Bad Smell from New Monitor
  • Duff Man
    Oh yeah!
    Hi everyone, first of all thanks to the site owner(s)/admin(s) for an excellent resource on electronic components.
    I have a brand new Samsung 2494SW now torn apart on my kitchen table that performs damn well with no obvious issues - other than a hot electrical component smell that gives me a righteous headache. It's not overpowering, but it's enough to make me want to return it, because apparently I'm quite sensitive to it. I've smelled the same odor coming from a prior Acer monitor that I returned (way more malodorous), and a couple CFLs. I can smell a faint odor similar to this in my philips tv and a samsung lcd at work if I put my nose right up to the vents.
    So after taking it apart, I've sniffed out the components that stink. It's definitely strongest near the medium-large sized caps and the transformer. I see no visible signs of defect. No bulging, leaking, stains, or dry joints. The caps are Samwha brand, and from what I've gathered they're the WB model.
    I guess I'm looking for guidance on the issue. Is it possible for caps to be bad and not show any signs other than odor? Any tips/insight would be tremendously appreciated.
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    Re: Bad Smell from New Monitor
    not unusual for new electronics to outgas a while.
    like "new car smell".
    if nothing is getting too hot i wold not worry about it.some pcb materals smell forever.have a panasonic rf-b600 sw reciever in the shop that has a distinctive phenolic pcb odor.its 30+ years old.
    • mockingbird
      • Dec 2008
      • 5484
      What kind of capacitors is that thing using?
      • Topcat
        The Boss Stooge
        • Oct 2003
        • 16956
        I remember the first time I used my Samsung color laser printer. It stunk up the whole house. After that, it was fine.
        <--- Badcaps.net Founder
        Badcaps.net Services:
        Motherboard Repair Services
        http://folding.stanford.edu/
        Team : 49813
        Join in!!
        Team Stats
        • Krankshaft
          • Jan 2007
          • 2328
          Yeah my Samsung Syncmaster 17" LCD I bought in 03 smelled like that too.
          I agree it's new car smell it eventually faded to almost unnoticeable and then I guess a year or two later disappeared completely.
          The components (mostly the heatsinks) are heating and natural convection is occurring (cool air is being drawn in at one vent and hot air is being expelled out the other) and the air is expelling that smell along with it.
          I agree though there are some PCBs that stink for life. I don't think it's the components (they don't have enough surface area) probably the PCB material, silkscreen ink, or the clear solder mask.
          A few cheap Chinese wall warts I opened had PCBs that stunk from a distance when opened like some type of salt solution almost as strong as ocean water to my nose.
          If you really can't deal with it until it passes return it.
          I'm sure the guys at the store will be giving you weird looks when you're sniffing the floor models though .
            • 31011
            your probably actually smelling chemicals being released from the plastic casing.
              by momaka
              03-15-2023, 10:17 PM
            • wattage
              by wattage
              Hello Badcaps Community,
              07-13-2025, 04:41 PM
            • ant3202
              HP 27es - LED monitor - Monitor Flashing On - Off
              by ant3202
              Hi Everyone
              Lately I am experiencing the deja-vu incident on one of the led monitor like this.
              https://www.badcaps.net/forum/troubl...lashing-on-off
              The monitor is HP 27es LED Monitor
              https://h30434.www3.hp.com/t5/Deskto...e/td-p/6804692
              The monitor will randomly blackout and display no signal and will recover again.
              Sometimes need to power and off again to restore the display but...
              03-20-2025, 07:30 PM
            • Rick_1234
              by Rick_1234
              Good evening, gentlemen.
              Things I tried
              06-22-2024, 04:44 PM
              Wise Wing F199 19'' LCD monitor - recapped
              by momaka
              Looking through my repair pictures and notes, it's been a long time since I posted anything in the LCD monitors section. So here goes that.
              I'm dedicating this thread to one of the very first LCD monitors I repaired (if not the first one), which was more than 10 years ago now. The monitor is a Wise Wing, model F199. It's a 19” CFL-backlit LCD. I got it for free off of Craigslist in 2009 from a guy, who said he bought it for cheap from Wallmart and the monitor worked only for a little less than 2 years before quitting.
              When I saw the Craigslist post, I wasn't...
              08-24-2020, 10:58 AM
