Jetway V6DP
  • Alex Atkin UK
    • Sep 2005
    • 23
    Jetway V6DP
    Heres another board I have, I got this off e-bay so when I found this site I had the sudden inclination to check the caps. Im not sure about the ones next to the CPU socket, are they raising a little or do they normally look like that?
  • AK0R
    • Mar 2005
    • 204
    Re: Jetway V6DP
    Typical GSC crap. If you value your board and/or your data, recap it prior to returning it to service.
    • Rainbow
      • Aug 2005
      • 1375
      Re: Jetway V6DP
      They look OK on the photos. But they might not remain OK after a year of use (or 2 years or 6 months - nobody knows).
      • willawake
        Super Modulator
        • Nov 2003
        • 8457
        • Greece
        Re: Jetway V6DP
        no they dont look ok. some caps are starting preliminary bulges around the vents. it may take a while they will be puking orange in the future and the board will be unstable. better to recap soon and enjoy the board how the designers wished it had become.
        • Alex Atkin UK
          • Sep 2005
          • 23
          Re: Jetway V6DP
          Thanks all, it confirms what I feared - that the CPU ones are bulging a little and I can't expect any better from the others either. Fortunately those photos show the majority of the caps so its not too many to replace, though I certainly do not find the prospect appealing none the less.
          I will have to get the board out and check the values on those caps then pay a friendly visit to rswww.com, unless anyone knows of a better place in the UK for them. Id see if I could pull some off another board but I wouldnt know if they were any better.
          • RJARRRPCGP
            • Jul 2004
            • 6304
            Re: Jetway V6DP
            Even Topcat may disagree with that!! Because if you see what appears to be little bulges around the seems and not in the middle, then that might be just the cap manufacturing process!
            ASRock B550 PG Velocita
            Ryzen 9 "Vermeer" 5900X
            Arc A770 16 GB
            eVGA Supernova G3 750W
            Alienware AW3423DWF OLED
            • Fatal0E
              • Jan 2004
              • 252
              Re: Jetway V6DP
              well they need replaced anyway, bulging or not.
              • PeteS in CA
                • Aug 2005
                • 3581
                • USA, Unsure of Planet
                Re: Jetway V6DP
                The bulging is equivocal. I've seen that kind of bulging on some brand new, name brand, caps. And I've seen it be the initial bulging in caps I've been torturing, caps that eventually vented.
                If they're a brand that tends to fail, replacement now might save headaches later. There must be a Johnny Cochrane-esque quip in that: "If the caps a crap, they're going to zap."
                PeteS in CA
