A bag of fakes. Or Not. or what?
  • Scenic
    o.O
    • Sep 2007
    • 2640
    okay i'm a bit confused here...
    bought those caps on ebay as a bag of 100pcs.
    not really clear picture and the auction only said they are panasonics with 470uF 35V new in bag.
    (private seller who obviously didn't know much about the stuff he was selling (in general))
    i just bought them cause i was buying other stuff from that seller and he had those up as an auction.. less than 10mins left, 1eur start price, no bid.. so why not?
    got the bag today along with my other stuff, which was exactly what it's supposed to be. except those darn caps..
    those are (according to the label on the bag) Panasonic TA 35V 470uF 12.5 x 20 caps. (EEUTA1V471)
    i immediately noticed something odd about them without even looking up the datasheet.
    their sleeve is black with white (instead of the usual silver) printing, completely missing the dark red datecode. another obvious sign is that they don't have the panny T-vent, but a simple X one..
    the "electrolytic capacitor quick guide" lists panasonic TA (search in pdf for "EEUTA") as "125°C for automotive application" ... body black, marking *silver* ... hmmmmm
    there are already 2 things not matching up. the ones i have are marked 105°C and have white printing. not silver.
    the datasheet for TA lists them as 125°C too. another oddity is that on page 2, 35V 470uF 12.5 x 20 is listed as a minimum bag quantity of 200.. my bag has 100pcs..
    the rubber bungs shown on page 1 also don't match.
    oh what the hell.. a whole bag of 100 fake pannys?
    http://bambooz.pytalhost.net/badcaps...onic_TA/01.jpg
    http://bambooz.pytalhost.net/badcaps...onic_TA/02.jpg
    http://bambooz.pytalhost.net/badcaps...onic_TA/03.jpg
    now what?
    at least i didnt pay much..
  • retiredcaps
    • Apr 2010
    • 9271
    Re: A bag of fakes. Or Not. or what?
    I'm new to all the "series" of caps so I'm probably dead wrong about this, but I remember reading one post that sometimes manufacturers get OEMs to make "custom" caps with different markings, sleeves, etc?
    For example, if GE makes a 10 million widgets and they need caps, GE might want their own custom cap from an OEM for cost savings or special engineering purposes?
    Maybe you got one of these "custom" caps?
    If you received 100, maybe unravel 1 to see if there is another smaller brand cap behind that like
    http://www.instructables.com/files/d...IXT.MEDIUM.jpg
    Originally posted by Scenic
    now what?
    --- begin sig file ---
    --- end sig file ---
    • japlytic
      • Oct 2005
      • 2086
      These units are very likely to be fakes.
      From what I have seen, Panasonic (previous Matsushita) electrolytic capacitor vents have a “T” (rounded horizontal line on “T”) vent for radial units; snap-in units have a cross-like “T” vent.
      • c_hegge
        • Sep 2009
        • 5219
        I agree with japlytic. The rubber seal on the bottom also looks wrong. Compare these two pics. The one on the left is one of my Panny FJ caps. The rubber seal on it is what I see on all genuine pannies 10mm and up in diameter, whether they be FJ, FC, FM or whatever. Your cap (right) looks different to it.
        • mo000
          470uf tantalum caps replacement
          by mo000
          hi
          motherboard toshiba C50 PT10F
          i found 2 bad 470uf tantalum in cpu sircuit making short .
          but i only have 380uf tantalum can i replace them with electrolytic caps .
          05-11-2021, 10:44 AM
        • chth96
          How Can I test PWM DM0365R?
          by chth96
          Hello
          I have power adaptor(220V/input, 12V 1.2A/output) which has symptom of fluctuating output DC voltage between 11.5V-12.2V.
          So I opened its plastic case and when switched it on, I heard constant tik tik sound from inside its PCB.
          I measured DC voltage between negative and positive pin of the largest capacitor(400v 10uf) and it was measured contant 300V.
          I also measured ESR value of all capacitors and I noticed that one of capacitor(KMG 16v 470uf), which located in the secondary side, have high ESR value(10 ohm),So I replaced it with same specification NXH capacitor....
          06-18-2025, 04:14 PM
        • RukyCon
          ZUMAX Technology (Leadman Power) ZU400W (X1), Modifications & Life Test
          by RukyCon
          Hello Again, so i'm bringing back this Zumax PSU from the gutless thread and going to be doing some modifications, and also putting it into a PC i'm going to throw together out of spare parts to see how long it lasts.
          So the first thing i did was fill in the missing filtering, by replacing the cheap common mode choke with a real one and adding a 470nf X2 capacitor in the open capacitor spot, i then replaced the fake Y-class capacitors with real ones, i also swapped out the mismatched primary caps with a pair of Aishi WK 470uf 200v caps, both of which test around 520uf. I also swapped...
          04-15-2022, 11:20 PM
        • mrdevil
          Crest Smart Home Single Power Adaptor SHSPM1 (rebadged Tuya device) - bad cap causing failure, how to repair
          by mrdevil
          Wanted to share this as I couldn't find anything on the internet about this problem, so pulled one apart and found the problem myself. Years ago I bought approx 20 or so Crest Smart Home Single Power Adapter smart switches - small 240v Tuya-compatible (rebranded) smart switch devices with power monitoring, which Big W had on sale for half price. Paid $7.50 each for these, and they've been incredibly useful for turning things on and off remotely... and monitoring how much power each device uses.
          However, after about 12 months, I had a number of these stop working...
          01-08-2025, 03:19 AM
        • mitchw
          Chieftec APS-650C owners beware
          by mitchw
          My trusty old Chieftec APS-650C decided to emit a pop and some smell few weeks ago. This happened when I pressed the power on button on the case.
          Upon examination I discovered:
          - No mains fuse blown, still drawing some little current from the mains
          - TNY278PN MOSFET almost shorted (about 90 ohms drain to source)
          - Primary of the 5VSB transformer open
          - 470uF 400V TEAPO mains smoothing capacitor reading only 5nF
          I managed to repair it. First I repaired the blown transformer, the tiny wire coming out of the winding to the pin on the transformer...
          04-13-2021, 11:30 PM
