Starter Capacitor Kits in the UK
  • mrdiy88
    • Nov 2017
    • 59
    Hi. It is unfortunate to learn that TC no longer sells caps as I would trust him. In light of this I was hoping someone could recommend a kit or assorted bag of caps to keep a small stock of the popular or common capacitors for tv board power supplies and tv repairs. I seen cheap general purpose on ebay obviously I wont buy these. I thought I may need low esr. I wanted decent quality but from a supplier in the UK. Thanks in advance.
    • 31289
    Re: Starter Capacitor Kits in the UK
    make a list of common sizes,
    look up the prices for panasonic FM and FR series on RS and CPC and buy the cheapest.
    • mrdiy88
      • Nov 2017
      • 59
      Thank you
      • diif
        • Feb 2014
        • 6978
        • England
        Depending on the value, check Farnell also. The parent company of CPC, so a much larger range with free shipping if your order is over £20.
        • mrdiy88
          • Nov 2017
          • 59
          Will do thank you
          • Th3_uN1Qu3
            Believe in
            • Jul 2010
            • 6031
            Also check out TME.eu. Cheaper than Farnell, at least for Romania. They also sell cheaper brands but i do not recommend any of them for other than hobby work. They have a pretty good selection of Nichicon, Chemicon and Panasonic.
            A working TV? How boring!
            • mrdiy88
              • Nov 2017
              • 59
              Cheers Th3
              • vinceroger69
                • Mar 2012
                • 6714
                • uk
                i use rs components myself as postage is always cheap and quick, but like you say be nice if we can find a chart with commonly used capacitors (rating size and voltage) that are used in tv psu s, what i have been doing is if i have to recap a psu to recap i just double/triple my order so im building up a spares supply slowly.
                • mrdiy88
                  • Nov 2017
                  • 59
                  That's a great idea Vince, I think I will do the same, good way to do it. I agree too a chart would be brill. I have filled my cart on a few occasions now but wasn't 100% sure. But time is a good teacher
                  • MORETTIGIAN
                    by MORETTIGIAN
                    Title:
                    Description:
                    Procedure performed:
                    - Removed backplate
                    - Reapplied thermal compound
                    - Reassembled card
                    09-18-2025, 12:14 PM
                  • Prolog
                    by Prolog
                    12-01-2024, 08:27 PM
                  • Agent24
                    Dick Smith Q-1760 linear power supply filter capacitor question
                    by Agent24
                    I have acquired a used Dick Smith Q-1760 power supply - although the OEM is Manson Industrial
                    It has at least one problem.
                    The voltage control potentiometer VR2, 50K is faulty - going high resistance / open circuit in the CCW end and leading to the output voltage jumping around.
                    I have already ordered a replacement potentiometer, so that's not an issue.
                    Now, I want to replace all three electrolytics on the PCB as they are CapXon and I don't trust them so much, I will replace them with something better while I've got the thing apart anyway.
                    All are CapXon...
                    10-21-2025, 05:39 PM
                  • chth96
                    by chth96
                    12-22-2023, 04:34 AM
                    Acer TravelMate P214-52-566U+STARTER KIT 15'' Notebook P2 Specification for Upgrade or Repair
                    This specification for the Acer TravelMate P214-52-566U+STARTER KIT 15'' Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P214-52-566U+STARTER KIT 15'' boardview and P214-52-566U+STARTER KIT 15'' schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                    09-06-2024, 07:20 PM
