Atlas ESR60 - Low ESR Meter
  • BigAlNZ
    • Mar 2008
    • 65
    Heya guys,
    Well I splashed out and got myself a Low ESR meter. I went with the Atlas ESR 60.
    So I decided to test it out on a bunch of new caps I got here which are mainly Panacsonics like 1000uf 6.3v with some 1500uf 10v, and 1000uf 10v, 1200uf 6.3v.
    Most came in at about 0.05 Ohms through to 0.12 Ohms. So I am guessing this is normal range.
    Now I grabbed the only bad motherboard I had lying around and put the meter on a clearly venting cap (not the worst example I have seen but it does have a little electrolyte out the top). The cap is rated at 6.3v 1500uf 105deg. It looks like its marked RLS / Ost?
    Anyway to my surprise it measured 6000uf (waaaay out) but only 0.13 Ohms (which is not that different to what I got on the good ones)
    So what gives? Why is its value so close to the good ones?
    Also I note this atlas esr meter with give capacitance as well as low esr, but it states that sometimes it cant calculate capacitance in circuit. I notice when testing the above capacitor it says *in curcuit* in place of the capacitance reading, EVEN when I have pulled the cap out of the circuit.
    Why would that be?
    Puzzled...
    -Al
  • BigAlNZ
    • Mar 2008
    • 65
    Re: Atlas ESR60 - Low ESR Meter
    PPS: I also note that when I tested this VRM cap in circuit the ESR value was 0 but asume thats because of other caps on the mobo which may be in parallel with it (though it wasnt in a line of caps).
    -Al
    • Wizard
      • Mar 2008
      • 2296
      I'll ask you to measure the voltage output on that esr tester, should be below diode breakover point (around .45V max) and what KHz esr generates, for that case, you need scope. The standard to compare against is bob parker's ESR meter as your measurements sounds odd.
      Cheers, Wizard
      • BigAlNZ
        • Mar 2008
        • 65
        Hi Wizard,
        I will do that. It says in the manual the output is 100Khz.
        Interestingly I found the spec sheet for that OST, RLS series 6.3v 1500uf cap. The spec sheet says it should have ESR of about 0.02. Thus if its reading 0.13 it is about 7 times over its rated ESR...
        Do I need to open this meter up to measure the output voltage?
        • BigAlNZ
          • Mar 2008
          • 65
          Cheers, Wizard
          PS: Whats your method for measuring with scope? I tried with the ESR meter connected to the probe and gnd clip, but when I press the test button the meter says open circuit or low capacitance so I am not sure if its putting the signal out?
          -Al
          • Wizard
            • Mar 2008
            • 2296
            ESR meter is constantly outputting when on. All you wanted is to measure peak voltages.
            I could not find what I'm looking for, but bob parker said train of pulses at 500uS.
            Cheers, Wizard
            • BigAlNZ
              • Mar 2008
              • 65
              Cheers, Wizard
              Okay, but the method in terms of connecting probe to ESR clip, and GND on probe to other ESR clip sounds right?
              Cheers
              -Al
              • Wizard
                • Mar 2008
                • 2296
                yes as long as it is isolated power or on battery power.
                Cheers, Wizard
                • BigAlNZ
                  • Mar 2008
                  • 65
                  Cheers, Wizard
                  OK, will have another go tonight. It wasnt a very thorough attempt at 6am this morning!
                  Also I have been told that a increase in ESR from the spec sheet value of 2x-10x is typical of a cap thats gone bad. Sounds about right?
                  IF this rule is true, then looking at the spec sheet tells me the ESR should be 0.023/0.038/0.041 (depending on the size) (spec sheet @ )
                  Now the cap I have is measuring 0.14 - easily more than twice the above values, and thus the cap is bad...IF the 2x-10x rule is true?
                  -Al
                  • severach
                    • Aug 2007
                    • 1055
                    There is nothing wrong with the measurements. I've measured a lot of popped caps with my Atlas ESR60 where the ESR is decent and the uF is double or triple. I think it's a just a failure mode of some capacitors before they crash and burn.
                    To duplicate what you see I tested a 820uf cap with a 1 ohm resistor in parallel. The ESR was still 0.06 but Atlas said it was in circuit. There are other strange messages you can coax out of the Atlas with other resistance values.
                    While the Atlas ESR60 is a nice meter I always reach for the Bob Parker unit when troubleshooting boards since it is so much easier to use. I use the Atlas to test pulls to discard them if the capacitance is too much.
                    sig files are for morons
                    • i4004
                      • Oct 2006
                      • 2029
                      there's no such rule: when cap will make problems for mobo depends on the mobo design.
                      ie it wouldn't be surprising to learn that mobo was actually working, but as severach says, those caps might just be on the cliff after which they'll burn the mobo too...
                      in other words, you can have venting cap, and everything works fine. then suddenly mobo doesn't work anymore...
                      and then one wonders was it increased capacitance that killed it rather than esr...heh...or just cap going short circuit...which is more likely...
                      either way that is advantage of being able to measure both capacitance and esr...
                      • Stephan Mathers
                        EDMI ATLAS MK10 Electronic Meter Discussion
                        by Stephan Mathers
                        Greetings, new guy here but always interested in the crazy universe of modding
                        We just finished construction of around 25 vacation houses, all inside the same private area.
                        Each house has 3phase power , and we bought an atlas MK10 meter for each house (25 meters total ! )
                        The metering on a per-house basis is done privately. Its not done by a utility company. The utility company will only charge us for the total consumption of all 25 houses together.
                        Id like to do a small modification on the firmware of our MK10 to make it easier identify each house's...
                        05-20-2025, 09:09 AM
                      • narf
                        Epson EB-U42 projector / Caps with 0.7 ohms ?!
                        by narf
                        hi all,
                        first of all: i'm a (motivated) newbie, so please forgive me any stupid question i may or may not ask
                        i'm currently repairing a projector: Epson EB-U42 that doesn't start (no lights, nothing).
                        what i've found so far:
                        - the PSU does its job and supplies 12V to the mainboard via the connector.
                        - shortly thereafter, there is a mosfet (TS420-600B) where i can test 12V on the one side (in the data sheet this side is called Anode), Gate 0V, Kathode shorted to ground
                        - not far away, there's the first cap with a resistance of 0.7 ohms....
                        07-02-2024, 03:53 PM
                        12-31-2023, 06:04 AM
                      • Ryan Wurtz
                        Lenovo Yoga C740-15IML 5V on usb meter.
                        by Ryan Wurtz
                        Hello. So I searched and didn't find any posts on this specific problem.
                        When plugged in USB power meter reads 5v
                        Doesn't charge battery. I can charge the battery with power supply. So it seems the battery works fine. Laptop started but didn't post on battery.
                        Original mobo had a shorted cpu it seems.
                        So I decided I need a new motherboard.
                        Put the new one in the computer. Connect the battery, I think it starts, don't quite remember, but when I plug the adapter/charger.
                        5v on the meter. Still won't charge. Can still charge the battery...
                        Today, 01:08 AM
                        Sacon FZ revival experiment
                        by momaka
                        So after using capacitor bungs to repair the rubber feet on two laptops, shown here:
                        https://www.badcaps.net/forum/showpo...&postcount=548
                        … and here:
                        https://www.badcaps.net/forum/showpo...&postcount=585
                        … I was inevitably left with some paper rolls and cans from the Sacon FZ capacitors I “sacrificed”.
                        The paper rolls from these Sacon FZ caps looked absolutely bone-dry. The idea then occurred to me: what if I put a few drops of water on there? How (if at all) would that affect these already-failed capacitors?...
                        01-26-2022, 08:43 PM
