What value is this capacitor?
  • roadrash
    • Oct 2015
    • 493
    • U.K.
    Can anyone identify what value this capacitor is?
    All I know is its 12v.
  • R_J
    • 9624
    Re: What value is this capacitor?
    From another site it seems to be a 2200µf/16 volt 10x25mm They used a Panasonic EEUFS1C222L as a replacement
    Other sites call it a 1200µf or 1500µf, the value will change the flash rate, Lower capacity gives a faster flash rate.
    For more information, Google, Marcon 5840
      • 31291
      i wouldnt, your going to run into problems
      the cap and resistor form a timed charging cicuit - a different cap may run at a different speed.
      a 555 timer will be a good upgrade.
      • roadrash
        • Oct 2015
        • 493
        • U.K.
        Its only a old but well made flasher unit off a 1979 hona CX500. Easy to fix so for the cost of 1 cap why not?
        Sorry to appear dumb but apart from the value being within tolerance i dont know how to interperate what the output from my component tester is telling me about this cap. I know what ESR is but what does all the rest mean and whats it telling me about this particular capacitor?
          • 31291
          vloss is leakage caused by internal resistance
          it can fool a lot of cap meters into thinking the cap has a higher uf, and makes the cap discharge itself faster.
          i'v seen far worse, but a good cap is in the 1.x% or less type of range.
          • roadrash
            • Oct 2015
            • 493
            • U.K.
            I know what ESR is but is there a value that you would say is ok and one thats makes it suspicious without having to keep looking at each manufacturers datasheets which is what can be done if its suspicious.
              • 31291
              no,esr varies greatly between series - but the vlos indicates it's fucked.
              • redwire
                • 3912
                It will not do anything if there is an open light bulb, that charges the cap in series with the 150 ohm resistor I think.
                You can't use a timer IC or electronics here because it's a two-prong part. It replaces the old thermal clickers.
                • roadrash
                  • Oct 2015
                  • 493
                  • U.K.
                  Sorry STJ that was a general question and not just about yhis particular capacitor. So vlos over 3.5% is knackered so is there a max and minimum to indicate whether a cetain cap is good or bad
                    • 31291
                    if it's 2 or more then it's higher than any good cap i'v tested.
                    polymers are different btw, they are often 2-3.
                    • MORETTIGIAN
                      Capacitor detached from PCB – RTX 2070 Super Founders Edition
                      by MORETTIGIAN
                      Title:
                      Description:
                      During maintenance on an RTX 2070 SUPER Founders Edition, I found a capacitor lying on my desk after reassembly.
                      I did not notice it detaching, so I am unsure of its original location on the PCB.
                      Procedure performed:
                      - Removed backplate
                      - Cleaned heatsink and PCB with isopropyl alcohol + soft ESD brush
                      - Reapplied thermal compound
                      - Reassembled card
                      Observed behavior after reassembly:
                      - GPU powers on and operates normally under...
                      09-18-2025, 12:14 PM
                    • Prolog
                      RTX 3080 FE Identifying capacitor
                      by Prolog
                      Hi people, I hope this is the correct spot to post this, I'm new to the forum.
                      I have an RTX 3080 Founders Edition which has a burnt up capacitor (it was in parallel with another capacitor which appears damaged too), so I am hoping to be able to identify the capacitor values and order replacements.
                      I hope these photos make it clear which component I am referring to:
                      (yes, the soldering is a bit botched from removing the blown one, I know)
                      I have found the board schematic (attached), but there does not seem to be a boardview available. I have never...
                      12-01-2024, 08:27 PM
                    • Agent24
                      Dick Smith Q-1760 linear power supply filter capacitor question
                      by Agent24
                      I have acquired a used Dick Smith Q-1760 power supply - although the OEM is Manson Industrial
                      It has at least one problem.
                      The voltage control potentiometer VR2, 50K is faulty - going high resistance / open circuit in the CCW end and leading to the output voltage jumping around.
                      I have already ordered a replacement potentiometer, so that's not an issue.
                      Now, I want to replace all three electrolytics on the PCB as they are CapXon and I don't trust them so much, I will replace them with something better while I've got the thing apart anyway.
                      All are CapXon...
                      10-21-2025, 05:39 PM
                    • chth96
                      If I replace with inferior capacitor, Is it No harm to other IC components at all?
                      by chth96
                      I replaced some capacitor which is located on optical pickup pcb which is shown in the table below(PCB #2).Because it have been out of order.
                      Now,It works very well,But I just have found that all caps (6svpc100my and other part number as well) ,which is shown in the table below, has ultra-high ripple current spec.
                      It is not able to obtain any capacitor which can be a substitute for this ultra-high ripple current nichicon capacitor.
                      So I replaced it with samxon and rubycon's general capacitor(GP,YXA series).
                      I know that these capacitor will not last as long as nichicon capacitor...
                      12-22-2023, 04:34 AM
                    • chth96
                      How can I test non-polarized capacitor?
                      by chth96
                      I desoldered samwha NF capacitor(50v 5.6uf) from PCB circuit of 29inch CRT TV which have symptoms of no display after I heard sound of inrush of current to TV whenever I switch on this television.
                      I measured ESR value of this non-polarized capacitor(samwha NF capacitor 50v 5.6uf) by means of MESR-100 ESR meter and It displayed 0.3 ohm
                      And When I measured its capacitance with digital multimeter and LCR-T4 Mega328 meter, It displayed 10uf from DMM and 8uf from LCR-T4 meter.
                      I found catalogue of samwha capacitor(samwha-catalogue_3.pdf file), which is attached to this thread,...
                      06-02-2024, 07:31 PM
