Caps getting Hot!!!!
  • hypergod
    • Dec 2007
    Hello everybody on forum,
    I came across lots of boards with badcaps. Some of them are leaky, bulged or getting hot. But recently I had a ASRock P4i65GV motherboard with 2.8GHz HT processor & 1GB RAM. I noticed that almost all caps across CPU are getting extremely hot (untouchable). Even the coils with ferrite cores are getting hot. At present motherboard is working well except CMOS settings are getting lost when PC is switched OFF and ON (battery is changed but of no use). What might be the reason?? Can anyone throw light on the condition of this motherboard.
    Thank u.....
  • ss627
    Super Member
    • Mar 2008
    • 52
    Re: Caps getting Hot!!!!
    What power supply are you using?
    • hypergod
      • Dec 2007
      I tried with different SMPS of 400W to 500W. But problem persists.
      • Toasty
        • Jul 2007
        • 4171
        Does the CPU cooler blow up, away from CPU, or down towards CPU?
        If down, then it's probably time to investigate and replace those caps. If up, then get a cooler that blows down. You need air moving across those caps.
        Either way, I'd check out those caps. If you can, report the make and series of the caps.
        Toast
        veritas odium parit
        • 370forlife
          Large Marge
          • Aug 2008
          • 3112
          Ya, but if you are using some cheap'o no-name psu they can cause the same thing.
          • hypergod
            • Dec 2007
            Ok...now I came to point that the cap (1000uf) on the besides USB socket is getting hot first and then others are getting hot including FETs (small flat transistors mounted flat on motherboard). Replacing with same rating causing it to getting heated and bulge immediately. What could be the problem? Can anybody help???? Plz..........!!
            • Toasty
              • Jul 2007
              • 4171
              >>Replacing with same rating causing it to getting heated and bulge immediately. <<
              Did you put the caps in correctly observing the polarity markings?
              What caps were there? What caps did you use to replace them with?
              As I asked before: If you can, report the make and series of the caps.
              Toast
              veritas odium parit
              • MegaOne302
                • Apr 2009
                • 94
                What brand and voltage caps were there before; maybe it was a bad recap job.
                Does an idiot make a sound if no one’s there to hear them talk?
                • MegaOne302
                  • Apr 2009
                  • 94
                  Sounds like the caps were replaced with high ESR caps. What was and what is there now?
                  • PCBONEZ
                    Grumpy Old Fart
                    • Aug 2005
                    • 10661
                    I agree with above.
                    Instant bloat is usually a cap in backwards.
                    Mann-Made Global Warming.
                    - Dr Seuss
                      by momaka
                      03-12-2025, 03:42 PM
                    • eryjus
                      by eryjus
                      05-10-2023, 11:21 AM
                    • Paxman_Swede
                      by Paxman_Swede
                      Hello!
                      01-14-2025, 09:51 AM
                    • captain150
                      by captain150
                      03-16-2025, 07:34 PM
                    • Foetuss
                      Gigabyte GA-6OXT :: caps question
                      by Foetuss
                      Good evening
                      I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
                      Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
                      But I was also suprised about the bigger boys, which are 330µF 25V.
                      Could it be they used 25V caps because they were cheaper / available at that time?...
                      02-11-2025, 12:22 PM
