Bad capacitors on Dell SX260
  • Kraig
    • Oct 2009
    I have two SX260's that will not start up right now, both have several bulging capacitors many with brown residue on top of them. All of the problem capacitors are labeled as 6.3v 2200 uF, is there an easy way to find the diameter and height without taking the capacitor off and measuring it?
    Now I looked at the stock on this site, and it seems the only capacitors that match the specs I need all have a 10mm diameter and 20mm size, would it be safe to assume this is the size I need? If so should I go with the Rubycon or Samxon? Thanks for such a helpful website!
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    Re: Bad capacitors on Dell SX260
    Put a tooth-pick next to the cap and mark it for how tall the cap is and then measure the tooth-pick.
    OR
    Look up the original caps in their data sheet.
    10x20mm should be fine.
    - But check first.
    Use the Rubycon.
    Mann-Made Global Warming.
    - Dr Seuss
    • Bowline
      by Bowline
      06-11-2025, 10:13 AM
    • Akhlz001
      by Akhlz001
      09-20-2025, 07:15 PM
    • master3112
      by master3112
      07-29-2025, 01:55 PM
      Dell Thunderbolt Firmware
      by SMDFlea
      Dell thunderbolt firmware, extracted from dell firmware update exe. Padded to 1MB.
      Some models have a choice of 2 different firmwares, it depends on the dell SKU.
      The SKU is in brackets (****)
      EDIT: NVM65...
      01-26-2025, 06:22 AM
    • F R 2568
      Dell Latitude 5420 does not start (no post) need help to find the reason why
      by F R 2568
      Hello all,
      this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
      I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
      If the laptop is only connected to the AC adapter (battery removed):
      When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
      The power/battery...
      01-08-2025, 05:45 AM
