FAQ? Can I test loose capacitors with a DVM?
  • lkvee
    • Feb 2009
    • 198
    I didn't find an answer in the FAQ here. I skimmed the USENET FAQs but didn't find documentation that directly answered my question.
    I'm thinking about the capacitors I've plucked out of boards, where replacing them with capacitors with similar specs (same capacitance, and the same or higher voltage, and the same ESR) failed to improve/repair/resolve the behavior.
    I'd be grateful for any feedback!
    Thanks for reading!
  • severach
    • Aug 2007
    • 1055
    Re: FAQ? Can I test loose capacitors with a DVM?
    [/url=http://www.anatekcorp.com/testequipment/meters.htm]Anatek Meters[/url]
    You can measure small capacitance values with a DVM that has a capacitance scale. The range is too small for most of the capacitors you will want to measure. A cap meter that goes to 20,000uf or 20mf is sufficient. Search eBay for "capa* (multi*,meter)".
    ESR testing is more definitive and can often be done without removing the capacitor minimizing unnecessary pulling of good caps. I like the Dick Smith based Anatek Blue with the pointy probes.
    The Atlas ESR60 tests both but isn't as easy to use.
    None of these meters test voltage breakdown.
    http://www.youtube.com/watch?v=uiQCNlex3aE
    I'm anxiously waiting until some pacific engineer figures out that $0.001 of chips and one setting on the dial and every meter could be an ESR meter.
    sig files are for morons
    • khelane
      test active pfc power with lamp test
      by khelane
      Hello
      I have a big problem and that is that in some cases when repairing active pfc power supplies I cannot work with a test lamp. I can only get help with 5 volts standby and for starting and starting I have to work without a lamp and this way there is a possibility of parts exploding and other parts being added.
      Sometimes with a multimeter test the problems can be reduced to some extent, but I had several cases that had to be tested on and online and recently two varistors exploded. They had terrible resistance because the power supplies were over 800 watts.
      Is there a way...
      06-03-2025, 01:00 AM
    • chronic519
      Mats / mods: detected and repaired GPU fault. Cant seem to test after!
      by chronic519
      Hello.
      GPU came in, green lines. Spent lots of time using to get the Mats / mods drive working (found on youtube).
      Found issue with a RAM block
      Replaced, green lines gone.
      Trying to test again, assuming getting the false positive. Originally had over 1K on a single bank. Now getting tosses low between banks.
      Used a good card to test and same results low errors 32+.
      I am just search for some form of command to do a full test on the GPU.
      I just ran the mats command with my good GPU and passed after roughly 40 min.
      The repaired one, ran...
      05-20-2025, 07:56 PM
    • slybunda
      AA and AAA battery charger capacitors?
      by slybunda
      hey all, iv got my favourite battery charger here which iv had for many years probably 15 years now or maybe even more. it still works good but thought id open it up to clean the dust out of it, lots of dust inside but now its clean and noticed 4 capacitors inside it and wondered if i should replace them.
      it has inside:
      2 x 47uf 16v caps 105c branded as Su'scon (lol sounds sus to me)
      2 x 470uf 16v LZ105c branded as G.Luxon
      not heard of these brands are they any good?
      iv attached photos of the charger and the board inside for an idea on the type of...
      12-24-2023, 04:41 AM
    • dragon3x
      After updating motherboard capacitors, what to do next (Asrock K7VT2, SOLTEK SL-75FRN2L)
      by dragon3x
      Hi, I have some 32 bits computer motherboards that need repair, as they fail to
      power on.
      Here are some examples :
      (N.B. "capacitors" indicated here are electrolytic capacitors located in the onboard
      switching supply area).
      (N.B. #2 : I could not find a 3300 microF aluminum-polymer with a higher voltage
      than 6.3 V.)
      1 - Motherboard #1 : this is an Asrock K7VT2 (socket A) that still works well. To put it on test
      I replaced capacitors with aluminum-polymer.
      3300 microF/6.3 V. x 4 replaced by 3300 microF/6.3 V. (KYOCERA...
      03-21-2025, 02:46 PM
      by sam_sam_sam
      After all of...
      07-13-2024, 08:14 PM
