ESR meter
  • Kelte
    • Jul 2009
    • 15
    ESR meter
    I am looking for a capacimeter / ESR meter. The following :
    http://www.peakelec.co.uk/acatalog/jz_esr70.html
    Compare to some other ESR meters, which sometime doesn't even have a display, it looks fine and at a competitive price. Best on the market?...
    Any experience on it? Worry a bit about accuracy…
  • chth96
    by chth96
    03-09-2024, 10:03 PM
  • Ryan Wurtz
    Lenovo Yoga C740-15IML 5V on usb meter.
    by Ryan Wurtz
    Hello. So I searched and didn't find any posts on this specific problem.
    When plugged in USB power meter reads 5v
    Doesn't charge battery. I can charge the battery with power supply. So it seems the battery works fine. Laptop started but didn't post on battery.
    Original mobo had a shorted cpu it seems.
    So I decided I need a new motherboard.
    Put the new one in the computer. Connect the battery, I think it starts, don't quite remember, but when I plug the adapter/charger.
    5v on the meter. Still won't charge. Can still charge the battery...
    Yesterday, 01:08 AM
  • eccerr0r
    lowest current galvanometer/analog meter (passively powered!)
    by eccerr0r
    Most analog meters are actually current driven - a current is needed to deflect the pointer full scale. They can be lots of different values. There are ones that can take several amperes to swing the pointer as they have internal shunts.
    On the other hand there are many that are rated in microamps for the intent that they draw as little power as possible from the devices under test. Some are 1mA, 500µA, 200µA, 100µA, and the ubiquitous 50µA frequently used in analog VOMs. There are even 20, 25, 30 µA and even down to 10µA. Been collecting a bunch of different ratings and...
    04-16-2025, 12:41 AM
  • jorpec
    by jorpec
    Hi
    Thnaks
    01-23-2023, 10:37 AM
    Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the “E” stops and one switching power (24 volt) supply and a transformer...
    12-14-2023, 07:45 PM
