Re: Where do you get your capacitors?!
AH, yeah, that kind of sucks to find. haha I mean, there are definitely higher voltage capacitor kits from people like Nichicon (ie: https://www.mouser.com/ProductDetail...SABEgJPEfD_BwE ), but getting high capacity/high voltage type caps can be a bit rough in a kit. :/
This is the sort of thing I have just purchased 5(or 1 extra in the case of huge caps like that) of at a time every time I came to a part I needed but didn't have off of Mouser. I would be interested if there are any high capacitence+high voltage cap kits too but I suspect that they would be prohibitively expensive as it were.
Something I have done in the past is just buy some tv capacitor kits that had a wide range of capacitors, plus some of the big ones. The quality varies though.. nothing like what you get when you get sample kits from suppliers like Nichicon.
I tend to recommend that people who are just sorting starting out, building up components, buy Sample Kits. These kits are sent out/sold to manufacturers so that they can test the components and such before using them in their products. Here is an example kit from Nichicon.
https://www.mouser.com/ProductDetail...SABEgKpK_D_BwE
You can also get them from the cheaper brands like jwco that will have about 4x as many capacitors as the nichicon one. What route you take really is up to you though.I honestly recommend buying some of the cheap kits to start out, then buy the nice parts as they are needed for a project if you are just starting out. You may end up replacing the cheap capacitors down the road in a device, but taking advantage of the learning curve and really getting a lot of experience quickly, at the start will go a long way.
That being said, If the thing you are working on really matters, then maybe use the nichicons instead of the jwco's. lol
like my current project at the moment, two 450v 1200 uf capacitors are way below capacity. But in reality all the other capacitors have aged too. i can replace those two that are causing the problem now for 10 dollars. but replacing the other will run more into the 25-30 range. and a working power supply board is around 25.
I see the argument that more then likely the ebay seller didnt replace all the caps on the working board. So i guess i get that side of it.
Do any of you know a kit that includes common P board capacitors? maybe in the 200-450v range?Leave a comment:
for only 56 dollars including shipping (you can select priority mail shipping, i highly recommend it)
is actually cheaper than buying it individually, which totals to 85 including shipping.
I have purchased Lelon kits (back then on Mouser) just for testing out projects and then purchase the good stuff.
I have used Mouser and Digikey and they have good customer service
and i always get what i ask for.Leave a comment:
That being said, If the thing you are working on really matters, then maybe use the nichicons instead of the jwco's. lolLeave a comment:
I use Digikey, they are fast, usually next day to Canada for $8.00, Free shipping on orders over $100.00Leave a comment:
Theyre not much better. Still a little cheaper than mouser though. The problem im having is i can buy in bulk to save money in the future but every tv ive seen needed different types of capacitors so it seems kinda stupid to buy in bulkLeave a comment:
check all the u.s. supplier minimum order levels for free shipping - someone must be reasonable!!
what is element14 like??Leave a comment:
So, im a hobbyist at repairing tvs. I actually find great satisfaction in making something work that previously didnt. But im starting to notice a big problem. Ive repaired about 5 tvs on my own now. They were all bad caps except one bad resistor.
The issue is that normally ive noticed that when one capacitor fails the others are aged pretty bad too. If i want to do things right i should replace all the capacitors that are aging. But every tv ive came across has used wildly different capacitors so stocking a few different types seems pointless. The power supplies ive been messing with have had about 6-8 different larger capacitors at about 5 a piece on mouser.
At that price i could buy two replacement working power supply boards on ebay. So am i missing something here or is it as it seems and its almost always a better idea to just buy replacement boards unless none are available.
Im hoping someone can point me to an assortment pack with actual good tv type high and low voltage capacitors. I prefer to work on the boards myself and so i would love any pointers on how you guys do it. Id love to know there some typical capacitors kit out there even though ive looked and looked and all i can find is the cheap kind that hardly get above 10v above 500uf.Last edited by Demonata08; 05-08-2019, 02:01 AM.Tags: None
by dragon3xHi, I have some 32 bits computer motherboards that need repair, as they fail to
power on.
Here are some examples :
(N.B. "capacitors" indicated here are electrolytic capacitors located in the onboard
switching supply area).
(N.B. #2 : I could not find a 3300 microF aluminum-polymer with a higher voltage
than 6.3 V.)
1 - Motherboard #1 : this is an Asrock K7VT2 (socket A) that still works well. To put it on test
I replaced capacitors with aluminum-polymer.
3300 microF/6.3 V. x 4 replaced by 3300 microF/6.3 V. (KYOCERA... -
by slybundahey all, iv got my favourite battery charger here which iv had for many years probably 15 years now or maybe even more. it still works good but thought id open it up to clean the dust out of it, lots of dust inside but now its clean and noticed 4 capacitors inside it and wondered if i should replace them.
it has inside:
2 x 47uf 16v caps 105c branded as Su'scon (lol sounds sus to me)
2 x 470uf 16v LZ105c branded as G.Luxon
not heard of these brands are they any good?
iv attached photos of the charger and the board inside for an idea on the type of...-
Channel: General Capacitor Questions & Issues
by sam_sam_samI did not have any 27uf @ 50 volt capacitors but one nice thing is that it has enough room for two capacitors in parallel a 22uf and a 4.7uf @ 50 volts 22 plus 4.7 equals 26.7uf which so very close to 27uf I will show some pictures of it sometime tomorrow
After all of... -
by CamaHello,
I need help to find the value of 2 missing capacitors ( C102 and C117) on my Easun SMH-II mainboard (solar hybrid inverter). I circled it in red on the close-up picture. The 2 old capacitors are completely missing, so I have no reference. Does anyone have this board and can tell me the value or make an educated guess based on the location ?
My model is : EASUN SMH-II 7 KW
Mother Board : P/N 18947-002401250250
Maybe the EASUN SMH-II 4.2 KW have the same capacitors
Thank you... -
by Ady2017I have a 2007-era Panasonic VHS combo that is full of of Elna RJG capacitors. I am trying to test the capacitors to diagnose the machine and then select replacement capacitors but I can not find any datasheets for them. I did find a Elna catalogue from 2007-2008 but there is no mention of this capacitor series. Where these specially made for Panasonic and so not made available to the public? Any ideas what to find out what the ESR values should be without the datasheets? They are all between 10V and 50V and 47uF and 1800uF. None are leaking or bulged but I know that they need to be tested to be...
- Loading...
