Blown PSU
  • spleenharvester
    • Mar 2010
    • 919
    Blown PSU
    I have a blown X-Power GTX Light 580w PSU.
    Basically, it's about 1.5yrs old. I was playing L4D, went for tea, came back and it smelt of burning/something melting. I tried to pull out of L4D to check voltages but it switched off before I could open speedfan.
    Now, it will not start at all if the graphics card power is plugged in. If the GFX power is unplugged it starts and my basic diagnostic card shows all voltages as OK and the PC as POSTing fine but obviously I cannot check.
    Does this sound like a cap issue to anyone?
    I can't check all of them but they all look absolutely fine to me.
    The big 200v capacitors are Capxon built, which I understand to be awful.
    Cheers
    Dell E7450 | i5-5300U | 16GB DDR3 | 256GB SSD
  • etnietering
    • Apr 2009
    • 379
    Re: Blown PSU
    The burning/melting smell would indicate to me that something other than the caps blew, or at least got way too hot. Check all of the ICs and the power transistors/diode packs (the things attached to the heatsinks) for signs of damage/overheating. Take some pictures, too, and post them here, so we can help you try to find the problem.
    Also, try not to run your system with it in this state - if the voltages aren't regulated properly it could seriously ruin the rest of your hardware.
    Good luck!
    • spleenharvester
      • Mar 2010
      • 919
      Re: Blown PSU
      How long do you recommend I wait for before opening it up?
      I.E how long do I have to wait to guarantee not getting shocked?
      I can wait weeks, months even, I'm in no rush
      • etnietering
        • Apr 2009
        • 379
        Re: Blown PSU
        Well if it's designed properly, you should only have to wait a few minutes. However, if it was designed properly, it would have turned off before melting....so I'd wait at least half an hour. The only place with enough voltage to hurt you is the primary side, so if you're still uneasy you can stay away from that for a while longer.
          • 31213
          Re: Blown PSU
          lesson1:
          if you smell burning or see smoke, dont try to logout or run diagnostics.
          PULL THE PLUG!
            • 31213
            Re: Blown PSU
            and examine your gfx card - incase it's that.
            • PCBONEZ
              Grumpy Old Fart
              • Aug 2005
              • 10661
              Re: Blown PSU
              Yes it sounds like caps -could- be it.
              Crap caps will cause other parts to burn-up, but so will other faults.
              The 'beer can' caps rarely go bad or cause problems regardless of who makes them.
              It's the 6 thru 13 mm caps you need to look at first.
              Mann-Made Global Warming.
              - Dr Seuss
              • spleenharvester
                • Mar 2010
                • 919
                Re: Blown PSU
                It ain't the card, pretty sure of that.
                Basically, what happened: we had a pretty bad surge, my PSU melted, my brother's SXS400w actually caught fire ( ), both laptops were plugged in so they died, and we've lost the oven and TV as well.
                The only thing I found on the card was some small, burnt-looking brown stuff behind one of the MOSFETs, but I think that's the stuff they put on at manufacture (my 6600gt has similar stuff)
                I'm going to leave it a few days before opening. I can see in atm (fan grill is off) and every capacitor within my site looks A-OK. What should I look for?
                Also, the smell's coming from the back of the PSU, near the transformers and some other stuff I can't see.
                **Also - I didn't think much of it at first because I've had similar smells before when it's under load. Kind of like the ones you get off a new PSU sometimes, just a bit stronger. Then I realised "hang on, something's wrong here", and it went off seconds later.
                  • 31213
                  Re: Blown PSU
                  open it, you cant get a shock just removing the cover.
                  • kc8adu
                    • Nov 2003
                    • 8832
                    • U.S.A!
                    Re: Blown PSU
                    if its the x-power i have seen it belongs in the trash anyway.hope it didnt kill anything when it died.
                    found one in a customers tool grinder.it overshot and killed the sbc.i/o,motion control,and probe interface.
                    i guess cash was tight and they guessed the original psu was bad.they bought the cheapest thing they could rather than calling me out to fix it.it bit em in the ass bigtime!
                    • spleenharvester
                      • Mar 2010
                      • 919
                      Re: Blown PSU
                      The Lite series has served me well but the others are truly awful.
                      This one was 1.5yrs before it got surged, was under heavy load regularly.
                      Anyhow: I opened it up, and the transformer near that back part is pretty badly melted. Didn't look salvageable so I just pulled the fan and soldered it to a 3pin connector
                      Cheers for the help people.
                      • spleenharvester
                        • Mar 2010
                        • 919
                        Re: Blown PSU
                        ...And it continues, with the new PSU.
                        Won't boot with card power plugged in. Will boot and card powers with power taken out, but the card beeps and won't display (obvs)
                        Basically, can't take a pic atm though, the MOSFET I mentioned has brown crap at the solder joint at the back, and it also has a random ball of solder stuck to it... reckon that's the one? ~EDIT: Just found another MOSFET further up with the same kinda shit over it, there's less of it though. You know how there's like a straight edge on the opposite side to the joints? On BOTH the MOSFETs I've mentioned they're both all rickety and messed up.
                        What should I be looking for? Maybe the solid state 16v caps need replacing? They do seem a bit bulgy.
                        • spleenharvester
                          • Mar 2010
                          • 919
                          Re: Blown PSU
                          http://forums.overclockers.com.au/sh...php?p=11586520
                          WTF? My card layout is the same, and it's the exact same MOSFET model that has blown. The two he shows in the picture, except mine has more brown gunk.
                            • 31213
                            Re: Blown PSU
                            the brown is just flux,
                            but you are describing symptoms of a shorted fet on the gfx card.
                              Acer Aspire A315-54K-580W Notebook 3 Specification for Upgrade or Repair
                              This specification for the Acer Aspire A315-54K-580W Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the A315-54K-580W boardview and A315-54K-580W schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                              09-06-2024, 12:18 PM
                            • cmlewis89
                              LG 47LB5DF blown power supply board
                              by cmlewis89
                              Hi folks,
                              I'm new to this forum. So my trusty 17-year-old LG 47" LCD recently died. As I was booting it up, I heard a hum followed by a loud bang, sounds of pieces flying around, and loss of power to the unit. Inspecting the PSU, I saw two obvious problems: a blown thermistor (bang + flung pieces) and a visibly bulging main cap. Inspecting as many components as I could with my Fluke MM, I diagnosed that the following components on the "hot side" of the board were also bad: one of the 2 main MOSFETs, main 8A fuse, small cap (25V 47uF) connected to main caps, and a blown...
                              09-03-2024, 07:50 PM
                            • drscoot
                              HP X360 convertible battery blown fuse error, not charging
                              by drscoot
                              HP Modelnumber: 14-dh0061nb​
                              This laptop had a shorted cap on a Vcore section. After replacement is works again. But there is still a battery issue.
                              The battery is HT03XL and with the built-in component test from HP, in the Power section, I get an error: Logic State: Calibration required (20), Charge state: Blown Fuse (42)
                              I have another same battery, also with error: Logic State: Very Weak (70), Charge state: Blown Fuse (42)
                              And a third battery TF03XL (looks identical) with error: Logic State: OK (0), Charge state: Blown Fuse (42)
                              All these 3 batteries are charging...
                              12-15-2023, 05:54 AM
                            • swerg
                              Part selection for possible blown inductor on ASUS GX531-GW-AB76 laptop mobo
                              by swerg
                              Hey everyone,
                              I'm a novice trying to repair my laptop. The LCD screen has an image, but no LED backlight for the image. It also produces an image when connected to an external monitor.
                              I have found what I believe to be a blown inductor labeled "L4502" and "120 Ohm" in the schematics (zoomed in image, blue arrow to blown component). I have included an image of the general area of the mobo and an excerpt from the schematics as well.
                              I am having trouble selecting a replacement component, which I believe to be a 120 Ohm ferrite bead, from the components...
                              06-06-2024, 03:39 PM
                            • MrzPdlch
                              Blown fuses on Gigabyte GTX 980TI 6GB
                              by MrzPdlch
                              Hey everyone,
                              I just went ahead and unscrewed a faulty GTX 980 TI from Gigabyte. What I found beneath the cooler was, as it seems, a common issue of that card. Two blown fuses on the bottom right corner of the card next to a MOSFET.
                              Now my question would be if there is any schematics of that card available to figure out which are the blown components so I can try and replace them together with the mosfet if needed.
                              Find some pictures of the actual GPU together with a picture of how it should look like.
                              I also wonder whther it might be a problem that there...
                              03-10-2024, 04:14 PM
