Illegal narcotic substance in electrolytic capacitors
  • bestsystem
    • May 2011
    • 59
    γ-Butyrolactone (GBL) is commonly used in electrolytic capacitors, especially some low temperature and low resistance capacitors.
    e.g.
    https://patents.google.com/patent/EP1460660A1
    any many more like samxon
    coincidentally, it's an illicit party drug!
    http://www.winknews.com/2018/09/24/f...egal-drug-gbl/
    Are there any case records about electrolytic capacitor manufracturers or owners got into illicit drug trouble?
  • ChaosLegionnaire
    HC Overclocker
    • Jul 2012
    • 3264
    • Singapore
    Re: Illegal narcotic substance in electrolytic capacitors
    wow didnt know u could do that and abuse cap electrolyte that way! hehe... thanks for informing me tho, now u're making me wanna break/cut open my caps just so that i could use and sniff some drugs! hahahaha!
    anyway, its more like the factory workers who would abuse and sniff gbl say one day when they are bored or when they got nothing to do in the factory one day... lol!
    • ratdude747
      Black Sheep
      • Nov 2008
      • 17136
      Great, now the DEA is staring us down
      sigpic
      (Insert witty quote here)
      • CapPun
        • Nov 2018
        • 37
        • Yurp
        "high" quality caps no doubt
        • Wester547
          • Nov 2011
          • 1268
          • USA.
          GBL is a solvent long used in non-aqueous capacitor series such as Nichicon PW, Panasonic FC, Chemi-con LXZ, etc. Unless the capacitors vent or leak their contents, or someone actively tries to dissect them, I don’t think this “illegal narcotic substance” would cause much ado by virtue of electrolytic capacitors. The liquid electrolyte, however, is highly acidic and conductive to begin with, regardless of the type of solvent or solution used.
          Moreover, the water used as part of the solvent in an aluminum electrolytic capacitor electrolyte solution is a chemically active substance with respect to the aluminum of the anode foil or cathode foil. It therefore reacts with the anode foil or cathode foil to generate hydrogen gas, and this raises the pressure in the capacitor and increases the stress on the capacitor element, thereby causing deformation or breakage of the wound structure; this may promote fly out of the electrolyte solution to the exterior or activate the safety vent, thereby significantly altering the characteristics.
          On and off-handed note, but I found this part to be interesting. Unless very special additives are used in the electrolytic mixture, the quality assurance is up to par, and all the materials are of exceptional purity, electrolytes whose solutions contain water in high or even moderate concentrations are probably bound to eventual failure (due to water-driven corrosion caused by hydroxide molecules). The water is used in the electrolyte due to its very good conductivity, permittivity, solubility, and affordability. Its high concentration of dissolved salt ions is what allows for its remarkably enhanced conductivity compared to more expensive, traditional solvents.
          • bestsystem
            • May 2011
            • 59
            yes Wester547, panasonic FC is non aqueous, has good quality that i love to use, but the content is rather flammable when I test the wrong polarity and flame test experiment, compared to other series and brands.
            • bestsystem
              • May 2011
              • 59
              A problem has arised is in many countries narcotic chemicals require prescription & exemption to posess in any form, and I can't see my recapping pack of panasonic and chemicon is exempted from the police, technically I am a criminal drug dealer
              • Topcat
                The Boss Stooge
                • Oct 2003
                • 16956
                Geez, with all the caps I've sold, I'm a kingpin!
                <--- Badcaps.net Founder
                Badcaps.net Services:
                Motherboard Repair Services
                http://folding.stanford.edu/
                Team : 49813
                Join in!!
                Team Stats
                • junktv
                  • Nov 2010
                  • 3065
                  An international smuggler also.
                  *Thinks to self.....Hmmm wonder what the reward would be? Ah better not then BCN would shut down.*
                    master hoarder
                    • May 2008
                    • 12175
                    • Bulgaria
                    Glad I saved all my failed caps over the years, then. Maybe I can crush a few busted caps tomorrow and roll me a stogie with the contents. If ya'll don't see me here in a few days, please don't call 911, even if I've O/Ded. Just remember my loving living spirit.
                    • bestsystem
                      • May 2011
                      • 59
                      Is same as
                      • Wester547
                        • Nov 2011
                        • 1268
                        • USA.
                        That's interesting regarding FC. In accordance to the Panasonic FC engineering draft, the contents, however corrosive they may be, should not be flammable, even though the series uses the organic solvent GBL:
                        Pressure relief shall be operated without any hazardous expulsion or emission of flame.
                        Who would've thunk that the GBL based capacitors could become potential firecrackers a la ventless Sacon FZ.
                        • bestsystem
                          • May 2011
                          • 59
                          pana FC can be ignited under big reverse voltage or when burnt with cigarette lighter , will not self extinguish, which many other caps will self extinguish.
                          Appears that GBL based caps have the least leakage current in electrolytics and warrants it's use.
                          • RetroComputingGrotto
                            Opinions/Advice on Do/Should I replace ALL Electrolytic Capacitors on old equipment?
                            by RetroComputingGrotto
                            I've just been repairing some (very) old speakers with a loud hum that occurred as soon as you powered them on regardless if any actual audio is played through them. I work in a School so it's 99% likey that the Teachers have hardly ever turned the power off on them for well over 10+ years.
                            As you can see the top large capacitor on the right has a bulge on the top so defincately needs replacing. As the one next to it is exactly the same capacity and voltage I planned to replace them both.
                            What is your advice/opinion on whether or not on old(er)...
                            04-03-2024, 08:30 AM
                          • alfredo2j90
                            Old electrolytic capacitors
                            by alfredo2j90
                            So as most of us know, old unused electrolytic capacitors are unrealiable due drying out and breakdown of the oxide layer.
                            I have a few questions regarding these issues.
                            1. Does using an electrolytic cap stop it from drying out or is it natural process that happens regardless?
                            2. With the breakdown of the oxide layer the ESR will increase as well as DC leakage. Say the cap has remained unused on a motherboard, psu or games console for many years, if the cap does not physically pop when power is applied what other damage could occur to the system if it was...
                            10-10-2021, 04:43 AM
                          • slybunda
                            AA and AAA battery charger capacitors?
                            by slybunda
                            hey all, iv got my favourite battery charger here which iv had for many years probably 15 years now or maybe even more. it still works good but thought id open it up to clean the dust out of it, lots of dust inside but now its clean and noticed 4 capacitors inside it and wondered if i should replace them.
                            it has inside:
                            2 x 47uf 16v caps 105c branded as Su'scon (lol sounds sus to me)
                            2 x 470uf 16v LZ105c branded as G.Luxon
                            not heard of these brands are they any good?
                            iv attached photos of the charger and the board inside for an idea on the type of...
                            12-24-2023, 04:41 AM
                          • proxneo
                            Recapping Sony ICF-SW55 - verifying cap values
                            by proxneo
                            Dear reader
                            I am performing a repair on a Sony ICF-SW55, which includes recapping (some) of the SMD capacitors on the mainboard. I am looking for verification of their values. At the moment, I'm 95% sure I've got the right values, but it is hard to find some official, credible or multiple independant sources on this.
                            At the moment, I have selected replacements based on the following list of values:
                            3 x 470uF 10VDC
                            3 x 4.7uF 35VDC
                            4 x 47uF 50VDC
                            8 x 22uF 6.3 VDC
                            1 x 220uF 6.3VDC
                            5 x 100uF 6.3VDC
                            Which...
                            06-21-2023, 12:38 AM
                            by sam_sam_sam
                            After all of...
                            07-13-2024, 08:14 PM
