Ost
  • Berne
    • 13
    Ost
    Im considering a power supply from Corasir which has Hitachi and OST caps, what sort of rep do they have?
    Berne
  • 370forlife
    Large Marge
    • Aug 2008
    • 3112
    Re: Ost
    Sounds like a CX400. As long as they are adequately cooled OST can do fine in a psu.
    Hitachi is known good.
    • Berne
      • 13
      Re: Ost
      Yes correct first time the CX400, Imnew to this what should I do to ensure adequate cooling? I attempted my first recap of my 2004 machine with Panasonic Caps and fingers crossed two months later the pc runs better than it ever did.
      This led me to search the net for power supplies which use Panasonic Caps but it came up blank ( any ideas )? , lastly do pc buffs build their own supplies and what kind of money would a 500W cost to build....Im assuming you can buy the board and screw it to a prebuilt metal box , wire up the cables ( could be techy ) and thats it?
      Again when time permits, and oh, appreciate the quick reply.
      Berne
      • 370forlife
        Large Marge
        • Aug 2008
        • 3112
        Re: Ost
        Power supplies are usually designed by college graduate electrical engineers. Pretty complex things.
        The corsair adequately cools itself. There is not much in the way of the caps and fan, so plenty of air moves over them.
        I don't know of many or any psu manufactures that use Panasonic (other than lite-on). Basically all corsairs except the CX400 use UCC.
        • Berne
          • 13
          Re: Ost
          Hi 370forlife,
          I think its good value the CX and my sys is quite small only requires 250W maxed out, so I got upgrade power if required. I saw some 40$ supplies and thought wow Ill go there but a little further reading has I think paid off.
          Many thanks for your replies and I wish you good luck.
          Bernard ( in Ireland )
          • Agent24
            I see dead caps
            • Oct 2007
            • 5038
            • New Zealand
            Re: Ost
            I have a Corsair 400CX powering a Socket 754 Sempron 2800+ with Radeon 9600XT
            Works fine and the system doesn't randomly lock up any more as it did with the old PSU...
            -David VanHorn
            • c_hegge
              • Sep 2009
              • 5219
              Re: Ost
              Although they can be OK in PSUs if adequately cooled, on motherboards they are Only Some Trash
              • Scenic
                o.O
                • Sep 2007
                • 2642
                Re: Ost
                ^ indeed.
                the OSTs in my Antec Neopower/NeoHE 430W (Seasonic OEM) are still perfectly fine after nearly 2years daily use powering my overclocked Core 2 Quad.
                allthough i'm probably going to replace them the next time i open it up to clean it..i mean.. i'm in there anyways.. so why not? better safe than sorry
                • mockingbird
                  • Dec 2008
                  • 5484
                  Re: Ost
                  I have had far more success with OST in PSUs than with Teapo.
                  • seanc
                    • Nov 2008
                    • 1319
                    Re: Ost
                    Meh, I rip them out and replace with Panasonic.
                    Had them fail in two Antec PSUs, so the third is being done for the hell of it.
                    • Jaime Morillo
                      Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
                      by Jaime Morillo
                      Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
                      The TV was stuck on the logo and I couldn't access the update menu.
                      I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
                      The image result was good, but the image is inverted.
                      The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
                      Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
                      08-18-2025, 11:38 AM
                    • wolf1976
                      hitachi 50hk5600 problem with display
                      by wolf1976
                      hi
                      i have the above tv and the display starts distorts the display at only in applications like you tube
                      after and on the didital channels
                      now without connect the antenna only the image of itsselfs tv i have the image i have in attach
                      i have read in another forum someone else with similar problem with mine changes tcon card and motherboard and the problem remains
                      can you tell me someone what is the reason that can causes that problem ? is the same the sisplay ?...
                      09-13-2025, 02:26 PM
                    • massimomax
                      Firmware TV Hitachi 32HE4500 scheda madre Vestel 17MB211S matrice: VES315UNVL-2D-N11
                      by massimomax
                      Chiedo aiuto per problema a TV Hitachi 32HE4500 che non si accende più,ho bisogno del firmware della scheda madre vestel 17MB211S codice pannello VES315UNVL-2D-N11 ?
                      spero che qualcuno può averlo per riprogrammare eprom. grazie
                      Post in English !!!
                      I ask for help with a problem with a Hitachi 32HE4500 TV that no longer turns on, do I need the firmware for the Vestel 17MB211S motherboard, panel code VES315UNVL-2D-N11? I hope someone can have it to reprogram eprom. Thank you
                      02-28-2025, 07:27 AM
                    • dragometin
                      Hitachi 40HYC42
                      by dragometin
                      TV Model: Hitachi 40HYC42
                      Power Supply: 17IPS71
                      MainBoard: 17MB95M
                      Panel: VES400UNDS-2D-NO3
                      When the set came in it was dead. Fuse was open primary side and the power mosfet was shorted. So I ordered a new power supply. Now it turns on, only displays "Hitachi" and then power off red and blue led flashing.
                      I had to modify the 0ohm resistors in the led backlight of the new PS like the original power supply.
                      Is there any variants on 17IPS71 power supply's?
                      UART output pins 10 and 12 on scart connector:
                      Code:
                      12:24:04.595
                      08-08-2024, 05:53 AM
                    • sotodefonk
                      Help finding the correct model of a T-Con board on my Hitachi TV
                      by sotodefonk
                      Hi, I have a Hitachi tv model L47V651, there is no image, but sound and backlights turn on, so I believe the issue is the tcon board.
                      I opened the tv to access the board and took the shared pictures of the T-Con board.
                      I saw a video from shopjimmy on how to detect the model number on tcon boards, but this doesn't have a sticker like how that video showed all boards.
                      I searched the P/N number and got results with the same marking name and P/N my board has but they list other specific tv models like Vizio and Philips brand but not Hitachi.
                      Inspecting...
                      06-28-2024, 04:39 PM
