Possibly rebranded Panasonic capacitors
  • Typicular
    • Mar 2020
    • 4
    • Czech Republic
    I just discovered those interesting capacitors: https://www.we-online.com/catalog/en/WCAP-PHGP/
    Does anyone know whether they are rebranded or not? They look pretty much the same like SP-CAPs from Panasonic.
    • 31087
    Re: Possibly rebranded Panasonic capacitors
    afaik all Wurth stuff is made for them by other company's
    but the poly's are good - i'v used them.
    very well priced too.
    • Typicular
      • Mar 2020
      • 4
      • Czech Republic
      Thanks for the reply! Panasonic surely manufacturers high quality caps.
      • Hitto
        • Apr 2019
        • 95
        • Italy
        I've used Würth capacitors (general purpose series) in the past and they seem to do their job.
        They are quite cheap, so you can have fun with poly-modding at a convenient price.
          by sam_sam_sam
          After all of...
          07-13-2024, 08:14 PM
        • Alfieh
          NAD C320BEE repair possibly bad capacitors
          by Alfieh
          hey Im very new to repairing electronics with capacitors as well as using a multimeter so I need so help/guidance fixing this issue
          recently I was handed a family members old NAD C320BEE that they had in their loft for storage for a few years but when powered on it went into power safety mode due to a problem on the protection circuit somewhere before it went into storage I was told it worked fine I found lots of people online talking about how the capasitors are known to be pretty bad in this model and can cause this issue the only problem being I don't have much experience sorting...
          11-19-2024, 04:55 PM
        • dragon3x
          After updating motherboard capacitors, what to do next (Asrock K7VT2, SOLTEK SL-75FRN2L)
          by dragon3x
          Hi, I have some 32 bits computer motherboards that need repair, as they fail to
          power on.
          Here are some examples :
          (N.B. "capacitors" indicated here are electrolytic capacitors located in the onboard
          switching supply area).
          (N.B. #2 : I could not find a 3300 microF aluminum-polymer with a higher voltage
          than 6.3 V.)
          1 - Motherboard #1 : this is an Asrock K7VT2 (socket A) that still works well. To put it on test
          I replaced capacitors with aluminum-polymer.
          3300 microF/6.3 V. x 4 replaced by 3300 microF/6.3 V. (KYOCERA...
          03-21-2025, 02:46 PM
        • Andre Gilbert
          by Andre Gilbert
          Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here🤔?
          Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting 😂.
          11-20-2024, 08:52 PM
        • slybunda
          AA and AAA battery charger capacitors?
          by slybunda
          hey all, iv got my favourite battery charger here which iv had for many years probably 15 years now or maybe even more. it still works good but thought id open it up to clean the dust out of it, lots of dust inside but now its clean and noticed 4 capacitors inside it and wondered if i should replace them.
          it has inside:
          2 x 47uf 16v caps 105c branded as Su'scon (lol sounds sus to me)
          2 x 470uf 16v LZ105c branded as G.Luxon
          not heard of these brands are they any good?
          iv attached photos of the charger and the board inside for an idea on the type of...
          12-24-2023, 04:41 AM
