Need help finding specific capacitor
  • Dakay
    • Apr 2020
    • 15
    Just had these capacitors blow. Can anyone send a link to where i can buy these specifically? I just want to be positive i get the right ones. Thanks in advance!
  • pecrie
    • Nov 2011
    • 182
    Re: Need help finding specific capacitor
    Looks to me that these are 25 uF / 25 Volts - they are smd capacitors
    There are many good brands : like Panasonic , Nichicon , Elna ,
    You can find them on Mouser , Digikey , and other places
      • 22182
      More like 100uf 25V .Looks like a laptop motherboard,the schematic,if available would tell you for certain what they are.
      • Dakay
        • Apr 2020
        • 15
        Yea I determined that they’re 100uf 25v. There are no schematics available, unfortunately. However i just bought some that are 100uf, 25v, and are a similar size on mouser. Hopefully they’re close enough to work
          • 31293
          so was it you that baked them? i see all that flux!!
          • Dakay
            • Apr 2020
            • 15
            Yep :p i was attempting to remove the MOSFET you see next to it, but my hot air station couldn’t do it fast enough. I even had some kapton tape on the caps. End result: blown cap and still bad mosfet on the board
            • pecrie
              • Nov 2011
              • 182
              Ok so 100 uF - -
              I thought that the last number in the 100 - so the last zero (0) was the multiplier.
              So for a 100 uF cap it would be printed on the cap 101 - or is this wrong ??
              That would be a 10 + 1 extra zero - (or is this only for non electrolytic small caps ?)
              • MORETTIGIAN
                Capacitor detached from PCB – RTX 2070 Super Founders Edition
                by MORETTIGIAN
                Title:
                Description:
                During maintenance on an RTX 2070 SUPER Founders Edition, I found a capacitor lying on my desk after reassembly.
                I did not notice it detaching, so I am unsure of its original location on the PCB.
                Procedure performed:
                - Removed backplate
                - Cleaned heatsink and PCB with isopropyl alcohol + soft ESD brush
                - Reapplied thermal compound
                - Reassembled card
                Observed behavior after reassembly:
                - GPU powers on and operates normally under...
                09-18-2025, 12:14 PM
              • Prolog
                RTX 3080 FE Identifying capacitor
                by Prolog
                Hi people, I hope this is the correct spot to post this, I'm new to the forum.
                I have an RTX 3080 Founders Edition which has a burnt up capacitor (it was in parallel with another capacitor which appears damaged too), so I am hoping to be able to identify the capacitor values and order replacements.
                I hope these photos make it clear which component I am referring to:
                (yes, the soldering is a bit botched from removing the blown one, I know)
                I have found the board schematic (attached), but there does not seem to be a boardview available. I have never...
                12-01-2024, 08:27 PM
              • Agent24
                Dick Smith Q-1760 linear power supply filter capacitor question
                by Agent24
                I have acquired a used Dick Smith Q-1760 power supply - although the OEM is Manson Industrial
                It has at least one problem.
                The voltage control potentiometer VR2, 50K is faulty - going high resistance / open circuit in the CCW end and leading to the output voltage jumping around.
                I have already ordered a replacement potentiometer, so that's not an issue.
                Now, I want to replace all three electrolytics on the PCB as they are CapXon and I don't trust them so much, I will replace them with something better while I've got the thing apart anyway.
                All are CapXon...
                10-21-2025, 05:39 PM
              • chth96
                If I replace with inferior capacitor, Is it No harm to other IC components at all?
                by chth96
                I replaced some capacitor which is located on optical pickup pcb which is shown in the table below(PCB #2).Because it have been out of order.
                Now,It works very well,But I just have found that all caps (6svpc100my and other part number as well) ,which is shown in the table below, has ultra-high ripple current spec.
                It is not able to obtain any capacitor which can be a substitute for this ultra-high ripple current nichicon capacitor.
                So I replaced it with samxon and rubycon's general capacitor(GP,YXA series).
                I know that these capacitor will not last as long as nichicon capacitor...
                12-22-2023, 04:34 AM
              • chth96
                How can I test non-polarized capacitor?
                by chth96
                I desoldered samwha NF capacitor(50v 5.6uf) from PCB circuit of 29inch CRT TV which have symptoms of no display after I heard sound of inrush of current to TV whenever I switch on this television.
                I measured ESR value of this non-polarized capacitor(samwha NF capacitor 50v 5.6uf) by means of MESR-100 ESR meter and It displayed 0.3 ohm
                And When I measured its capacitance with digital multimeter and LCR-T4 Mega328 meter, It displayed 10uf from DMM and 8uf from LCR-T4 meter.
                I found catalogue of samwha capacitor(samwha-catalogue_3.pdf file), which is attached to this thread,...
                06-02-2024, 07:31 PM
