Relying on you true Pros for some good advice here.
  • Neo2_000
    • Apr 2005
    • 180
    Ok. Thats it. I've had enough!
    My old 3mm cherry-red tip Scope (not-the-mini) soldering iron has just gotta be history.
    Great for contact separation of FETs from mobos or high voltage Buzzbar work but zero finesse and no forgiveness whatsoever - it's just outa control.
    I need an iron that will do the soldering for me while I am falling asleep over the 2 oclock mobo.
    Time to invest in a state of the art grounded tip, temeprature controlled laserbeam Robo-solder 5000 or somefin like that!
    But what to get? Goot? Duratech? Weller? Ebay Trifecta? Double sided flat-tip? Round conical tip? Stainless steel tip? 2mm? 0.2mm? yada yada yada???? It's so complicated!
    What do you high end pros reckon is the best tool for the job, bearing in mind that I cannot afford a gold plated MIB automatic beta desoldering prototype.
    Probably somewhere around Oz$200 would do it for me.
    What specs and features should I look for?
    Any one brand /model a contender for the gold cup?
    Help!
    Neo.
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    try to find someone complaining about hakko on the net.
    http://www.computronics.com.au/hakko/soldering/
    • Neo2_000
      • Apr 2005
      • 180
      Thanks willawake.
      I will have a good look at the Hakko, especially since the link you povided is right in my back yard so to speak.
      Would like to hear from other members too. Any advice would be appreciated.
      Should I be concerned about the coming lead-free solder standard. Will it mean any substantial changes to soldering equipment apart from the tips?
      http://www.cooperhandtools.com/ad_pages/lead_free.htm
      Thanks,
      Neo.
      • willawake
        Super Modulator
        • Nov 2003
        • 8457
        • Greece
        yes i am concerned also about lead free. are we gonna have to work with boards soon that have solder like concrete?
        http://www.hakkousa.com/lead-free/default.asp
        • MD Willington
          • Sep 2004
          • 702
          WoW...Hakko 701 Repair System A$ 988.00 (~$746 USD)
          I realised we have about a dozen of these at work...
          Ya'll think us folk from the country's real funny-like, dontcha?
          The opinions expressed above do not represent those of BADCAPS.NET or any of their affiliates.
          • Neo2_000
            • Apr 2005
            • 180
            What do you think of Goot Soldering Irons?
            • willawake
              Super Modulator
              • Nov 2003
              • 8457
              • Greece
              i have a corded goot 25w with extremely fine tip. I have actually never used it cos i always need more than 25w but it is the most comfortable iron i have ever held. the manufacture appears to be excellent also. There is distribution of part of the goot range here so i have goot solder assist tools (great), tip refresher, goot antistatic wristband. all great.
              I think that goot and hakko are probably quite similar in quality. the difference is that hakko is better distributed around the world, they have a big american operation also.
              yeh either would be my choice. japanese speciality tools....
              • yanz
                • Nov 2004
                • 910
                btw i curently use this goot-taiyo 40w soldering iron.. it is cheap but reliable..
                • zen
                  Sunfire sub true sub woofer EQ signature schematic /advice please
                  by zen
                  Discovered that input to left or right channel will instigate a rumbling noise from sub , which is still present when signal removed.
                  Also discovered that if i monitor the plus 173V across one of the main smoothing caps, which is stable with no signal , but when input provided voltage can fluctuate 152V - 168V . Replaced the cap , which made no difference .
                  The minus 173V across the other cap is fine .
                  Could really do with some help trying to isolate this issue.
                  https://youtu.be/MSwIRZFfPc0
                  04-05-2023, 09:26 AM
                • Green Probe
                  Mosfet Advice
                  by Green Probe
                  Hi, Im looking to replace some EMP21N03 mosfets on an Alienware motherboard, but I'm having trouble finding a legit supplier. The ones that are available from China have pictures with the engraved logo looking very scratchy and sketchy. Nobody in the US sells them. I'm trying to find a compatible mosfet, but I'm not well versed enough to be confident im making the right choice. Does anyone have a suggestion or advice that could help me find the right mosfet? Thanks!
                  05-22-2025, 10:49 AM
                • user234
                  Gigabyte Eagle 3060 Ti - Boardview / Advice request please
                  by user234
                  Recently installed a new motherboard but during the process I seemed to have damaged my Gigabyte Eagle 3060 Ti card.
                  My motherboard ROG STRIX B550-A is detecting an issue with the VGA (light ON)
                  I have attached 2 photo's of my GPU board, one above and the other is what I believe to be the 5V - as you can see, this has visual damage so looks suspicious to me.
                  If I replace this part what are the odds this will resolve the issue? - any additional information on where to source the parts would be much apricated too!
                  This is...
                  05-10-2025, 04:25 AM
                • artvandalai
                  Advice on rewiring this stepup transformer?
                  by artvandalai
                  I bought this Chinese made step up transformer to run some 220v appliances. Some of the wires were brittle and broke off. I attempted to improve some of the wiring with spade terminals and heatshrink tubing as the wires were just soldered straight to the connectors. Any advice on how to rewire the broken wires on this step up transformer? I'm unsure how to go about rewiring this to a better safe working condition.
                  01-14-2025, 01:00 AM
                • wattsRpower
                  MBP 820-00928a need advice
                  by wattsRpower
                  I'm working on an a1707 macbook pro for a friend of mine that said it had stopped working and will not turn back on. After opening up the laptop I discovered a short on C7382 which took the PPBUS_HS_CPU to gorund.
                  After fixing the cap issue, I had 12.6 volts on the line. Not sure what or when something happened, but I am now getting 3.6 to 3.8 volts fluctuating. I was taking some volt readings and I'm not sure if I shorted something or if something else has happened.
                  At this point, I'm not sure where to start looking for something to fix. Maybe the cpu fried anyway when the PPBUS_HS_CPU...
                  10-12-2024, 04:55 PM
