Ceiling Fan Speed Capacitor
  • Baldrick
    • Apr 2014
    • 19
    I've got a bulging capacitor in my ceiling fan that only gives me high speed.
    It's a 4-wire guy and I'm having a heck of a time finding a direct replacement. I've attached a pic of mine. As you can see, it's a 4uf - 5uf. The closest I can find is a 5uf - 5uf.
    Would this work?
    Thanks!
  • TechGeek
    Computer Geek
    • Jan 2015
    • 2254
    Re: Ceiling Fan Speed Capacitor
    Looks like you'll also need some 330K resistors. If you want exact values, order 2 capacitors, 1 5uf and 1 4uf, as well as 2 .5W 330K resistors and wire as shown.
    Permanently Retired Systems:
    Kooky and Kool Systems
    sigpic
      https://www.ebay.com/itm/CBB61-250VA.../162178364020?
      You can probably use 5uf + 5uf without the bleeder resistors, or do more search on EBAY for SK MOTOR CAPACITOR.
      • Baldrick
        • Apr 2014
        • 19
        If I were to buy something like in the picture I'm attaching, could I just leave out the brown and end up with the same thing?
        Hopefully, that's not a really stupid question...
          • 31170
          yes,
          but you should fit the 330k resistors if you can, they are to stop you getting a shock among other things
            Yes you can.
            • Baldrick
              • Apr 2014
              • 19
              Originally posted by stj
              yes,
              Just curious. Are those resistors just an extra safety thing or would it be inadvisable to go without? In all of the searching I've done looking for these caps, I have not seen another with resistors.
              Thanks.
                The bleeder resistor is used for discharging the cap so if you have to work on the fan after disconnecting the power, the cap will be discharged by the resistor so you will not get shock from it, most motor caps do not have resistors.
                • Baldrick
                  • Apr 2014
                  • 19
                  I just wanted to say thanks everyone!
                  I bought a replacement cap and wire nutted off the unneeded lead. Hooked it up and it works perfectly.
                  My girls think I'm a genius...
                    Thanks for the follow-up on the repair.
                    • desert-rat
                      • Mar 2014
                      • 4103
                      If you all ready the 5 5 uf cap , I would try it . My guess is that the speed might be a little off .
                        • Jul 2011
                        • 6059
                        Look at this website page you can find the cap you are looking for
                        https://eceilingfans.com/capacitors_-_ceiling_fans.html
                        One note
                        I have not bought from them before
                        If the UF value is too high then the motor might run warm than normal
                        This might be a problem or it might not be problem it just depends on the motor ( just testing the motor that would be fine use it for that )
                        • MORETTIGIAN
                          Capacitor detached from PCB – RTX 2070 Super Founders Edition
                          by MORETTIGIAN
                          Title:
                          Description:
                          During maintenance on an RTX 2070 SUPER Founders Edition, I found a capacitor lying on my desk after reassembly.
                          I did not notice it detaching, so I am unsure of its original location on the PCB.
                          Procedure performed:
                          - Removed backplate
                          - Cleaned heatsink and PCB with isopropyl alcohol + soft ESD brush
                          - Reapplied thermal compound
                          - Reassembled card
                          Observed behavior after reassembly:
                          - GPU powers on and operates normally under...
                          09-18-2025, 12:14 PM
                        • Prolog
                          RTX 3080 FE Identifying capacitor
                          by Prolog
                          Hi people, I hope this is the correct spot to post this, I'm new to the forum.
                          I have an RTX 3080 Founders Edition which has a burnt up capacitor (it was in parallel with another capacitor which appears damaged too), so I am hoping to be able to identify the capacitor values and order replacements.
                          I hope these photos make it clear which component I am referring to:
                          (yes, the soldering is a bit botched from removing the blown one, I know)
                          I have found the board schematic (attached), but there does not seem to be a boardview available. I have never...
                          12-01-2024, 08:27 PM
                        • chth96
                          If I replace with inferior capacitor, Is it No harm to other IC components at all?
                          by chth96
                          I replaced some capacitor which is located on optical pickup pcb which is shown in the table below(PCB #2).Because it have been out of order.
                          Now,It works very well,But I just have found that all caps (6svpc100my and other part number as well) ,which is shown in the table below, has ultra-high ripple current spec.
                          It is not able to obtain any capacitor which can be a substitute for this ultra-high ripple current nichicon capacitor.
                          So I replaced it with samxon and rubycon's general capacitor(GP,YXA series).
                          I know that these capacitor will not last as long as nichicon capacitor...
                          12-22-2023, 04:34 AM
                        • chth96
                          How can I test non-polarized capacitor?
                          by chth96
                          I desoldered samwha NF capacitor(50v 5.6uf) from PCB circuit of 29inch CRT TV which have symptoms of no display after I heard sound of inrush of current to TV whenever I switch on this television.
                          I measured ESR value of this non-polarized capacitor(samwha NF capacitor 50v 5.6uf) by means of MESR-100 ESR meter and It displayed 0.3 ohm
                          And When I measured its capacitance with digital multimeter and LCR-T4 Mega328 meter, It displayed 10uf from DMM and 8uf from LCR-T4 meter.
                          I found catalogue of samwha capacitor(samwha-catalogue_3.pdf file), which is attached to this thread,...
                          06-02-2024, 07:31 PM
                        • chth96
                          Is it no harm to replace with capacitor without ripple current rating?
                          by chth96
                          When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
                          Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
                          But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
                          Rubycon YK DataSheet (b...
                          04-19-2024, 05:19 AM
