Aishi Capacitors (same value, different height)
  • linker3000
    • Sep 2007
    • 24
    I'm refurbing a non-working DVR (won't power up) and starting by replacing the caps in the PSU PCB section. All caps are Aishi and some have already tested bad and will be replaced, however I have a quick question:
    There's a bunch of 1000uF 16V caps, but one is taller than the others. The majority are marked CD288Z, and the taller one is CD288S. A quick Web search has not turned up any useful info, so can anyone let me know from experience whether there's any major differences between the two types that may be relevant for how I replace them. I presume it's either just production line variances or might be more important - ie: ripple or ESR??
    • 31213
    Re: Aishi Capacitors (same value, different height)
    different ripple & esr,
    nothing unusual - panasonic does the same.
    http://www.paullinebarger.net/DS/Aishi/
    • Bishop
      AisHi?
      by Bishop
      I had a bad ballast in a light fixture so I took it apart and found two AisHi 200v, 47uf caps.
      This is my first AisHi cap. Are they quality or not?
      01-25-2018, 10:47 AM
    • spleenharvester
      Whirlpool PACF212HP W portable air conditioner, upper fan only turns slowly.
      by spleenharvester
      I just acquired this portable aircon, history unknown. Its behaviour is quite strange:
      • When turned on and placed into cooling mode, the upper fan (cold air out) just spins slowly. The compressor and lower fan do not run.
      • If the device is then placed into heating mode and then back into cooling mode, the lower fan and compressor kick in and start cooling, but the upper fan still only spins slowly.
      • If the device is placed into fan-only mode, the upper fan does not respond to low/medium/high speed toggles - just keeps running slowly.
      • Display and buttons all behave normally aside from the
      06-27-2025, 07:49 PM
    • spleenharvester
      TP-Link Kasa KP105 - rapidly power cycling when plugged in
      by spleenharvester
      One of my KP105 smart plugs failed today. It started very rapidly power cycling (you could hear the relay clicking on and off and the LED was going green/orange repeatedly).
      I was going to just bin it but I opened it up out of curiosity. Found a swollen cap in the corner (bottom right of image). AiSHi brand, 470uF 10V 105*C. Not sure what purpose it serves exactly so can't comment on whether it is appropriately specced. Other members of this forum have reported similar findings with off-brand smart plugs but this is the first time I have seen evidence of this happening with a brand...
      05-21-2025, 11:26 AM
    • Babo Tech
      Need bios bin Hp g42 daax1jmb8c0 rev:c
      by Babo Tech
      Hola a todos,
      Llego al taller una notebook, Hp g42 daax1jmb8c0 rev:c, que enciande mas no da imagen, ya probamos con las ram, voltajes, salidas hdmi y nada, y por lo que veo es problema de bios,
      si alguienme puede ayudar con dichas bios, se lo agradeciaria mucho.
      A notebook arrived at the workshop, HP g42 daax1jmb8c0 rev:c, which turns on but does not give an image, we already tried with the ram, voltages, hdmi outputs and nothing, and from what I see it is a bios problem,
      If anyone can help me with these...
      02-03-2025, 07:19 AM
    • t4796
      Fender Mustang non valve guitar amp - owner connected 110v amp to 220v.
      by t4796
      I recently picked up this amp as not working. I took it as is. Didn't notice until I got home it had foreign power plug and was marked 110v and our local voltage is 220v so then I knew what had happened to it.
      Opened it up and was able to find the schematic online. In the schematic I have uploaded I have erased the parts for 220v operation to make it easier for me to visualise however I have since added the two additional diodes and remove the wire link from the power supply so I can test it easier on 220v
      From the FAQ I learnt that for 110v the power...
      10-25-2024, 06:59 PM
