I have three crapXon KMs. 25v, 2200u, 1.2Arms, no listed ESR. Classified as general. Closest I get is UCC KMEs, which are out of stock on mouser. The other ones are that are 1.2A are classified as audio caps. Are these suitable as replacements? Not even sure low ESR/high ripple are suitable replacements. Ive seen what happens on pc psus when people have tried replacing general purpose caps with polys
Using audio caps on smps secondaries?
^If you have datasheets not listed PM meTags: None -
Re: Using audio caps on smps secondaries?
Get shitty Low ESR ones.
Like Nippon KYA or Pana FC.
But Mouser has some good replacements like Panasonic M Series, maybe NHG series or Nichicon URS or UVP series.
Choose your poison...Comment
But the ones in there are not low esr and only fair ripple, they're not bloated, still I want to replace them thoughCap Datasheet Depot: http://www.paullinebarger.net/DS/
^If you have datasheets not listed PM meComment
Now if it's just a regular non-flyback SMPS, you should probably go with entry-level low ESR, like Panasonic FC, Nichicon PS/PM/PW/PJ, Rubycon YXJ, or Chemicon KYA.
As to the question in the title: yes, you could probably get away with using audio-grade caps on SMPS, but it's not recommended. Audio-grade caps usually have higher ripple current capability at low frequencies (typically compared at 120 Hz or 1 KHz) compared to both general purpose and low-ESR caps. At higher frequencies in the 10's to 100's of KHz range, low-ESR caps have higher ripple current. So essentially, low-ESR caps are more suitable for high frequency circuits.Last edited by momaka; 02-05-2018, 11:56 AM.Comment
by reweaseHi everyone,
There actually was a time when early SMPS and late bakelite housed electrolytic caps coexisted in high end industrial gear. A friend of mine just got himself a CNC milling machine form that time with its first set of now 41 year old caps still installed in the PSU... and it's malfunctioning.
Two of the caps have already leaked slightly onto the board. I have not desoldered or measured any so far but they should qualify for replacement.
Now I'm wondering what to put in there as a replacement. First idea was state of the art low-ESR Nippon KY,...-
by momakaI know I've been a little scarce lately (like the last 2-3 years), but I'm still here and still doing my thing with fixing PSUs.
https://www.badcaps.net/filedata/fetch?id=359177... -
by SluggerBI have an old Tivo. The Power Supplies are known to have caps that fail. Here are the caps that come with the original power supply:
I could not find replacement caps with the exact same specs. I followed an online guide and recapped the power supply with caps with these specs
The power supply now works, however the HDMI video is giving me eye strain. I don't know how a capacitor on a Power supply could impact an HDMI video signal, but it does, the Tivo interface has a flicker now and the color/brightness is off. So I want to get some new caps...-
by Paxman_SwedeHello!
I have studied the board and...-
by fl0wHi,
I just noticed that my Asus V9999GT (GeForce 6800 GT) had some swelling capacitors. I managed to identify the brown ones, which are Nippon Chemi-Con KZG series, 6.3V 820µF, which I plan to replace with this.
But for the yellow ones, I guess these are Fujitsu caps, without being able to identify which series... A picture of the video card is attached to the topic.
I need to replace:- 2x 2.5V 1500µF => I plan to use this
- 2x 16V 330µF=> I plan to use this
- 1x 6.3V 680µF=> I plan to use this
Thanks for...1 Photo-
- Loading...
