iq recap?
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    iq recap?
    i have here a compaq presario 7000 board. 6 rubycon yxg, 7 iq. none of the iq visibly failed.
    board posts slower than an identical board (oddly, with nova in place of iq)
    iq:
    to recap or not recap?
    sigpic
    (Insert witty quote here)
  • pfrcom
    Oldbie
    • Jun 2006
    • 1230
    Re: iq recap?
    Is it because the faster one is set to Quick Start = Enabled (or equivalent) and the slower one isn't ?
    better to keep quiet and be thought a fool, than to open your mouth and remove all doubt
    • gdement
      • Jan 2007
      • 690
      Re: iq recap?
      If this board will be used for anything where you care about reliability, then I'd replace the IQ regardless of current condition.
      But as for your symptoms, I've heard of high ESR causing a slow boot. People have talked about that happening when they used general purpose caps from Radio Shack. Never seen it myself though. Definitely check your BIOS settings like pfrcom said.
      • ratdude747
        Black Sheep
        • Nov 2008
        • 17136
        Re: iq recap?
        both set to quick boot
        should i recap the other one as well?
        sigpic
        • gdement
          • Jan 2007
          • 690
          Re: iq recap?
          I would, unless you're not worried about what happens if they fail later.
          • m1ch43lzm
            by m1ch43lzm
            05-12-2025, 08:37 PM
          • Hakuu
            by Hakuu
            Hi There,
            More Details
            TV Model - LG OLED77G1PUA
            07-12-2023, 02:37 PM
          • jb_Bak
            by jb_Bak
            CN6401
            Pin 01 NC
            Pin 02 NC
            Pin 03 "BL_ON": 0V
            Pin 04 "N/C"
            Pin 05 "STBY 3.3V": 3.5V
            Pin 06 "GND": N/C
            Pin 07 "AC_OFF"...
            09-27-2021, 04:52 PM
          • canadaboy25
            Panasonic TC-P54VT25 No image. A or D board?
            by canadaboy25
            I have a Panasonic TC-P54VT25 that will power on and prime the display but there is no image at all.
            The panel is primed as there is a slight glow from the entire panel. This means the problem should be logic related. The service manual also confirms this and recommends replacing the A or the D board.
            I have tried to get the TV to display the test sequence but I have been unable to and I don't even know if this TV has a test sequence or not. I tried following tom66's instructions in post #3 on this thread https://www.badcaps.net/forum/showthread.php?t=26790. There was...
            01-17-2021, 01:06 AM
