blinking power LED - help
  • RandyG
    Hi motherboard experts
    Does anybody know what it means, when upon turning on the power supply (rear switch) the mobo power LED blinks slowly?
    This is a desktop board - MSI K8NGM2-FID (aka 7207)
    I have a clone of this computer (had to recap it too) - it doesn't blink on standby (was my first thought too)
    When you switch on the case POWER SUPPLY, the motherboard power LED almost immediately starts blinking slowly. This is prior to hitting the mobo power switch. Pressing the mobo power switch makes no difference at all.
    No post, no beeps, no fans, just blinking power LED.
    Already tried swapping the power supply, cpu, and ram, replacing the bios battery, (and hitting the bios reset button a couple dozen times).
    The motherboard has 5v at this point, it doesn't appear to even try to start the power supply at all, with the mobo power on header switch.
    I recapped it a while ago. My badcaps kit was missing quite a few caps (the 470s and smaller) but they test ok with my trusty old BP esr meter.
    It was having problems powering up prior to recapping, and had a couple crappy CPU power caps.
    After recapping the computer worked perfect for 3 or 4 days , then it shut itself off with this blinking power led about 1 minute after powering up from standby one night, and has been dead ever since.
    Could the bios have scrambled itself? Could that cause this?
  • delaware74b
    • Apr 2009
    • 628
    Re: blinking power LED - help
    It's possible the BIOS is bad or the southbridge got burned from the past power supplies. I had a customer who had a similar issue with a bestec where the 5vsb went bad. I replaced the power supply and the board died a year later. My recommendation: see if the power supply will start on its own, go back and check the caps that weren't replaced when you recapped it and anything 100uf and up.
    Stupidity should be a crime, especially for drivers. I have NO patience for them.
    • kaniki
      • 514
      The power supply should not be the problem. or should i say the only if it is one at all. He already said that he switched it with a known good one. so if it is bad, then the problem is definitely more then just the power supply.
      I would check to make sure that all the solder joints are solid. also, I dont know how you solder but maybe some excess flux got under the cap and is slightly shorting the board out. I have had that happen once. It worked fine when I recapped, but then started messing up days later and would not boot, post, or anything else. I took the caps out and found that there was a little excess flux under a couple of the caps that caused the problem. I cleaned it and re-soldered the caps in and no problems since then.
      • RandyG
        the power supply doesn't turn on though. None of those caps are getting voltage yet.... all that's powered up so far is the +5vSB (and couple volts on the ATX PS_ON# pin). And something is making the LED blink... lol
        What controls the power supply PS_ON? I've been googling for that all morning.... is there a "CPU Power sequence controller" on a 939 board?
        Or does the bios have control between pressing the power button, and PS_ON ?
        I'm pretty good with electronics... I have a couple scopes, and likely anything I need to trace it out. (I do microcontroller AVR type stuff for a hobby)
        I just don't have any clue where to begin and can't seem to find any reference on the web to get me started.
        • RandyG
          It still blinks the same, even with the bios chip out - so it's not that I guess.
          I measured every electrolytic cap on the board. The only one with power on it is up by the outside edge of the pci slots... which makes sense since pci is supposed to get 5v standby power.
          • kaniki
            • 514
            I would say that it is the same on a 939 board as it is on any other board. All that turns is on is shorting out the 2 pins or wires that are down the middle of the main power supply power pack that goes to the motherboard. So it should be pretty much the same no matter the brand or model. There has to be something one the board that is not powering up right though. If you are getting the light on then that means that it is getting power and you said it is the same no matter which power supply that you try. The 12v and other voltages should not come into play until you turn or push the power button on. You could try shorting out the power line while it was attached and see what happens, but if something is really shorting out bad, then that may also fry the board if it isnt already. I wish i could help you more but that is about all i know.
            here is some info about the power supply's
            http://www.helpwithpcs.com/courses/p...nc-pinouts.htm
            • RandyG
              Thanks kaniki
              I hot-flashed the bios in the working board, just for fun... made no difference
              I did short the ps_on# pin yesterday for a second with no cpu/ram in it, and fans spun up.
              Kinda afraid of smoking stuff trying to power it up that way though
              It appears the Winbond chip controls power on / off , the PS ps_on#
              and the LEDs, including the one that's blinking. So... either it is screwed, or it's flash data is screwed, or it sees something it doesn't like and is refusing to power up the board
              • Tynan Dill
                by Tynan Dill
                Assuming...
                11-22-2024, 01:46 PM
              • shovenose
                Ubiquiti Unifi PoE Switch US-8-150W Power Supply Failure
                by shovenose
                Got this one for free because, well, it no worky.
                A little research and there are tons of complaints all over forums/the internet about premature failure of these switches. The observation everyone makes about these is "they run hot" and failure occurring as soon as 13 months, right out of warranty, of course.
                Upon removal of the cover I found a G0398-15011480A power supply that, when plugged in, was making a constant ticking noise. Multimeter confirmed the PSU was the issue. Output was cycling between 0 and about 20V. With output disconnected it sat around...
                08-11-2021, 01:26 PM
              • CMCM
                Russound CA4 Power Supply Repair
                by CMCM
                Hello Everybody,
                Trying to repair a power supply from a Russound CA4 Multizone Controller (picture attached)
                Russound no longer supports it but were kind enough to provide a schematic of the power supply (pdf attached).
                The outputs marked 12v and 20v are all measuring only 1v.
                The board is clicking, which I think means it is in something called hiccup mode when the flyback transformers switches because of an internal problem or something else on the board Overloading it.
                The capacitors physically look clean (no bludgesor leaks) and...
                Yesterday, 01:12 PM
              • Gust zhang
                Mid 2014 A1398 MacBookPro,Is it feasible to remove the battery from the MBP and connect it to an external power supply?
                by Gust zhang
                ​I have a 15 - inch Retina MacBook Pro from the mid - 2014 model. Here is the link: https://www.badcaps.net/forum/showth...light=820-3662 . The battery broke some time ago. After I removed the battery and plugged in the original power adapter, the MBP could boot up normally. However, when I checked with IntelPowerGadget, I found that the CPU speed was limited to 0.8 GHz, and it ran very slowly. Later, I found a solution on GitHub. There is an open - source project called cputune that can set the CPU running speed. So I can now run the MBP at full speed. But another problem...
                02-16-2025, 08:39 AM
              • Andreas_de
                Power supply Manson NTP-5561 (5661) LCD controller dead - PIC18F87K90 HEX dump required
                by Andreas_de
                Hello!
                i got a damaged Manson NTP-5561 (60V, 1,6A DC output) and and the main issue is that the controler IC for the LCD display has a short. The controler IC PIC18F87K90 is mounted on the back of the back of the LCD. Vss-Vdd = 3 Ohm. The 5V and 3,3V power line was killed as well, but that is not a problem. A new LDO 3,3V and 5V 7805 is already ordered.
                Replacing the PIC18F87K90 is necessary but that makes no sense without having the HEX dump of the new controler.
                Does anybody have such a power supply and could do a HEX dump of the Flash and EEPROM memory?
                04-12-2025, 10:38 AM
