Does it matter if the Capacitor im replacing with uf is lower than the original broken cap? For example the broken cap uf is 2700 the cap im replacing with is 2200uf
Capacitor uF
Always replace caps with ones of the uf same rating or slightly above, NEVER lower.
Always replace caps with ones of the uf same rating or slightly above, NEVER lower. Same thing goes with the voltage; a bad 25v cap can be replaced with a 35v / 50v cap as long as it fits and you have clearance for other components / casing. Make sure you match or exceed the temp rating also; it will usually be 85c or 105c. -
Re: Capacitor uF
Need a bit more info... Brand & series AND diameter & height. Easier to make the proper recommendation for replacement. Series are usually 2 or 3 letter marked near the temperature rating.
Diameter and height.
Also, consider replacing all of that brand and series of cap on the board. More failures are likely. Especially due to the heat in there.
If you are unsure, post pics of markings on cap.
Toastveritas odium paritComment
Re: Capacitor uF
How old of a xbox 360 is this? Mine is the first gen to have the extra heatpipe and heatsink on the gpu, smaller manufacturing process, and the HDMI port on the back.
When I cracked it open it had all 105C rubycon's from the bigun's to the littleun's, along with the little fujitsu solids scattered about.Comment
Re: Capacitor uF
Nichicon HN or HZ series:
HN - http://www.mouser.com/ProductDetail/...FB9oeVnCpac%3d
ESR = 0.010 ohms / Ripple = 2900mA
HZ - http://www.mouser.com/ProductDetail/...ls0nMEcpcy4%3d
ESR = 0.007 ohms / Ripple = 3770mA
Re: Capacitor uF
AgreeMann-Made Global Warming.
- Dr Seuss
by MORETTIGIANTitle:
Description:
Procedure performed:
- Removed backplate
- Reapplied thermal compound
- Reassembled card
- GPU powers on and operates normally under...11 Photos -
by chth96When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
Rubycon YK DataSheet (b...-
by “Eabdel”Hello,
I have a RTX 3090 Founders Edition and it's detected as PCIE X4 instead of X16
I took a look to the PCB and found that a capacitor, wich is linked to and the PCIE fingers lines, is broken. I count and it's on the 32 position (exactely the end of the PCIEX4)
Anyone knows this capacitor specification? I see some other models boardview and seems to be linked to the ground
Can I just solder the trace between them with no capacitor or it's risky?
Thanks...2 Photos -
by AdenitzHello,
I'm reading an article about the "capacitor plaque" in early 2000s and I have found one sentence I cannot understand.
The normal lifespan of a non-solid electrolytic capacitor of consumer quality, typically rated at 2000 h/85 °C and operating at 40 °C, is roughly 6 years. It can be more than 10 years for a 1000 h/105 °C capacitor operating at 40 °C.
What this 2000h or 1000h means? Why 1000h capacitors have longer life span?-
by Per Hansson(TL;DR skip the first paragraph)
I encountered my first dead motor run capacitor at a customer this week.
For some fields I guess it is a very common occurrence but the usual way for industrial machines here is to use 3-phase motors.
(Unless a servo motor makes more sense that is).
But for some reason this 3-phase machine uses a 1-phase motor for its liquid coolant pump.
The pump would run but sometimes trip the 10A breaker.
I monitored it starting and stopping for over an hour until it finally stopped in a specific spot between its windings:
Then it could... - Loading...
