Should I recap Bestec?
  • Oerg866
    • Nov 2009
    • 61
    Hi. I have bought a HP PC in 2007 and since then I had thrown out board, CPU, graphics, etc.
    Right now the only thing in it that's from the original setup are the case and the PSU.
    The PSU is a Bestec and to be honest I had not experienced any trouble with that thing as the computer runs fine and I do tons of LAN gaming with it.
    Should I look in it though and recap it or is it not such an emergency?
    Cheers
  • c_hegge
    • Sep 2009
    • 5219
    Re: Should I recap Bestec?
    Depends on the model. If it is an ATX-250-12E, dump it as that model has flaws in its 5vsb rail which cause it to overshoot 5 Volts after a few years use and fry the motherboard. If it's an ATX-___-12Z, it will be fine after a re-cap.
    • Oerg866
      • Nov 2009
      • 61
      Thank you. I opened that bastard up and saw CapXon and Teapo. Enough reason for me to change them
      • Oerg866
        • Nov 2009
        • 61
        Can I use 1500uF instead of 1000uF on one cap?
        Can I use 6.3V Rubycon MBZ instead of 10V 2200uF CapXon/TEAPO?
        • POM_MJ
          • Aug 2009
          • 228
          Yes, I've done that on my bestec atx-300-12z => https://www.badcaps.net/forum/showpo...0&postcount=42
          good result.
          | AMD Phenom II X2 550BE | GIGABYTE GA-MA790FXT-UD5P | GeIL DDR3 Ultra 2x2GB 1600C7 |
          | XFX GTS250 DDR3 512MB | Dell H525EF-00 | Lancool PC-K62 Black | Samsung 2232GW |
          | 2xWD7500AYYS | 2xHD322GJ Raid0 |
          • Oerg866
            • Nov 2009
            • 61
            very good
            • Oerg866
              • Nov 2009
              • 61
              Alright, I did that and plugged it in (from good 5 meters distance s nothing explodes into my face X) - success for now the green light came on and now I have to test it. Hopefully it will work
              • POM_MJ
                • Aug 2009
                • 228
                Glad for that , I'd like to see a pic after recaps.
                • Oerg866
                  • Nov 2009
                  • 61
                  Yay it works
                  You'll get pics tomorrow because I don't feel like opening the thing again right now =P
                  It pretty much looks like your recap though
                    ASUS P5GC-MX motherboard recap
                    by momaka
                    Here’s another motherboard that needed a full recap: an ASUS P5GC-MX.
                    This one was gifted to me some years ago by user Pentium 4, along with a few other goodies. It actually came in working order with no bulging or leaking caps. However, I noted there were United Chemicon KZG caps everywhere on the motherboard. The CPU VRM output (CPU V_core) was the only exception: it had only 2x KZG. The rest was 6x UCC TMV 4V 680 uF caps… which aren’t any good news either.
                    So here is what the motherboard looked like with its original caps:
                    CPU VRM area up close…...
                    01-27-2021, 11:59 PM
                  • varunviolin007
                    Looking for someone to recap Dell XPS T450 motherboard (Live in suburbs outside of Philly)
                    by varunviolin007
                    Hi guys,
                    I’m looking for someone in the Northeast to do a full electrolytic capacitor recap on a working Dell Dimension XPS T450 motherboard (it's an Intel 440BX, Slot 1). The board runs mostly fine but is beginning to freeze after warm reboots (turns back on for 30 secs or so and then freezes up but is perfectly fine after 12 hr cool down).
                    I’d be sending just the bare motherboard (CPU, cards, bracket, battery all removed). I’m located in Chadds Ford, PA and happy to ship within the US.
                    Looking for someone experienced with older PC boards who uses...
                    07-29-2025, 11:53 PM
                  • Foetuss
                    Recap motherboards :: Abit KG7-LITE and Soltek SL-75FRN2-L
                    by Foetuss
                    Hi all
                    Hope this is in the correct place.
                    I'm planning on recapping both motherboards. I actually already ordered recplament caps for them, where I will be changing out most for poly's.
                    Could use some double checking to see if I'm not doing something stupid .
                    Pictures of the boards are attached.
                    What I will be replacing with what : (planned)
                    Soltek Golden ::
                    4 1500µF 16V 10mm (5mmL) KZG => APSG160ELL152MJ16S (Chemi-Con 1500µF 16V)
                    6 3300µF 6.3V 10mm (5mmL) KZG => APSG160ELL272MJ20S (Chemi-Con 2700µF 16V)...
                    01-18-2025, 11:44 AM
                  • goodpsusearch
                    Got 4 LG L222WS 22" for free - psu recap
                    by goodpsusearch
                    Got 4 CCFL 16/10 monitors for free.
                    The resolution is almost Full HD (1680x1050)
                    VGA Input only is a bummer though.
                    Uses cheap TN panel with terrible viewing angles.
                    Even though this is not 17" 5:4 screen, still has very low resell value here. Can be found for 15-20 euros.
                    All the 4 monitors were not working and needed psu recap. Used mix of mediocre / junk caps to recap them, then donated 3 of them to friends/relatives and kept 1 for myself. Also like to install extra caps on empty spaces to help them last longer.
                    01-15-2022, 05:36 PM
                  • DrDos
                    Kenwood KR-6030 vintage stereo ,Old Man Trying to Save a Buck
                    by DrDos
                    Hello all. I'll try to keep this short. I have no knowledge of electronics. I can use a multimeter and am familiar with caps to some extent. I bought a Kenwood KR-6030 vintage stereo. It need work and so I thought I would recap the thing since I get power to the on switch but nothing else is working. No lights, no sound and so forth. I went to Mouser to order caps and I find I am way over my head. I not only do not know the type of capacitors I need but Mouser and digikey do not accept Kenwood part numbers. I have the info such as 220uF 63v and such but no place to put it. I could buy a recap...
                    08-08-2025, 03:16 AM
