How to tell a bad cap?
  • AudioGuy88
    • Jun 2020
    • 35
    I had a Sunfire True Subwoofer which was making a buzzing noise when it when it was on with no signal. It made more of a buzzing noise when it had a signal.
    I figure it was bad caps in the power supply so I replaced all the electrolytic caps. This fixed the problem and there no noise at all, so I'm very happy with the result.
    I used both a multimeter and a multi-function tester to check the old capacitors. However all of them measure well within spec.
    The caps I replaced were
    2 x 1500uf 200v
    4 x 1000uf 25v
    They all measured well within 10%, but at least one of them must be faulty. How can I find out which one is faulty?
    • 31214
    Re: How to tell a bad cap?
    you cant tell with a multimeter, you need a component tester or esr meter
      master hoarder
      • May 2008
      • 12175
      I think that's what he said he did: used both a multimeter (with capacitance function test, I presume) as well as a "multi-function tester", which I presume is what he means for those Chinesium transistor testers / component testers.
      In any case, if the caps are reading within 10% on the capacitance and ESR is good (for big caps like that, I think you should be seeing 0.10 Ohms absolute maximum), then the caps might actually be good and perhaps the buzzing issue was from a bad/cold solder joint somewhere that happened to "fix" itself when you took the subwoofer apart. Or it could be that dreaded tan/brown conductive glue (very commonly used on subwoofers), and you just happened to knock it off from wherever it may have been causing signal feedback issues due to leakage.
      Without pictures and more info, though, it's hard to say what exactly happened.
      • AudioGuy88
        • Jun 2020
        • 35
        That is correct. I am using the TC1 tester
        https://www.ebay.com/itm/263291447651
        There was the brown glue on the bottoms of the big caps. However they were only around the edge and not touching anything pins/pads.
        With the small caps I measured:
        Small caps
        905uF - 925uF 0.2 ohm ESR 1.3% Vloss
        Big caps
        1400uF 0.18 ohm ESR 0.9% Vloss
        Are those numbers enough to indicate if the caps are good or not?
          master hoarder
          • May 2008
          • 12175
          ^ Going by those numbers, the caps seem good. In particular, the capacitance is within range and V_loss is low an all of them, which means the caps aren't electrically leaking (high V_loss = high internal electrical leakage, which usually but not always goes hand-in-hand with abnormally high capacitance.) ESR seems OK overall. Perhaps a little high for the 1000 uF caps, as I imagine they should probably really be around 60-70 mOhms... but depending on the calibration of your TC1 tester, that's probably a normal reading.
          So all in all, at least I can't see anything wrong with those caps.
          It is possible that one of them may be breaking down only when in use... but highly unlikely, though.
          If you really want try this test: charge each of the above caps to about 12-15V... maybe 20V, if you dare. Then remove the power supply and short out the cap's leads with a metal object (preferably something you won't mind getting a tiny burn mark on - so don't use your fancy screwdrivers.) If the caps are remotely good, they should give out a nice spark. With 12-15V, you may not see that much at that capacitance. But at 20V, you should definitely hear a small pop and see a spark.
          BTW, also if the brown glue under the big caps was touching some other components around the caps and any of the leads of the caps, that could have been the source of the noise too, since when that glue turns brown (or dark brown / black), that's when it starts going slightly conductive. It should really be only tan in color.
          Last but not least, what brand and series were the caps?
          Another thing I can think of is perhaps on one of the big caps, one of its leads may be starting to corrode from the electrolyte inside (can happen with cheap caps sometimes.) And somehow, the cap is still working in the TC1 tester, but otherwise may have been on its way out.
          • Per Hansson
            • Jul 2005
            • 5895
            • Sweden
            A capacitor can have leakage that only shows up when it is exposed to its rated voltage.
            I repaired an old LEM amplifier that was like that: It had 4x 15000uF 80v caps.
            The unit worked fine with a 300w incandescent light bulb in series.
            But when I gave it straight mains the 10A fuses on one of the transformers secondary blew!
            I identified the bad capacitor and brought it up on my Variac: up to around 50v it was fine.
            But after that you could hear load pops inside the can, and the higher you got the worse it got...
            The failed cap tested just fine on both my "component tester" and also Keysight U1733C LCR meter at any frequency...
            Here is a nice tester for measuring leakage:
            #346: Basics of Capacitor Leakage / using the Antique Wireless Association DC Leakage Tester
            You can of course just use a bench power supply and measure the current going into the cap once the voltage stabilizes instead.
              master hoarder
              • May 2008
              • 12175
              That's very interesting.
              I've only seen this phenomenon with loose capacitors on my bench - particularly with a few old, used ones that I was trying to reform to their full rated voltage (very old Samsung caps from the 90's and some G-Luxon LZ from an ECS motherboard.) In both cases, the caps would leak a ton of current past a certain voltage, but were OK below it.
              So I guess what you're suggesting may be the most likely cause here.
                • Jul 2011
                • 6069
                This is a very interesting topic and I just bought the board to build my own but I am going to change a couple of things one I going to use a digital volt meter modules and not use an external voltage meter unless I have to but will do some testing
                I really building it so I can check main filtering capacitor on switching power supply and lower voltage output capacitors as well
                • AudioGuy88
                  • Jun 2020
                  • 35
                  Thanks everyone for their replies.
                  I don't have a scope or variac so unable to test it.
                  But I've got the answer I need. It seems in some cases testing a cap with a tester alone is not enough.
                  • stvhop
                    HP1955L Buzzing noise & interference
                    by stvhop
                    Hello, This is my first post so please forgive me if I miss out some vital info.
                    I have a problem with my HP1955L monitor from 2005.
                    The first thing to say is that it is still basically working, ie the picture is fine.
                    However it makes an electrical buzzing sound. I know all monitors make some some of hum, but this is louder and more of a buzz.
                    The volume of the noise seems to be dependent on how hard the monitor is working; switched on with a blank screen -> no sound; small dialog (like OSD only) -> minor buzzing; full screen picture -> loud buzzing.
                    11-07-2020, 07:13 AM
                    Modification done to a EBC-A40L 5volts Battery Capacity Tester 40A for less noise when charging / discharging cycles
                    When I first turned this battery testing machine the fan for the switching power supply was a little bit noisy but once I recapped the switching power supply board it quiet down considerably then I put a temperature controlled fan that does the mosfets control board was really noisy but now that it is cooled with temperature controlled fan that sensor was moved from the fan to the heat sink so now that the fan is controlled this way the fan runs according to the temperature of the heat sink
                    This switching power supply was really fun to recap the quality of the board was very good...
                    02-25-2024, 08:55 PM
                  • Orion Bardier Skylar
                    Adding Bluetooth module to Woofer buzzing noise
                    by Orion Bardier Skylar
                    Hi, I got this Woofer,Name TBT, which damaged its Radio module, then was added a Bluetooth module from the market(history from client). Then recently was brought to me with very low sound and heating problem. I changed subwoofer Speaker which had impedance of 1.2 instead of 4ohms rms and the bass ic KA2206B. Sound is back but buzzing and hissing sound present even when muted. How can I get rid of it?
                    03-06-2024, 02:35 PM
                  • tony359
                    by tony359
                    11-28-2023, 05:18 AM
                  • MegaZAC
                    Onkyo TX-SR805 noise in one channel
                    by MegaZAC
                    Surprisingly enough, this receiver doesn't have the DSP chip issue. The HDMI board does not get hot, and sound over HDMI works fine.
                    Regardless of the input, the right channel has noise that is clearly noticeable even on average volume level. The only cases when there's no noise is when VCR input is selected (some tracks on the board are damaged, maybe that's why), or if HDMI input is selected but nothing plugged into it. In all other cases, even when no input is connected I still have the noise.
                    There's some logic behind it. As soon as I select an input I get only left...
                    04-23-2025, 10:09 PM
