Recapping iMac logic board using solid polymer
  • glocalmedia
    • Sep 2009
    I will be recapping an iMac's logic board it uses the regular low esr capacitor in case I want to use solid polymer capacitors as replacement what would you suggest I get to replace them here's a picture of the logic board.
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    Re: Recapping iMac logic board using solid polymer
    i am going to polymod one soon.
    stay tuned for the results.
    • glocalmedia
      • Sep 2009
      Hi kc8adu can your verify all the cap values are right? I checked the board and it was previously repaired saw signs of bad soldering. thanks
      • Logistics
        • Apr 2007
        • 721
        I'd like to hear back about this. I just got an iSight G5 20" for next to nothing, but it's got blown caps. I may as well polymod it. I'm not certain what the voltages are, though.
        The bad ones are all nearest the CPU and the GPU (least I think that's what the main chips with the heat tubes run to them are) and are 6.3v MCZ's at 1500uF and 1800uF. Can I just run polymers with half the capacitance at 4v or so? I can't find a really good recap writeup for these. Everyone always replaces them with factory caps which I'm obviously not about to do.
        Thanks in advance!
        -Logistics
        Presonus Audiobox USB, Schiit Magni 3, Sony MDR-V700
        • Topcat
          The Boss Stooge
          • Oct 2003
          • 16955
          https://www.badcaps.net/forum/showthread.php?t=9769
          and
          https://www.badcaps.net/forum/showthread.php?t=9829
          <--- Badcaps.net Founder
          Badcaps.net Services:
          Motherboard Repair Services
          http://folding.stanford.edu/
          Team : 49813
          Join in!!
          Team Stats
          • Logistics
            • Apr 2007
            • 721
            Dang, I have the 3rd Gen with a 2.1GHz... I guess that makes it a Core II Duo? But it has hardly any caps on it compared to the 1st and 2nd Gen. I think the PSU will end up having problems after I open it because from the looks of its PCB it got HOT.
            In regards to the few caps it does have, the 1500uF and 1800uF 6.3v jobbers, do they need to be the same value if I put polys in their place or can I reduce them?
            Here's a link to the exact board mine has: hxxp://jimwarholic.com/2010/02/isight-g5-apple-mother-board.php
            • Logistics
              • Apr 2007
              • 721
              Oh, I guess it's still the PowerPC processor and not the Core Duo version. My Paps aquired this thing under the impression he could actually install Windows on it. Is that possible with the PowerPC version? (and I don't mean emulating it within MacOS)
              • m1ch43lzm
                by m1ch43lzm
                05-12-2025, 08:37 PM
              • ohren
                by ohren
                09-08-2023, 05:24 PM
              • Yanleb
                LG 60PK550 Logic Control Board EBR63450301
                by Yanleb
                Hi all, I just want to share the repair of my 60PK550-UA TV set.
                The TV set was powering on, just no image. After verification, nothing wrong on the YSus or ZSus boards. Nothing wrong on the main board either.
                But I noticed that the LED was not flashing on the Logic Control Board. This is an EBR63450301. The LED is supposed to flash even with all the flat cables disconnected, with only the power cable attached.
                All the voltages measured at the electrolytic capacitors on the board were good. From top left to bottom right:
                C57: 3.30V
                C61:...
                07-20-2023, 12:38 AM
              • korben_dallas
                Will I have a bricked logic board after reflow of the GPU v-core U8900 chip on my Mid-2012 15" Retina Macbook pro?
                by korben_dallas
                Hi everyone! I'm trying to fix my black screen / failed U8900 GPU v-core on my Mid-2012 Macbook Pro 15" Retinaby doing a rework/reflow of the chip (once I determine that's the real issue; but it likely is).
                I've been disabling the GPU in NVRAM for a few years... but it's just time for a better solution.
                I'm new to soldering but the only feasible way to fix this issue is to do something myself.
                MY QUESTION:
                I've been seeing some people (on this forum mostly) run into issues with the logic board needing a serial number or it being deactivated (?)...
                02-14-2024, 12:23 AM
