Need a cap Expert: Infrant ReadyNAS 600-TL
  • grtessman
    • Mar 2013
    Hi guys,
    Does anyone have any idea what I can use to replace these green caps on Infrant ReadyNAS 600-TL?
    Photos: https://photos.app.goo.gl/5J8J3oKpJkvU4iOi2
    I'd like to find good quality 10,000hr capacitor to replace these crappy LTecs but I am having a hard time figuring out what I need. I think they're both also 8mm X 11.5mm
    I found this reference sheet: https://cdn.badcaps-static.com/pdfs/...4a47e06c98.pdf but not sure how to translate correctly to a good brand and considering the part numbers on the caps differ.
    LTec LXY series both read 470uF 10V but have different numbers on them for some reason as follows:
    4 qty has numbers: 4D10D - 470uF 10V LXY 105°C C(M)
    2 qty has numbers: 5912D - 470uF 10V LXY 105°C C(M)
    Please help... Thank you VERY much!
    ~Gary
  • Uranium-235
    Comrade Glimmer
    • Aug 2007
    • 5042
    • US
    Re: Need a cap Expert: Infrant ReadyNAS 600-TL
    Sorry within those specs I cannot find a ripple/rms that is over 5000hrs
    • Sparkey55
      • Jan 2010
      • 1523
      Originally posted by grtessman
      Hi guys,
      ~Gary
      A close enough match (even better) would be Rubycon ZLH 470uf 16V from Badcaps.net Store
        • 31214
        or try polymer caps
        • Sparkey55
          • Jan 2010
          • 1523
          Originally posted by stj
          or try polymer caps
          Polymers would be way too low ESR. The original caps are rated at 0.072 ohm.
          The Rubycon ZLH 470uf 16V 8mm is rated for 0.056 ohm.
          A good step up would be Nichicon HN or HZ, both would be overkill.
