Bad capacitors on Dell SX260
  • Kraig
    • Oct 2009
    I have two SX260's that will not start up right now, both have several bulging capacitors many with brown residue on top of them. All of the problem capacitors are labeled as 6.3v 2200 uF, is there an easy way to find the diameter and height without taking the capacitor off and measuring it?
    Now I looked at the stock on this site, and it seems the only capacitors that match the specs I need all have a 10mm diameter and 20mm size, would it be safe to assume this is the size I need? If so should I go with the Rubycon or Samxon? Thanks for such a helpful website!
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    Re: Bad capacitors on Dell SX260
    Put a tooth-pick next to the cap and mark it for how tall the cap is and then measure the tooth-pick.
    OR
    Look up the original caps in their data sheet.
    10x20mm should be fine.
    - But check first.
    Use the Rubycon.
    Mann-Made Global Warming.
    - Dr Seuss
    • Bowline
      by Bowline
      06-11-2025, 10:13 AM
    • Akhlz001
      by Akhlz001
      09-20-2025, 07:15 PM
    • master3112
      by master3112
      07-29-2025, 01:55 PM
      Dell Thunderbolt Firmware
      by SMDFlea
      Dell thunderbolt firmware, extracted from dell firmware update exe. Padded to 1MB.
      Some models have a choice of 2 different firmwares, it depends on the dell SKU.
      The SKU is in brackets (****)
      EDIT: NVM65...
      01-26-2025, 06:22 AM
    • dell_sadness
      Dell Latitude 3440 - Service tag ending in 0001 - Locked!
      by dell_sadness
      BIOS password locked Dell Latitude 3440 (Service tag B4HNJX3)
      Have extracted the BIN and want to know how to rebuild a clean BIOS
      I have come across the 8F8C patcher but not sure if that would work in my case as the service tag ends in 0001.
      I tried it and although the log states it patched several mentions of 8F8C in the BIN, I haven't flashed it yet in case such a patch wouldn't work.
      Have also tried to extract a clean BIN file from Dell's .exe BIOS updates using 'Dell PFS Extractor', but not confidently; Ended up with a 25MB file instead of the same 32MB...
      Yesterday, 02:54 PM
