Dell E310 problems - Need advice
  • friscokid
    • Oct 2009
    • 16
    Re: Dell E310 problems - Need advice
    O.k. Found this thread with a similar problem... Looks like I need to recap and retest..
    https://www.badcaps.net/forum/showpo...02&postcount=3
    • PCBONEZ
      Grumpy Old Fart
      • Aug 2005
      • 10661
      Originally posted by friscokid
      Well, Vista seemed fine, but I tried to boot into FreeNAS, a BSD based OS, and it immediately gives an I/O error on the USB-Hub and shuts it down. Only a keyboard hooked up.
      Definitely something still wrong within the USB hardware for the machine.
      Suggestions on anything I can check with a DMM or should I just order those two low ESR caps first?
      Thanks for all the help so far, Mike
      That's not what I meant.
      Look at the USB gadgets. They should say how many amps they pull.
      Might be in milliamps. -- 0.5 amp = 500 milliamps.
      As long as all the gadgets connected to and powered by any given Port add up to 0.5 amps or less you are fine.
      If a gadget has a wall-wart then it's not powered by the port.
      If you need to connect more than 0.5 amps worth to one Port then connect them through a POWERED USB Hub. - A Powered USB Hub will have a wall-wart so -it- will be the source of power to the devices instead of your PC's USB Port.
      Mann-Made Global Warming.
      - Dr Seuss
      • friscokid
        • Oct 2009
        • 16
        Thanks, I understood what you meant... good info.
        In reading my post, I think I was not being clear
        The only thing hooked up to the computer was a keyboard and the system was still having
        USB controller problems.. not the other 'hardware'.
        I have to look at the motherboard and see what all caps are on it.
        I've seen people on here recommend from replace all, replace above 480 and replace above 860... and oh.. look out for those 220s.
        I'll probably order them all since shipping is a large part of the cost and start at the higher side and work down.
        -Mike
        • PCBONEZ
          Grumpy Old Fart
          • Aug 2005
          • 10661
          Small caps gone bad near the chipset south-bridge may be boogering up the signals.
          [USB chip is integrated into south-bridge.]
          Small caps near the port itself are usually to keep EMI captured by external cables or devices from coming into the motherboards power plane from outside the case. They don't usually go bad but if they do you might have some EMI in your +5v, +5vsb, or both depending on the boards design.
          I had a board a while back that kept telling me 'some' USB device was pulling excess power. - There weren't any USB devices connected.
          Turned out to be a +5v issue with the PSU tripping the USB power sensor's warning.
          [Wherever the heck that sensor is...]
          New PSU fixed it.
          - Dr Seuss
          • Borse2008
            Seeking Advice: Repairing Dell U3425WE Monitor with Faulty USB-C/Thunderbolt Ports
            by Borse2008
            Looking for some advice or opinions on what to do with a monitor issue I’ve run into. Apologies in advance is this crossovers a few forum categories.
            I have a Dell U3425WE, which I've recently replaced with another model. That said, the original unit is still fully functional in terms of the display — it works perfectly over HDMI and DisplayPort. However, the USB-C and Thunderbolt 4 ports have stopped functioning correctly. The Issue:
            • The 90W Thunderbolt 4 port (circled in the photo) no longer charges or powers any device, including laptops or MacBooks.
            • There’s
            07-15-2025, 04:55 AM
          • Bowline
            by Bowline
            06-11-2025, 10:13 AM
          • Akhlz001
            by Akhlz001
            09-20-2025, 07:15 PM
          • Caimano
            Problems extracting from Dell Bios Update.Inspiron 3793
            by Caimano
            I am trying to repair a Dell Inspiron 3793 which has problems with start up, no battery charging and fan not running. I believe the Bios (probably the EC Region) is corrupted.
            The board is FDI45-LAJ091P REV 1.0 A00
            Processor i7 1065G7 with GPU
            This MB has 2 Bios Chips (one 8MB and one 16MB chip).
            I am trying to reload a new Bios with clean ME region, new main region and new EC region.
            I attach the dumps of the 2 chips.
            I successfully used ME analyzer to identify ME, PCH and PMC versions and used Flash Image Tool to install ME, PCH and PMC cleaned regions....
            05-04-2022, 11:19 AM
          • stakrzysiu
            Dell Vostro 15 5501 BIOS Problems
            by stakrzysiu
            i have here a Dell Vostro 15 5501
            REG Model: P102F
            SN: 1WD5103
            there is a problem that it shows screen after 1 min.
            Is this caused by me?
            Can someone clean me for me? Then i will try.
            Thank you very much
            Best regards...
            01-25-2025, 05:36 AM
