Sorry for dumb question. Capacitor size.
  • DixiePenguin
    • Mar 2008
    • 77
    • Philippines
    I have new 680uf 6.3v capacitors. The problem is they are larger in physical size than what I had ordered. Can they still be used if I can fit them in? If i need to leave them raised slightly will it cause problems? Thanks!
  • ChaosLegionnaire
    HC Overclocker
    • Jul 2012
    • 3266
    • Singapore
    Re: Sorry for dumb question. Capacitor size.
    if the caps are used in a buck regulator like for the cpu vrm, raising it slightly will increase the esr which may not be good. raising it can also cause interference issues with the cpu heatsink if the increased height violates the processor keep out zone.
      master hoarder
      • May 2008
      • 12175
      • Bulgaria
      Usually yes.
      Raised how far?
      A few mm (5-6 mm max) off the board is generally not an issue. If you need to raise them more, it will depend on the circuit. As Chaos noted above, if the caps are used around a high-frequency voltage regulator circuit (such as caps around the CPU on a motherboard), then it's best to keep the caps as close to the PCB as possible. Other areas on the motherboard usually aren't as sensitive. And on an ATX PSUs, up to 10 mm off the PCB will still be OK (though, again, if the caps are closer to the PCB, they will be more effective and there will also be less electrical noise due to shorter leads.)
      Now if the caps are used in a low-frequency circuit or as general filters for a linear voltage regulator, you can raise them pretty far off the PCB and they will still work fine.
      • DixiePenguin
        • Mar 2008
        • 77
        • Philippines
        Thanks for the info, I appreciate it. They would not be very elevated, probably less than 3mm. On a follow-up note. I have a Sniper A88X board with two bad polymers 560uf 6.3v. Would it be safe to use the 680uf 6.3v caps to replace them? I ask because anything I order ships from the States at very high standard charge. A lot of 10 caps cost under 300 php (Philippine piso) ship at a cost of 800 php. (That is $6 dollars worth of caps cost $17 dollars in shipping)
        Have a good one,
        Bill
          master hoarder
          • May 2008
          • 12175
          • Bulgaria
          If the 680 uF 6.3V caps are polymers as well, then Yes.
          If the 680 uF caps are regular electrolytics, then MAYBE / it depends: if the 560 uF caps are near the CPU, RAM, or an inductor/coil, then they may be used as filter for switching VRM - in which case, the 680 uF electrolytic caps may not work if they have inferior ESR.
          Otherwise, in terms of capacitance, 560 uF is only slightly less than 20% of 680 uF, so the circuit will be perfectly fine with the slight increase in capacitance (if not even benefit from it.)
          • DixiePenguin
            • Mar 2008
            • 77
            • Philippines
            Many thanks or maraming salamat as we say here. I am sorry, I meant to say all caps in question are polymers. I will go ahead and replace them and post the results I really hope they are cause of the weird memory problems on the board. It is the Sniper A88X I have posted about. Again my appreciation for the help and patience.
            Bill
            • MORETTIGIAN
              Capacitor detached from PCB – RTX 2070 Super Founders Edition
              by MORETTIGIAN
              Title:
              Description:
              During maintenance on an RTX 2070 SUPER Founders Edition, I found a capacitor lying on my desk after reassembly.
              I did not notice it detaching, so I am unsure of its original location on the PCB.
              Procedure performed:
              - Removed backplate
              - Cleaned heatsink and PCB with isopropyl alcohol + soft ESD brush
              - Reapplied thermal compound
              - Reassembled card
              Observed behavior after reassembly:
              - GPU powers on and operates normally under...
              09-18-2025, 12:14 PM
            • m1ch43lzm
              Notice to users of XGecu TL866II Plus / T48 / T56 / T76 programmers regarding BIOS backup file size
              by m1ch43lzm
              Hi everyone
              I noticed on the Xgpro software the BIOS backup files have extra bytes at the end when reading some chips, this is because the Xgpro software also reads the OTP region of those flash chips, and by default will append that region to the saved file
              Programmer models: XGecu TL866II Plus / T48 / T56 / T76
              Example: GD25LQ128D (1.8V), IC size is listed as 0x1000000 Bytes (16777216 bytes) + 0xC00 bytes, those extra 0xC00 bytes will be appended to the end of the saved file by default, resulting in a file size of 16780288 bytes
              There's also an extra OTP Secu.R...
              09-06-2025, 05:47 PM
            • howardc64
              by howardc64
              Problem
              08-04-2024, 10:36 PM
            • Per Hansson
              Motor run capacitor physical size vs voltage rating & measurements?
              by Per Hansson
              (TL;DR skip the first paragraph)
              I encountered my first dead motor run capacitor at a customer this week.
              For some fields I guess it is a very common occurrence but the usual way for industrial machines here is to use 3-phase motors.
              (Unless a servo motor makes more sense that is).
              But for some reason this 3-phase machine uses a 1-phase motor for its liquid coolant pump.
              The pump would run but sometimes trip the 10A breaker.
              I monitored it starting and stopping for over an hour until it finally stopped in a specific spot between its windings:
              Then it could...
              09-20-2020, 06:32 AM
            • Prolog
              RTX 3080 FE Identifying capacitor
              by Prolog
              Hi people, I hope this is the correct spot to post this, I'm new to the forum.
              I have an RTX 3080 Founders Edition which has a burnt up capacitor (it was in parallel with another capacitor which appears damaged too), so I am hoping to be able to identify the capacitor values and order replacements.
              I hope these photos make it clear which component I am referring to:
              (yes, the soldering is a bit botched from removing the blown one, I know)
              I have found the board schematic (attached), but there does not seem to be a boardview available. I have never...
              12-01-2024, 08:27 PM
