My caps LOOK ok, but my board doesn't work!
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16959
    This board is definite proof positive that your caps can LOOK ok in appearance, but are absolutely unusable or dead. The customer contacted me, stating that his caps looked perfect, but the system froze one day, and never POST'd again. The board is an ECS D6VAA, a common one for the plague.
    When I got the board in for repair, he was right... heh... It wouldn't POST. Indeed, his board packed with G-Luxon caps looking as good as they did the day they were manufactured. Not a single one had even the slightest bit of swelling.
    Before recapping, I checked the VRM's for shorts, just to make sure I wouldn't be pissing in the wind and wasting caps trying to rebuild it. VRM's were fine, so I recapped it with some nice pretty new Rubies (MBZ Series), and she's operating perfectly now!
    Lesson boys and girls: They don't always have to appear bad to be bad!! I get asked this a lot: "They look ok, whats wrong with my board?" Even if they look ok, take note of the brand. We all know G-Luxons are turds out of the factory...
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
  • Neo2_000
    • Apr 2005
    • 180
    That's where an ESR meter comes in handy, revealing suspect caps where there is no physical evidence.
    I would be interested in learning more about testing VRM's. I assume you are referring to the 3 legged chips that usually have the middle leg cut off. I have seen these referred to as VRM's and mosfets among other names.
    What are these things really, what function do they actually perform?
    What are common problems you may test them for and how do you test for them?
    Do you have to remove them from the circuit board to effectively test them?
    I recall reading one post where there was no joy after replacing the caps on one board, so the tech also replaced these chips and the board came good.
    Thanks,
    Neo.
    • AK0R
      • Mar 2005
      • 204
      VRMs (voltage regulator modules) are a specific class of MOSFETs; MOSFETS are a specific type of FETs. FETs have several advantages over bipolar transistors. For a basic description on the workings of a voltage regulator, search on "7805 data" on Google or Yahoo (7805 is a basic 5-volt regulator).
      VRMs take one voltage (such as +5 VDC) and produce a different, lower voltage that is needed by various components (microprocessor, memory, etc.). Each VRM can only produce one output at a time, so two different VRMs are needed if the CPU and memory operate at different voltages. The output of the VRM can be varied slightly, depending on how external components are connected and controlled, so some motherboards are able to have settable voltages for memory. CPU voltage is usually, but not always, taken care of automatically. True variable power supplies, where the voltage is variable over a large range, aren't used in PCs. The middle leg is usually cut off, because it is connected to the case, which is soldered to the board. The case is often, but not always, connected to ground. To test one, you need to know what the input and output should be, then measure them with respect to a known ground. If the VRM produces no or low output with proper input, either it's bad, or an external controlling component is bad. If the input is bad, look for upstream damage. Usually, it's best to test a VRM in-circuit (with CPU, memory, etc. removed!) so that the output can be checked at the immediate output of the VRM, as well as at the point of connection of the powered device.
      • MD Willington
        • Sep 2004
        • 702
        I'm looking for a good right up on testing VRM's since I get asked how to test them every so oftem, in all honesty, I have not tested a VRM in a long time so I'm kind of foggy oon the whole procedure.
        MD
        Ya'll think us folk from the country's real funny-like, dontcha?
        The opinions expressed above do not represent those of BADCAPS.NET or any of their affiliates.
        • m1ch43lzm
          by m1ch43lzm
          05-12-2025, 08:37 PM
        • Dani_2024
          by Dani_2024
          10-28-2024, 05:06 PM
        • black6host
          Replacement caps for Samson Resolv studio monitor 65A Amp board.
          by black6host
          Good day!
          I have a Samson Resolv studio monitor that has no sound output. I've opened it up and found two caps that are bulging on what I believe to be the power supply section of the amplifier board. The board is marked Resolv 65A AMP V1.2. The caps in question are YUSCON, 2200uF, 35V, 85C temp and have markings of RA(P) and are 16mm x 25.5mm tall. I've attached the schematic and the caps in question are C5 and C6. I'm assuming they are low esr caps. I've tested both caps and they test low uF, nowhere near 2200uF.
          I'm going to replace the caps and I'll be the first...
          02-06-2024, 08:22 PM
        • Noodneek
          Replacing all the caps on the BenQ SW2700pt's power board didn't help...
          by Noodneek
          My 3.5 years old monitor (BenQ SW2700pt) started to black out for 1-2 sec every minute or so, it was doing this even with PC disconnected from it. I searched online and read that it's probably aging capacitors and there's a workaround to lower the brightness.
          I lowered it from 100 to 65% and it indeed helped, but after a couple of months the issue returned... I continued to lower the brightness, but it helped only for a couple of hours at most, then I needed to lower it further... Turning the monitor off and waiting for it to cool down also helped for a short time, after which it...
          08-30-2024, 12:52 PM
