Cap rated voltage
  • nian28
    • Feb 2009
    • 5
    Cap rated voltage
    Hi Guys,
    How do you test for the capacitor's rated voltage?
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    Re: Cap rated voltage
    You look it up in the data table.
    Mann-Made Global Warming.
    - Dr Seuss
    • nian28
      • Feb 2009
      • 5
      I mean, a means for you to check if the cap is in tune with the data table.
      For example, I have a 47uF/50V cap. Can I hook the cap directly to a 50V DC power supply and measure if the capacitance is not changing? Is the way I measure capacitance acceptable? If the capacitance remain unchange, can I say that the cap is in tune with the datasheet?
      • PCBONEZ
        Grumpy Old Fart
        • Aug 2005
        • 10661
        If you try to measure capacitance with 50 volts on the cap you will blow up the capacitance meter.
        - Dr Seuss
        • PCBONEZ
          Grumpy Old Fart
          • Aug 2005
          • 10661
          What you are trying to do won't show you or accomplish anything.
          50v rated caps are created by applying somewhere around 100v DC to them for so many hours to build up ["Form"] an aluminum oxide layer on the foil which is the actual dielectric in lytic caps.
          The process is called "forming".
          Once they are formed they are 'derated' to the rating in the data table.
          - Dr Seuss
          • sofTest
            • Aug 2008
            • 361
            Isn't is possible to go through a reconditioning procedure to check the rated voltage? I came across a couple of sites some weeks ago where this procedure was described, though different. For low voltage capacitors, one used 1000 ohms limiting resistor for each capacitor in series with a power source. One site said to use 110% rated voltage for 3 hours, the other site said use rated voltage for 30 minutes, and then measure voltage after disconnecting. If I remember correctly, then if capacitor within 95% of rated voltage, it pass test. I realize the procedure is a bit cumbersome/impractical just to test individual capacitors, but I'm just curious myself.
            Be a mensch
            • nian28
              • Feb 2009
              • 5
              Thank you very much sofTest! I think that's the answer I was looking for.
              I was googling and had no luck finding that website, I was hoping you could post it here.
              • sofTest
                • Aug 2008
                • 361
                Had to Google them again, but luckily the two links was still marked as read:
                http://www.duracap.com/electrolytic_...tion_guide.htm
                And two more I stumbled upon looking for the others:
                Be a mensch
                • Perry Babin
                  Operating caps well below rated voltage
                  by Perry Babin
                  I think this has been answered but I couldn't find the thread.
                  Someone asked me if it would harm a capacitor (10F [not a typo], 24v) if it was operated on nothing more than 12v.
                  So, I ask... Does it change any of the capacitor's characteristics/parameters/? in any way if it is never operated near rated voltage?
                  If operated for years at 1/2 rated voltage, does it accept full rated voltage like it would if it had always been operated at the higher voltage?
                  Or would it require reforming?
                  05-23-2024, 05:43 PM
                • UserXP
                  Transformer producing higher voltage than rated
                  by UserXP
                  Hello, people.
                  i am not sure if this question belongs to this forum section exactly, but since there already are some queries here about power transformer, let's give it a try.
                  So, I have this old but very well preserved Casio SA-20 ToneBank keyboard. It is powered either by five 1.5V AA bateries, or via a power adapter, so its operating voltage is 7.5V. The power adapter input jack also states 7.5V DC In. Now, since this keyboard was never supplied with a PT, but actually came with test bateries included, I decided to try to buy an adapter for it. I know I could have just gone...
                  09-02-2025, 12:42 AM
                • Antonynl
                  Capacitance and voltage of tantalum?
                  by Antonynl
                  I have a tantalum capacitors with indicators EB 21 that measures only 22pF. See attached picture.
                  Since this is a windmeter that is normally in a very high mast I would like to get the correct replacement capacitor.
                  Is there somebody that can tell me what the capacitance and voltage of this capacitor are?
                  I don't feel confident that I can figure this out myself after searching around
                  Cheers!!
                  04-14-2024, 03:19 PM
                • Fernon@Repair
                  Gigabyte Z490 Gaming X Motherboard No VCORE Voltage
                  by Fernon@Repair
                  i have Gigabyte Z490 Gaming X Motherboard .it has a power on no display fault .. no vcore voltage and debug led stuck CPU LED .
                  VCCIO voltage ok
                  VCCSA Voltage OK
                  VCCPLL Voltage OK
                  Ram Voltage ok
                  RamVTT OK
                  VPP 2.5 OK
                  But No Core Voltage
                  and i want to this vrm ic datasheet or pinout (ISL69269)
                  anyone have this ic pinout voltages?...
                  06-25-2025, 07:19 AM
                  Trip light 2400 watt line conditioner bought used issue with low voltage oscillation going on between relays
                  by sam_sam_sam
                  I found two capacitors on the board and one of the leads on one capacitor had bad soldering joint and the other joint connections not much better and there were several soldering joints that way to much flux around the joint redid several of them
                  The capacitors were a non brand that I did not recognize they got replaced and now it does not oscillating between relay but what concerns me a little bit is when the voltage is a little bit low the output voltage is around 130 volts and then drops down to 115 volts this happens around 105 to 108 volts if remember correctly
                  Now...
                  06-09-2024, 10:57 AM
