please help to identify capacitor marking TV 2 0318 (attached pic)
  • debugtimog
    • Jul 2018
    • 30
    • Malaysia
    Hi All,
    Please help me identify this capacitor, I have tried searching online but I cant figure it out, if someone could post the rating that would be much helpful.
    • 31090
    Re: please help to identify capacitor marking TV 2 0318 (attached pic)
    maybe it's written on the other side.
    however, if it's across the power pins on the chip then it's probably 0.1uf (100nf)
    • PeteS in CA
      • Aug 2005
      • 3581
      • USA, Unsure of Planet
      stj is probably correct, as to the value being on the other side and as to the likely value. The value code for .1uF would be "104" (100,000pF). The "0318" you can see is probably the date code (YYWW), the 18th week of 2003.
      PeteS in CA
      • R_J
        • 9558
        I would guess there are others like that on the board, can you see their numbers?
        • debugtimog
          • Jul 2018
          • 30
          • Malaysia
          i have pulled it out, and there's no other markings. maybe TV is manufacturer code?
            • 31090
            meter it.
            • Andrew F. Ali
              • Jan 2014
              • 2450
              • Trinidad & Tobago
              Are you asking because you think this is a bad part or are you just curious or are you getting a short across it?
              • jiroy
                • Jun 2016
                • 2416
                • Lebanon
                The 18 week of 2003 , and T stand for a Tantalum , although it's supposed to be a resin dipped axial ceramic capacitor , while they forgot to put the voltage code V and the the capacitance 3 digits ..Some low chinese made of course .
                Best thing to do is to show the near chipset number and the surrounding figure , trying to define a standard value .
                • R_J
                  • 9558
                  Multilayer Ceramic Capacitor axial lead
                  • debugtimog
                    • Jul 2018
                    • 30
                    • Malaysia
                    i am asking beacause I broke the original capacitor when I lifted one lead. I want to buy a new one but I cant figure the rating.
                    link for datasheet
                    https://cdn.badcaps-static.com/pdfs/...3e45f4cff8.pdf
                    • debugtimog
                      • Jul 2018
                      • 30
                      • Malaysia
                      sorry, I forgot to say that the capacitor is attached to the VCC pin of the Hex inverter.
                      • R_J
                        • 9558
                        Just replace it with a .1uf disc, or get one like this Kemet C410C104M5U5TA7200 or digikey.com 399-4454-1-ND
                        • debugtimog
                          • Jul 2018
                          • 30
                          • Malaysia
                          Thanks all. I followed R_J's advice. Please close thread.
                          • Andrew F. Ali
                            • Jan 2014
                            • 2450
                            • Trinidad & Tobago
                            You are welcomed.
