ESR meter
  • Kelte
    • Jul 2009
    • 15
    ESR meter
    I am looking for a capacimeter / ESR meter. The following :
    http://www.peakelec.co.uk/acatalog/jz_esr70.html
    Compare to some other ESR meters, which sometime doesn't even have a display, it looks fine and at a competitive price. Best on the market?...
    Any experience on it? Worry a bit about accuracy…
  • chth96
    Is it possible to test small ceramic disc capacitor with analogue meter?
    by chth96
    I read EBOOK of Testing Electronic Component and found that
    "In order to test the small blue resin coated ceramic disk capacitor which has 104 50v specification,it is possible to test this small ceramic capacitor by making use of analogue meter.
    Set to times 10Kohm that has 12v output from the probe to check disorder of ceramic capacitor.
    It is not uncommon that testing result of digital capacitance meter is okay,But It show shorted reading when you check it with analogue meter."
    Is it really possible to test small ceramic disc capacitor with analogue...
    03-09-2024, 10:03 PM
  • Ryan Wurtz
    Lenovo Yoga C740-15IML 5V on usb meter.
    by Ryan Wurtz
    Hello. So I searched and didn't find any posts on this specific problem.
    When plugged in USB power meter reads 5v
    Doesn't charge battery. I can charge the battery with power supply. So it seems the battery works fine. Laptop started but didn't post on battery.
    Original mobo had a shorted cpu it seems.
    So I decided I need a new motherboard.
    Put the new one in the computer. Connect the battery, I think it starts, don't quite remember, but when I plug the adapter/charger.
    5v on the meter. Still won't charge. Can still charge the battery...
    11-24-2025, 01:08 AM
  • eccerr0r
    lowest current galvanometer/analog meter (passively powered!)
    by eccerr0r
    Most analog meters are actually current driven - a current is needed to deflect the pointer full scale. They can be lots of different values. There are ones that can take several amperes to swing the pointer as they have internal shunts.
    On the other hand there are many that are rated in microamps for the intent that they draw as little power as possible from the devices under test. Some are 1mA, 500µA, 200µA, 100µA, and the ubiquitous 50µA frequently used in analog VOMs. There are even 20, 25, 30 µA and even down to 10µA. Been collecting a bunch of different ratings and...
    04-16-2025, 12:41 AM
  • jorpec
    Changing the scale of an analog meter
    by jorpec
    Hi
    I want to change the scale of an analog meter, to monitor the charge of an li-ion single cell, so the needle at the end would point 4.2 volts and the 0 on the meter would point 2.5 volts or so, i tried to add diodes or a zener in series with the meter but the changes of the ambient temperature also changes the voltage value on the meter
    I wonder how i can accomplish this so the meter would be precise at any temperature ?
    Thnaks
    01-23-2023, 10:37 AM
    How an incandescent light and a ESR meter ** friend**have a machine blowing fuses
    by sam_sam_sam
    About a month ago we had a transformer jumper wire that burned in two different places between two transformers caused over $200 thousand dollars worth of damage to VFD drives at least 10 of them and a memory card and quite a few power supply as well
    Now we have most of the equipment that got damaged back up and running except a feeder that has issues and we are waiting for some parts for
    Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the “E” stops and one switching power (24 volt) supply and a transformer...
    12-14-2023, 07:45 PM
