Heya guys,
Well I splashed out and got myself a Low ESR meter. I went with the Atlas ESR 60.
So I decided to test it out on a bunch of new caps I got here which are mainly Panacsonics like 1000uf 6.3v with some 1500uf 10v, and 1000uf 10v, 1200uf 6.3v.
Most came in at about 0.05 Ohms through to 0.12 Ohms. So I am guessing this is normal range.
Now I grabbed the only bad motherboard I had lying around and put the meter on a clearly venting cap (not the worst example I have seen but it does have a little electrolyte out the top). The cap is rated at 6.3v 1500uf 105deg. It looks like its marked RLS / Ost?
Anyway to my surprise it measured 6000uf (waaaay out) but only 0.13 Ohms (which is not that different to what I got on the good ones)
So what gives? Why is its value so close to the good ones?
Also I note this atlas esr meter with give capacitance as well as low esr, but it states that sometimes it cant calculate capacitance in circuit. I notice when testing the above capacitor it says *in curcuit* in place of the capacitance reading, EVEN when I have pulled the cap out of the circuit.
Why would that be?
Puzzled...
-Al
Why would that be?
Puzzled...
-Al
