Laptop Mobo Unknowns
  • SupraSS
    • Aug 2005
    I had this old Dell Inspiron 3500 laptop mobo that I used the oven heat trick on. I wasn't sure if the caps could handle the heat and sure enough they couldn't. I guess that was pretty stupid, I wasn't thinking and should've just removed them prior. Truthfully I didn't think the oven technique would work anyways so I didn't think it through too well. All of them started leaking, but at least the mobo went from dead to now working again. Previously it wouldn't boot unless it was pressed or twisted meaning there was a solder break somewhere.
    There are 8 total Sanyo caps, 3 designated "18"(long ones) and 5 "19"(short ones). What does the 15/25 mean? I assume it's 15uf/25v because there are some same style caps on another Toshiba mobo that I have which are designated 330/6.3 and 68/20. See picture.
    So where could I get some replacements? I tried googling, but didn't come up with any good sites.
    Thank you for any input you can give.
    http://img255.*************/img255/796/capsayc.jpg
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Re: Laptop Mobo Unknowns
    wow. it takes effort to blow up oscons. those are polymer caps. i personally do not know much on that type but i wish you the best.
    sigpic
    (Insert witty quote here)
    • Fsufan1391
      LG Oven model LREL6325F
      by Fsufan1391
      Hello everyone my oven is less than 2 years old and all of a sudden recently when i run the oven for 15 minutes or so and i am done with it and shut it off. after about 10 minutes it starts chiming and randomly putting it in different modes like the touch screen is being touched but no one is around it. I have tried to reset it by unplugging it multiple times and no luck. I took it apart to see the main board and everything looks fine. I am wondering if i should replace the main board or if its in the control panel. the touch screen is very responsive and works like it should. its only acting...
      04-23-2025, 05:42 AM
    • schnauzer2021
      Chasis bond to neutral to overcome oven tripping problem
      by schnauzer2021
      I have a 6 years old Rowenta table top oven. The oven have both convection and grill function.
      Last Christmas I used it to roast a turkey with the convection mode for about 4 hours without any problem. When I switched to grill mode to deep browning the turkey for the final half hour, the power trips after a while.
      I have not been using the oven since then. Last week, when I try to use the oven again, both convection and grill mode trip the power supply a few minutes after turning it on.
      As I was too busy with my work, I leave it to the repairman...
      09-13-2021, 02:40 AM
    • bpjl
      SEF 551.10 - Error starting the reflow oven.
      by bpjl
      When starting the SEF 551.10 reflow oven, the following problem occurs:
      It seems to me that this is related to corrupted software. Does anyone have files that can fix this device? Or maybe someone uses such an oven and is able to make a sector copy of the memory card located in the computer controlling this oven?
      PS.: Of course, appropriate emails for help have been sent to the manufacturer and distributor in my country. No response yet, but I don't expect much. It's a fairly old device and from what I know, it's no longer...
      10-17-2024, 06:30 AM
    • ChaosLegionnaire
      by ChaosLegionnaire
      09-13-2022, 09:02 AM
    • Cerberuska
      Mobo MSI B550-A PRO password popup
      by Cerberuska
      Hello guys,
      I have interesting problem. My MoBo MSI running on Ryzen 7 w/o graphics just good. I swapped to Ryzen 5 5600G and on the boot I stuck with screen on picture. Enter Password. I checked BIOS setting with Ryzen 7, no security is enabled, BIOS password or TPM.
      BIOS I updated to last one.
      any suggestions?
      And same thing for two different 5600G, and yes, MoBo supposed to support it.
      Thank you...
      11-10-2024, 01:23 PM
