Possibly rebranded Panasonic capacitors
  • Typicular
    • Mar 2020
    • Czech Republic
    I just discovered those interesting capacitors: https://www.we-online.com/catalog/en/WCAP-PHGP/
    Does anyone know whether they are rebranded or not? They look pretty much the same like SP-CAPs from Panasonic.
    • 31288
    Re: Possibly rebranded Panasonic capacitors
    afaik all Wurth stuff is made for them by other company's
    but the poly's are good - i'v used them.
    very well priced too.
    • Typicular
      • Mar 2020
      • Czech Republic
      Thanks for the reply! Panasonic surely manufacturers high quality caps.
      • Hitto
        • Apr 2019
        • 95
        • Italy
        I've used Würth capacitors (general purpose series) in the past and they seem to do their job.
        They are quite cheap, so you can have fun with poly-modding at a convenient price.
          After all of...
          07-13-2024, 08:14 PM
        • Alfieh
          NAD C320BEE repair possibly bad capacitors
          by Alfieh
          hey Im very new to repairing electronics with capacitors as well as using a multimeter so I need so help/guidance fixing this issue
          recently I was handed a family members old NAD C320BEE that they had in their loft for storage for a few years but when powered on it went into power safety mode due to a problem on the protection circuit somewhere before it went into storage I was told it worked fine I found lots of people online talking about how the capasitors are known to be pretty bad in this model and can cause this issue the only problem being I don't have much experience sorting...
          11-19-2024, 04:55 PM
        • BigPete
          Panasonic Heatpump Dryer Repair
          by BigPete
          I picked up a Panasonic NH-P70G2, though it would apply to the NH-P80G2, NH-P70G1 and NH-P80G1 models as well, as maybe some other models. This one was coming up with a H86 error. After lots of testing and googling it was an error with one of the thermistors in the condenser area.
          The attached French service manuals is incorrect, TH11 is gray and is a 95k thermistor and TH12 is black and is a 35k thermistor.
          In my case TH12 was bad. I was able to get a 35k thermistor on AliExpress. It's 6mm in diameter.
          Unfortunately the whole machine has to come apart to fix it.
          I have...
          11-01-2025, 06:40 PM
        • dragon3x
          by dragon3x
          power on.
          Here are some examples :
          switching supply area).
          than 6.3 V.)
          03-21-2025, 02:46 PM
        • Andre Gilbert
          by Andre Gilbert
          11-20-2024, 08:52 PM
