I have new 680uf 6.3v capacitors. The problem is they are larger in physical size than what I had ordered. Can they still be used if I can fit them in? If i need to leave them raised slightly will it cause problems? Thanks!
Sorry for dumb question. Capacitor size.
Tags: None
Re: Sorry for dumb question. Capacitor size.
if the caps are used in a buck regulator like for the cpu vrm, raising it slightly will increase the esr which may not be good. raising it can also cause interference issues with the cpu heatsink if the increased height violates the processor keep out zone. -
Raised how far?
A few mm (5-6 mm max) off the board is generally not an issue. If you need to raise them more, it will depend on the circuit. As Chaos noted above, if the caps are used around a high-frequency voltage regulator circuit (such as caps around the CPU on a motherboard), then it's best to keep the caps as close to the PCB as possible. Other areas on the motherboard usually aren't as sensitive. And on an ATX PSUs, up to 10 mm off the PCB will still be OK (though, again, if the caps are closer to the PCB, they will be more effective and there will also be less electrical noise due to shorter leads.)
Now if the caps are used in a low-frequency circuit or as general filters for a linear voltage regulator, you can raise them pretty far off the PCB and they will still work fine.Last edited by momaka; 08-29-2020, 01:01 PM.Comment
Thanks for the info, I appreciate it. They would not be very elevated, probably less than 3mm. On a follow-up note. I have a Sniper A88X board with two bad polymers 560uf 6.3v. Would it be safe to use the 680uf 6.3v caps to replace them? I ask because anything I order ships from the States at very high standard charge. A lot of 10 caps cost under 300 php (Philippine piso) ship at a cost of 800 php. (That is $6 dollars worth of caps cost $17 dollars in shipping)
Have a good one,
BillComment
If the 680 uF caps are regular electrolytics, then MAYBE / it depends: if the 560 uF caps are near the CPU, RAM, or an inductor/coil, then they may be used as filter for switching VRM - in which case, the 680 uF electrolytic caps may not work if they have inferior ESR.
Otherwise, in terms of capacitance, 560 uF is only slightly less than 20% of 680 uF, so the circuit will be perfectly fine with the slight increase in capacitance (if not even benefit from it.)Comment
Many thanks or maraming salamat as we say here. I am sorry, I meant to say all caps in question are polymers. I will go ahead and replace them and post the results I really hope they are cause of the weird memory problems on the board. It is the Sniper A88X I have posted about. Again my appreciation for the help and patience.
BillComment
by MORETTIGIANTitle:
Description:
Procedure performed:
- Removed backplate
- Reapplied thermal compound
- Reassembled card
- GPU powers on and operates normally under...11 Photos -
by m1ch43lzmHi everyone
There's also an extra OTP Secu.R...-
Channel: BIOS Requests ONLY!
by howardc64Problem
This is an LG edge LED lit LCD Display. The LEDs are on the bottom edge of the display. There are 2 bars (left and right) Each bar has many LEDs and a 6 pin connector. Each pin drive several LEDs thus is the highest current flow / heat junction. The weak lead free solder gradually fails with thermal expansion/contraction cycling and increases resistance. PSU will compensate up to a point, then when the current is too high, PSU just shut down the backlight causing a dark display. I have even seen one which the connector just fell off as solder points became completely detached....-
by Per Hansson(TL;DR skip the first paragraph)
I encountered my first dead motor run capacitor at a customer this week.
For some fields I guess it is a very common occurrence but the usual way for industrial machines here is to use 3-phase motors.
(Unless a servo motor makes more sense that is).
But for some reason this 3-phase machine uses a 1-phase motor for its liquid coolant pump.
The pump would run but sometimes trip the 10A breaker.
I monitored it starting and stopping for over an hour until it finally stopped in a specific spot between its windings:
Then it could... -
by PrologHi people, I hope this is the correct spot to post this, I'm new to the forum.
I have found the board schematic (attached), but there does not seem to be a boardview available. I have never... - Loading...
