Acer AN-515-57 LA-L191P please help write down the serial numbers
  • ramkaskad12
    • May 2018
    • 54
    • ukraine
    • 22035
    Re: Acer AN-515-57 LA-L191P please help write down the serial numbers
    You can copy it yourself using the attached script, see the README file.
    • ahmedtou
      HOW CAN I UPDATE HL-DT-ST BD-RE GGW-H20N XA02
      by ahmedtou
      help me please
      I have an HL-DT-ST BD-RE GGW-H20N with ROM version: XA02.
      When I tried to burn a 25GB Blu-ray disc using ImgBurn, I got an error.
      I will share all the details with you, including the disc information.
      Code:
      HL-DT-ST BD-RE  GGW-H20N XA02 (ATA)
      Current Profile: BD-R
      Disc Information:
      Status: Empty
      State of Last Session: Empty
      Erasable: No
      Free Sectors: 12,219,392
      Free Space: 25,025,314,816 bytes
      Free Time: 2715:27:17 (MM:SS:FF)
      Next
      08-27-2025, 08:49 AM
    • bruce35
      HP 600 G3 MT serial number change please
      by bruce35
      HP 600 G3 MT
      SERIAL NUMBER MXL8301K1C Serial number in the file in bios
      SERIAL NUMBER CZC72988BY original serial number of the safe original serial number of the safe
      Thank you very much...
      09-24-2025, 02:32 AM
    • ChaosLegionnaire
      bug of the month: write caching setting for the hard drive in device manager
      by ChaosLegionnaire
      i recently bought a new wd re4 2tb with 2014 datecodes. when i got around to testing it tho in victoria hd tester, the write speed was very slow at 14 mb/s with a 256 sector transfer size. when i increased the transfer size to 1024 sectors, the write speed increased slightly to 44 mb/s. read speeds and sector verify speeds were fine and at normal speeds.
      so i just ass-u-med the drive's poor performance was due to it being an advanced format drive and i was using it on winxp. when i tried cloning my system disk to this wd re4 2tb drive and writing to it in linux, the write speed...
      10-06-2019, 01:39 PM
    • Dannyx
      UART (serial ?) splitter ?
      by Dannyx
      Good day folks. I got a project on hand and would like some thoughts on whether it's possible to achieve, albeit impractical. You know me - I like to over-complicate stuff
      The setup: I got a Paradox EVO192 alarm panel, a serial-to-ethernet adapter and an official PCS250 GSM communicator.
      The task (TL/DR): connecting both the ethernet adapter AND the communicator to the single serial port of the Paradox panel. Connecting their TX/RX lines in parallel the data would get all messed up. At the very most, I THINK I could parallel the RX pins of the ethernet adapter...
      08-18-2023, 03:21 PM
    • mshone
      Lenovo thinkpad P1 G2 UUID and Serial number/mashine type unknown
      by mshone
      Sorry if topic if misplaced. Have lenovo thinkpad P1 gen2 with Xeon E-2276M CPU and NVIDIA® Quadro® T1000. It is a new board replaced. Old board was P1 G1 model with i7 and it is defective. I ordered a new one with xeon, but is gen 2. Laptop case is suitable for this motherboard, with some little difference (GPU fan and subcard).Ok, ordered and replaced and GPU fan and subcard and now laptop is working fine, but serial number and UUID is unknown. Ok, i readed several topics here and found Thinkpad maintenance disk, but.....which values to type? How to find data base with those values? serial...
      08-29-2025, 06:41 AM
