Do capacitors have maximum allowed amps rating?
  • LearningToRepair
    • Jul 2020
    • 35
    Hi!
    I am interested to know what happens to capacitors when too much load is applied? Do they only pop on overvolt or also on over load?
    In SMPS caps are in parallel in order to get rid of ripple. If I exceed capacitors supply ability will I only get tons of ripple or will they also explode at the some point? And is there way to calculate max allowed amps for capacitor if I know actual volts, allowed max volts and capacitance? And also is there some rule that for example if I got this power supply from china then calculated maximum load should be divided by 3 to be safe for example?
    Also do you have experiences, how reliable are chinese power supplies? They advertise it as LED power supply but LED lighting is something that during winter period could easily be powered 10+ hours in a row and I am curious if anyone have experience with long time use of chinese power supplies?
    Some time ago I managed to pop chinese step up converter (I think I connected it in reverse polarity but I dont remember exactly anymore). And that pop was so loud that it was anything but fun. And now I am scared of every single power supply I see lol :P
    • 31288
    Re: Do capacitors have maximum allowed amps rating?
    if the ripple exeeds the cap rating you just wont get smooth power - you wont blow it up.
    chinese psu's are very varied.
    some are good, some are..... well lets say shit would be putting it lightly!!!
    https://www.youtube.com/channel/UCQa...B_Kd54g/videos
    • LearningToRepair
      • Jul 2020
      • 35
      Thanks for info. Can I tell good psus from bad somehow? Like if I open it will there be any visual indicators? I mean if it visually looks bad then it is very likely bad but can I assume that if it visually looks well done then it is good one?
      Also one more question: How much do capacitors need cooling? I want to modify fan to have 0 RPM mode if it is not hot enough. If that modification goes wrong would capacitors be one of the first things to pop or one of the last things to pop?
      PS I have occasionally watched this YT channel. Haven't seen stuff to blow up there but 240V AV between iPhone case and ground was fun.
      • petehall347
        • Jan 2015
        • 4450
        they have max temp on them for rated hours ..the cooler they are kept the longer they last
          • 31288
          there is no magic temperature, the higher it is - the lower the life.
          it's not a good idea to have fans switching up and down - find a good fixed speed.
          • LearningToRepair
            • Jul 2020
            • 35
            Thought I would ask - if I want powersupply for livingroom LED lighting setup and I want more power than those typical fanless supplies would give and I cant place that supply in an other room, what would be good options? One is rebuild case from scratch and have large fans with low RPM. Any alternatives to that?
            • PeteS in CA
              • Aug 2005
              • 3583
              • USA, Unsure of Planet
              In good quality electrolytics the ripple current rating is what the manufacturer guarantees the parts can do in the specified conditions for at least the specified number of hours. IRL, good quality parts may last much longer.
              At Curtis Instruments, 2005-2009, my job included torture-testing electrolytic capacitors to see how long they would last under really extreme conditions. My test consisted of running ripple current through tested parts that was 8X-10X the parts' ratings for 22 hours a day. During the remaining 2 hours I let the parts cool to room temperature and measured the parts' capacitance and impedance (to track accumulating damage), and then restarted the torture. The test bore some relationship to real life usage but was still extreme compared to real life.
              The really good parts would go for hundreds of hours, up to around 2000 hours, before venting or the impedance going way high. Crap caps sometimes vented within 24 hours and almost always in less than 100 hours. (BTW, United Chemicon KZG series parts did very poorly)
              So, yeah, there is an insanely high value of ripple current that will quickly cause an electrolytic capacitor to vent dramatically, but real life applications probably are not capable of sourcing that much ripple current. A misapplied or low quality part will "just" have a relatively short lifetime, and might or might not vent a little bit of electrolyte on the top of the can.
              PeteS in CA
              • @udiophile99
                • Mar 2021
                • 14
                Originally posted by LearningToRepair
                Hi!
                If you apply too much load, let's say you will have to forget about the smooth power. However, nothing will be damaged.
                  master hoarder
                  • May 2008
                  • 12175
                  Need more specifics into which power supply (or supplies) you're considering.
                  A lot of things are made in China - good stuff, cheap/mediorce stuff, and total garbage too. With "no-name" brands, though, the chance of getting that is somewhere between mediocre and garbage is really high.
                  Well, if you mistreat or connect electronics improperly, there's always a chance it will pop/smoke, no matter if it's a good brand or a bad one. Of course, the better built stuff might stand a little more abuse or for longer... but in the end, you also need to do your part to make sure you connect things correctly too.
                  • jayjr1105
                    • 281
                    So ripple current handling, is that the amount of amperage in the ripple the capacitor can handle or the amperage in general? Was always confused by this spec
                    Ryzen 3600x
                    16GB Patriot 3600MHz
                    MSI B450 Gaming Plus
                    MSI Air Boost Vega 56
                    Acer 32" 1440P Freesync
                    Rosewill Capstone 750W
                    Hakko FX-888D Station
                    FX-8802 Iron
                    MG Chem .8mm 63/37 RA 2.2%
                    • PeteS in CA
                      • Aug 2005
                      • 3583
                      The rated ripple current is the AC current the capacitor can handle at rated voltage and temperature and still have a life at least as long as its life rating. 10X the rated ripple current could be passed through a capacitor, but either a lead will open up like a fuse or it will have a much shorter life.
                      PeteS in CA
                      • dragon3x
                        by dragon3x
                        power on.
                        Here are some examples :
                        switching supply area).
                        than 6.3 V.)
                        03-21-2025, 02:46 PM
                      • Agent24
                        Dick Smith Q-1760 linear power supply filter capacitor question
                        by Agent24
                        I have acquired a used Dick Smith Q-1760 power supply - although the OEM is Manson Industrial
                        It has at least one problem.
                        The voltage control potentiometer VR2, 50K is faulty - going high resistance / open circuit in the CCW end and leading to the output voltage jumping around.
                        I have already ordered a replacement potentiometer, so that's not an issue.
                        Now, I want to replace all three electrolytics on the PCB as they are CapXon and I don't trust them so much, I will replace them with something better while I've got the thing apart anyway.
                        All are CapXon...
                        10-21-2025, 05:39 PM
                      • slybunda
                        AA and AAA battery charger capacitors?
                        by slybunda
                        hey all, iv got my favourite battery charger here which iv had for many years probably 15 years now or maybe even more. it still works good but thought id open it up to clean the dust out of it, lots of dust inside but now its clean and noticed 4 capacitors inside it and wondered if i should replace them.
                        it has inside:
                        2 x 47uf 16v caps 105c branded as Su'scon (lol sounds sus to me)
                        2 x 470uf 16v LZ105c branded as G.Luxon
                        not heard of these brands are they any good?
                        iv attached photos of the charger and the board inside for an idea on the type of...
                        12-24-2023, 04:41 AM
                      • Benchaton
                        No Power : Acer Swift 7 Pro (Board model ZDL)
                        by Benchaton
                        Problem : When plugged into power the laptop shows no signs of life but a small periodic tick noise, no battery charging indicator.
                        Observations :
                        - The laptop makes a tick sound at regular intervals when plugged in via the charger.
                        - The laptop negociates with the Power Delivery charger to 20V as expected but shuts back down to 0 then 5 at regular intervals (same as ticking noise)
                        - 4 Ceramic capacitors have 1 Ohm resistance to ground on both poles (Anotated on the pictures)
                        - After removal of the Battery Charging IC short is still...
                        10-05-2025, 09:48 AM
                        After all of...
                        07-13-2024, 08:14 PM
