can I Know Capacitors suitable Capacitys Listwise?
    another thing that you might want to consider is the voltage. if you have a 1800uf 6.3v cap and none are available, but 1800uf 10v caps are available, then that is pretty much always fine to do. If possible, I would go with the higher volt's or V then uf's
    • dragon3x
      After updating motherboard capacitors, what to do next (Asrock K7VT2, SOLTEK SL-75FRN2L)
      by dragon3x
      Hi, I have some 32 bits computer motherboards that need repair, as they fail to
      power on.
      Here are some examples :
      (N.B. "capacitors" indicated here are electrolytic capacitors located in the onboard
      switching supply area).
      (N.B. #2 : I could not find a 3300 microF aluminum-polymer with a higher voltage
      than 6.3 V.)
      1 - Motherboard #1 : this is an Asrock K7VT2 (socket A) that still works well. To put it on test
      I replaced capacitors with aluminum-polymer.
      3300 microF/6.3 V. x 4 replaced by 3300 microF/6.3 V. (KYOCERA...
      03-21-2025, 02:46 PM
      by sam_sam_sam
      After all of...
      07-13-2024, 08:14 PM
    • Cama
      Solar Inverter - SMH-II - 2 missing capacitors
      by Cama
      I need help to find the value of 2 missing capacitors ( C102 and C117) on my Easun SMH-II mainboard (solar hybrid inverter). I circled it in red on the close-up picture. The 2 old capacitors are completely missing, so I have no reference. Does anyone have this board and can tell me the value or make an educated guess based on the location ?
      My model is : EASUN SMH-II 7 KW
      Mother Board : P/N 18947-002401250250
      Maybe the EASUN SMH-II 4.2 KW have the same capacitors
      Thank you...
      09-12-2025, 02:50 AM
    • FrancescoV
      Onkyo HT-R390 no sound output, video output ok
      by FrancescoV
      Good morning everyone,
      I'm trying to repair an onkyo ht-r390 that has no sound output, despite the volume being at maximum, the rest seems to work; the video output signal (coming from an hdmi input) is present, but the audio is absent. Similar situation if I send an audio signal from any input I have no output.
      The firmware reported is the following:
      M:1.00/11107BLP
      D:?.??/????????
      O:1.00/11107AL
      The DSP firmware given the question marks seems corrupt.
      On the BCHDM-0678 - 25140678 - QPWBCHDM0678A0 board the chip that usually seems...
      05-11-2025, 02:59 AM
    • ctroxtell
      Samsung UN70tu7000wxza no standby light, do I have bad capacitors?
      by ctroxtell
      I picked up a 70" Samsung UN70TU7000WXZA. The original owner said they were watching it when the power surged and knocked it out. I pulled the back off the TV and disconnected the main board from the power board, and the LED backlight came on, which I was told meant the power board was good. When everything is plugged in the standby light will not come on, looking at the main board BN94-17775A with a thermal imaging gun I can see one of the chips labeled 3202 is 251 degrees F just sitting idle. I found a replacement board, BN94-16115X; this board has the same symptoms, except it is a different...
      01-03-2025, 08:57 PM
